[QGIS-Developer] Plugin version number
Raymond Nijssen
r.nijssen at terglobo.nl
Fri Sep 13 01:51:18 PDT 2019
Hi Paul,
I do not think it is supported now, but a workaround could be:
- Add a variable 'version' with the plugin version number to your plugin
class.
- Then do:
qgis.utils.plugins['your plugin name'].version
You could even write a version() function that reads the version number
from the metadata.txt to prevent redundancy.
I wonder if there is another way though..
Kind regards,
Raymond
On 13-09-19 10:05, Paul Wittle wrote:
> Hi,
> It is possible to see the plugin version number (from the metadata file)
> when you open the manage plugins window and select a plugin.
> Is it possible to retrieve this version number using Python in the
> plugin itself?
> It’s not really very important but I just want to be able to include it
> in messages; so for example, “You have successfully upgraded to
> version…” or being able to automatically include the version number in
> bug reporting.
> I did try an internet search but it just comes up with people looking
> for the version of Python rather than the actual version of the plugin
> itself.
> Thanks in advance,
> Paul
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it,
> or disclose it to anyone else. If you have received this transmission in
> error please notify the sender immediately. All traffic may be subject
> to recording and/or monitoring in accordance with relevant legislation.
> Any views expressed in this message are those of the individual sender,
> except where the sender specifies and with authority, states them to be
> the views of Dorset Council. Dorset Council does not accept service of
> documents by fax or other electronic means. Virus checking: Whilst all
> reasonable steps have been taken to ensure that this electronic
> communication and its attachments whether encoded, encrypted or
> otherwise supplied are free from computer viruses, Dorset Council
> accepts no liability in respect of any loss, cost, damage or expense
> suffered as a result of accessing this message or any of its
> attachments. For information on how Dorset Council processes your
> information, please see www.dorsetcouncil.gov.uk/416433
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
