[QGIS-Developer] 3.10.0 in hard freeze, should we branch master as unfreeze for 3.12?
Mathieu Pellerin nirvn.asia at gmail.com
Mon Oct 14 03:24:55 PDT 2019
I'm also -0 to branch off early, as I think it's a missed opportunity to
get core devs to stick to soon-to-be-released 3.10 for as long as possible
(and therefore oh-so slightly increase the chance of core devs stumbling on
a bug he/she can fix prior to release :) ) .
On Mon, Oct 14, 2019 at 4:02 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> On Mon, 14. Oct 2019 at 09:14:58 +0200, Denis Rouzaud wrote:
> > Hi all,
> > I don't have a strong opinion, but it would be good to have pros and cons
> > to decide.
> > Jürgen, since you are the release manager, are you saying it's not a good
> > idea (why?) or rather that you have to modify the procedure (meaning more
> > work)?
> The only gain I see is that we can just continue working on master earlier.
> Branching off also means that we have to put the new version number on that
> branch prior to the actual release.   The nightly build scripts will not
> expect
> to see a new branch and handle it like it as if it was a new release.
>  When to
> merge and how to update translations in the meantime is also unclear
> (transifex
> is tied to the branches we current have).
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191014/5d8d0b2e/attachment.html>
More information about the QGIS-Developer mailing list
