[QGIS-Developer] Making QgsRasterLayerProperties class independent again from QgisApp instance
Paolo Cavallini cavallini at faunalia.it
Mon Oct 7 22:11:08 PDT 2019
Hi all,
On 07/10/19 22:05, Vincent Cloarec wrote:
> The purposed PR permits to use this class through the GUI library. This
> is cleaner and less tricky than using it from the App library. I think
> it is a good thing for stand-alone applications devs.
> I don't know if there is a lot of devs who are developing stand-alone
> applications. So maybe there is no advantage to accept my PR, and I will
> understand it could not be accepted.
> But, today,  I need to know if I can count on this PR will be accepted,
> or if I have to think about another solution to continue to use the
> QgsRasterLayerProperties.
> If someone has an idea about this?
this seems reasonable to me, as generally keeping the GUI separated is a
good practice.
Anyone sees a problem here?
Cheers.
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the QGIS-Developer mailing list
