[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Alexander Bruy alexander.bruy at gmail.com
Thu Sep 19 22:04:57 PDT 2019
these options are not used anymore and should be removed. Correct extension now
determined automatically from the filename for file-based outputs.
пт, 20 вер. 2019 о 00:02 Alexandre Neto <senhor.neto at gmail.com> пише:
> Hi all,
> I have realized that the processing option to determine the default output extension as moved to the advanced settings. What I find odd is that the value type is an integer and the default values is now 0. Changing it to 1, seems to make the default shapefiles.
> If exists, where can I find the enumeration for default values? this needs to be documented
> Thanks,
> Alexandre Neto
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
More information about the QGIS-Developer mailing list
