[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Etienne Trimaille
etienne.trimaille at gmail.com
Fri Sep 20 00:21:52 PDT 2019
No, I think you can't.
People are changing the extension by editing the source code:
https://gis.stackexchange.com/a/317169/24505
Related ticket: https://github.com/qgis/QGIS/issues/28377
Alexandre, where did you find these options? I think they have been removed
a few months ago now.
Le ven. 20 sept. 2019 à 09:13, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Hi Alex,
> Thanks for your fast answer.
> Is there a way to control what happens in multi output files? Like split
> vector layer, wher you can only select a output folder.
> Thanks,
> Alex
> A sexta, 20/09/2019, 06:05, Alexander Bruy <alexander.bruy at gmail.com>
> escreveu:
>> Hi,
>> these options are not used anymore and should be removed. Correct
>> extension now
>> determined automatically from the filename for file-based outputs.
>> пт, 20 вер. 2019 о 00:02 Alexandre Neto <senhor.neto at gmail.com> пише:
>> > Hi all,
>> > I have realized that the processing option to determine the default
>> output extension as moved to the advanced settings. What I find odd is that
>> the value type is an integer and the default values is now 0. Changing it
>> to 1, seems to make the default shapefiles.
>> > If exists, where can I find the enumeration for default values? this
>> needs to be documented
>> > Thanks,
>> > Alexandre Neto
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190920/a520b79f/attachment.html>
