[QGIS-Developer] Plugin version number
Raymond Nijssen r.nijssen at terglobo.nl
Fri Sep 13 01:52:39 PDT 2019
Tnx Borys! :)
On 13-09-19 10:49, Borys Jurgiel wrote:
> Dnia piątek, 13 września 2019 10:05:14 CEST Paul Wittle pisze:
>  > Hi,
>  > It is possible to see the plugin version number (from the metadata file)
>  > when you open the manage plugins window and select a plugin.
>  > Is it possible to retrieve this version number using Python in the plugin
>  > itself?
> from qgis.utils import pluginMetadata
> pluginMetadata('db_manager', 'version')
> In (a rare) case it doesn't meet your needs (e.g. the plugin you examine
> is not loaded), you can alternatively parse the metadata.txt file on
> your own, using Pyton's configparser.ConfigParser
>  > It's not really very important but I just want to be able to include
> it in
>  > messages; so for example, "You have successfully upgraded to
> version..." or
>  > being able to automatically include the version number in bug reporting.
>  > I did try an internet search but it just comes up with people looking for
>  > the version of Python rather than the actual version of the plugin
> itself.
>  > Thanks in advance,
>  > Paul
>  > This e-mail and any files transmitted with it are intended solely for the
>  > use of the individual or entity to whom they are addressed. It may
> contain
>  > unclassified but sensitive or protectively marked material and should be
>  > handled accordingly. Unless you are the named addressee (or authorised to
>  > receive it for the addressee) you may not copy or use it, or disclose
> it to
>  > anyone else. If you have received this transmission in error please
> notify
>  > the sender immediately. All traffic may be subject to recording and/or
>  > monitoring in accordance with relevant legislation. Any views
> expressed in
>  > this message are those of the individual sender, except where the sender
>  > specifies and with authority, states them to be the views of Dorset
>  > Council. Dorset Council does not accept service of documents by fax or
>  > other electronic means. Virus checking: Whilst all reasonable steps have
>  > been taken to ensure that this electronic communication and its
>  > whether encoded, encrypted or otherwise supplied are free from computer
>  > viruses, Dorset Council accepts no liability in respect of any loss,
> cost,
>  > damage or expense suffered as a result of accessing this message or
> any of
>  > its attachments. For information on how Dorset Council processes your
>  > information, please see www.dorsetcouncil.gov.uk/416433
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
