[QGIS-Developer] Installing qgis custom widgets in designer from development build
Jürgen E. Fischer
jef at norbit.de
Tue Sep 10 23:53:44 PDT 2019
Hi Chris,
On Tue, 10. Sep 2019 at 21:33:44 +0000, Chris Crook wrote:
> I'm still having problems installing the custom widgets into designer on ubuntu 18.04. I've run make and make install, and copied the custom widgets .so with
> sudo cp libqgis_customwidgets.so.3.9.0 /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqgis_customwidgets.so
> It is being found, in that when designer starts it now dies :-( I think the
> problem is that it is not finding qgis.db, though there are other errors
> along the way. Output when starting up is listed below. QGIS itself starts
> up normally.
See fixed https://github.com/qgis/QGIS/issues/31657
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190911/2dfb2fee/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190911/2dfb2fee/attachment.ksh>
