[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Alexandre Neto senhor.neto at gmail.com
Fri Sep 20 00:13:26 PDT 2019
Hi Alex,
Thanks for your fast answer.
Is there a way to control what happens in multi output files? Like split
vector layer, wher you can only select a output folder.
Thanks,
Alex
A sexta, 20/09/2019, 06:05, Alexander Bruy <alexander.bruy at gmail.com>
escreveu:
> Hi,
> these options are not used anymore and should be removed. Correct
> extension now
> determined automatically from the filename for file-based outputs.
> пт, 20 вер. 2019 о 00:02 Alexandre Neto <senhor.neto at gmail.com> пише:
> > Hi all,
> > I have realized that the processing option to determine the default
> output extension as moved to the advanced settings. What I find odd is that
> the value type is an integer and the default values is now 0. Changing it
> to 1, seems to make the default shapefiles.
> > If exists, where can I find the enumeration for default values? this
> needs to be documented
> > Thanks,
> > Alexandre Neto
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190920/62f1cc2a/attachment.html>
More information about the QGIS-Developer mailing list
