[QGIS-Developer] 3.10 hard freeze?
Nyall Dawson nyall.dawson at gmail.com
Sun Oct 13 23:21:43 PDT 2019
On Mon, 14 Oct 2019 at 16:19, Peter Petrik
<peter.petrik at lutraconsulting.co.uk> wrote:
> Hi,
> I am wondering if it would be good idea to branch of the 3.10 when it is already in the hard freeze mode, so we are able to merge PRs to master for 3.12 release?
> That way the HF fixes would me merged directly to 3.10 branch and also the tagging/release could be done on the branch before release?
Check my other email on the dev list from earlier today ;)
Nyall
> Peter
> On Mon, Oct 14, 2019 at 7:55 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Mon, 14 Oct 2019 at 15:33, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> > Hi all,
>> > I had a PR tagged as frozen this morning.
>> > I guess this is related to the concept of hard freeze. Can someone give more information on soft vs hard freeze? Any what is accepted to be merged?
>> Denis,
>> My understanding is that the hard freeze is basically a "hands off"
>> for 3.10.0. We could consider 3.10.0 as being tagged for release as of
>> the freeze, and it's now just in a pending state while we put out
>> calls for testing.
>> I haven't seen any fixed guidelines on what we'd allow in during this
>> time, but my 2c is that we should only let in absolutely mission
>> critical, life-threatening stuff. Everything else needs to wait till
>> 3.10.1.
>> On this note, for the hard freeze period I've set the github master
>> branch to use the same branch restrictions as we apply to our LTR
>> branch (no direct pushes, PRs require all passing tests + 1
>> non-submitter review).*
>> Nyall
>> * I'm quite tempted to "forget" to set this back after hard freeze ends ;)
>> > Cheers,
>> > Denis
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
