[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Alexander Bruy
alexander.bruy at gmail.com
Fri Sep 20 00:22:25 PDT 2019
For split vector layer and other similar algorithms output format is hardcoded
or defined by underlying 3rd party tool (e.g. WhiteBox Tools or TauDEM).
BTW, as far as I can see, this options already removed in master and probably
in 3.8 too.
пт, 20 вер. 2019 о 10:13 Alexandre Neto <senhor.neto at gmail.com> пише:
> Hi Alex,
> Thanks for your fast answer.
> Is there a way to control what happens in multi output files? Like split vector layer, wher you can only select a output folder.
> Thanks,
> Alex
> A sexta, 20/09/2019, 06:05, Alexander Bruy <alexander.bruy at gmail.com> escreveu:
>> Hi,
>> these options are not used anymore and should be removed. Correct extension now
>> determined automatically from the filename for file-based outputs.
>> пт, 20 вер. 2019 о 00:02 Alexandre Neto <senhor.neto at gmail.com> пише:
>> > Hi all,
>> > I have realized that the processing option to determine the default output extension as moved to the advanced settings. What I find odd is that the value type is an integer and the default values is now 0. Changing it to 1, seems to make the default shapefiles.
>> > If exists, where can I find the enumeration for default values? this needs to be documented
>> > Thanks,
>> > Alexandre Neto
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexander Bruy
Alexander Bruy
