[QGIS-Developer] Plugin version number
Borys Jurgiel
lists at borysjurgiel.pl
Fri Sep 13 01:49:07 PDT 2019
Dnia piątek, 13 września 2019 10:05:14 CEST Paul Wittle pisze:
> Hi,
> It is possible to see the plugin version number (from the metadata file)
> when you open the manage plugins window and select a plugin.
> Is it possible to retrieve this version number using Python in the plugin
> itself?
from qgis.utils import pluginMetadata
pluginMetadata('db_manager', 'version')
In (a rare) case it doesn't meet your needs (e.g. the plugin you examine is not loaded), you
can alternatively parse the metadata.txt file on your own, using Pyton's
configparser.ConfigParser
> It's not really very important but I just want to be able to include it in
> messages; so for example, "You have successfully upgraded to version..." or
> being able to automatically include the version number in bug reporting.
> I did try an internet search but it just comes up with people looking for
> the version of Python rather than the actual version of the plugin itself.
> Thanks in advance,
> Paul
> This e-mail and any files transmitted with it are intended solely for the
> use of the individual or entity to whom they are addressed. It may contain
> unclassified but sensitive or protectively marked material and should be
> handled accordingly. Unless you are the named addressee (or authorised to
> receive it for the addressee) you may not copy or use it, or disclose it to
> anyone else. If you have received this transmission in error please notify
> the sender immediately. All traffic may be subject to recording and/or
> monitoring in accordance with relevant legislation. Any views expressed in
> this message are those of the individual sender, except where the sender
> specifies and with authority, states them to be the views of Dorset
> Council. Dorset Council does not accept service of documents by fax or
> other electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its attachments
> whether encoded, encrypted or otherwise supplied are free from computer
> viruses, Dorset Council accepts no liability in respect of any loss, cost,
> damage or expense suffered as a result of accessing this message or any of
> its attachments. For information on how Dorset Council processes your
> information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190913/949cfdbc/attachment.html>
