[QGIS-Developer] Installing qgis custom widgets in designer from development build
Chris Crook
ccrook at linz.govt.nz
Tue Sep 10 14:33:44 PDT 2019
Hi all
I'm still having problems installing the custom widgets into designer on ubuntu 18.04. I've run make and make install, and copied the custom widgets .so with
sudo cp libqgis_customwidgets.so.3.9.0 /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqgis_customwidgets.so
It is being found, in that when designer starts it now dies :-( I think the problem is that it is not finding qgis.db, though there are other errors along the way. Output when starting up is listed below. QGIS itself starts up normally.
Still desperate for ideas!!!
Thanks
Chris
QMetaProperty::read: Unable to handle unregistered datatype 'DocumentViewerContent' for property 'QgsExternalResourceWidget::documentViewerContent'
QMetaProperty::read: Unable to handle unregistered datatype 'QgsFileWidget::RelativeStorage' for property 'QgsExternalResourceWidget::relativeStorage'
QMetaProperty::read: Unable to handle unregistered datatype 'QgsFieldProxyModel::Filters' for property 'QgsFieldComboBox::filters'
QMetaProperty::read: Unable to handle unregistered datatype 'QgsFieldProxyModel::Filters' for property 'QgsFieldExpressionWidget::filters'
QMetaProperty::read: Unable to handle unregistered datatype 'StorageMode' for property 'QgsFileWidget::storageMode'
QMetaProperty::read: Unable to handle unregistered datatype 'RelativeStorage' for property 'QgsFileWidget::relativeStorage'
QMetaProperty::read: Unable to handle unregistered datatype 'QgsTextFormat' for property 'QgsFontButton::textFormat'
QMetaProperty::read: Unable to handle unregistered datatype 'QgsMapLayerProxyModel::Filters' for property 'QgsMapLayerComboBox::filters'
src/gui/qgsproviderguiregistry.cpp:94 : (loadDynamicProviders) [57ms] Checking . for GUI provider plugins
src/gui/qgsproviderguiregistry.cpp:98 : (loadDynamicProviders) [0ms] No dynamic QGIS GUI provider plugins found in:
src/gui/qgsgui.cpp:123 : (enableAutoGeometryRestore) [1ms] WARNING: No object name set. Best for it to be set objectName when using QgsGui::enableAutoGeometryRestore
src/core/qgscoordinatereferencesystem.cpp:1221 : (getRecord) [6ms] user qgis.db not found
ASSERT: "sc" in file /qgis/src/gui/attributetable/qgsdualview.cpp, line 76
Aborted (core dumped)
________________________________________
From: QGIS-Developer [qgis-developer-bounces at lists.osgeo.org] on behalf of Matthias Kuhn [matthias at opengis.ch]
Sent: Monday, 9 September 2019 10:31 p.m.
To: qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] Installing qgis custom widgets in designer from development build
Hi Chris,
First thing is to run CMake with -DWITH_CUSTOM_WIDGETS
Then the resulting library needs to be copied into the folder where Qt
loads its plugins from.
Matthias
On 9/9/19 9:43 AM, Chris Crook wrote:
> Title pretty much is the question - I'm building QGIS development build on ubuntu as per instructions in INSTALL.
> I think the thing I need to register with designer is libqgis-customwidgets.so. But that doesn't seem to be built as part of the CMake build (can't find the file anywhere), and the only reference to it I can find is in the debian directory as a package. I'm not familiar enough with packaging to figure out how it gets built or what source files are used :-(
> Any help would be great - I am building on a virtual machine with source code in a mounted directory.
> Thanks for any guidance
> Chris
> This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
