[QGIS-Developer] PyQGIS unavailable at QGIS startup time on OSGeo4W
Jürgen E. Fischer
jef at norbit.de
Mon Oct 7 03:34:03 PDT 2019
Hi Eric,
On Wed, 02. Oct 2019 at 14:10:29 +0200, Eric Lemoine wrote:
> > Not sure why PYQGIS_STARTUP is used that early. The python path is
> > added shortly after it was referenced:
> > https://github.com/qgis/QGIS/blob/master/src/python/qgspythonutilsimpl.cpp#L98
> Yep saw that. And I was wondering too.
> > So other platforms should have the same issue.
> Except that there's no probleme on Linux, because PyQGIS is installed
> globally in the main Python environment.
We probably wouldn't if we would install multiple versions…
> So Jürgen, would you suggest to change the QGIS code?
4c1b95ba9ee0d5f0e4c9664bd293003ef280ba31 suggests that it's intentionally that
way - so that should probably stay as is.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191007/31f7923b/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191007/31f7923b/attachment.ksh>
