[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
r.m.aguilardearchila at utwente.nl
Fri Sep 20 00:29:46 PDT 2019
Perhaps this is related to your question?
https://github.com/qgis/QGIS-Documentation/issues/3409
That was documented with https://github.com/qgis/QGIS-Documentation/pull/4144
Best,
Rosa
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> On Behalf Of Alexandre Neto
Sent: 20 September 2019 09:13
To: Alexander Bruy <alexander.bruy at gmail.com>
Cc: qgis-dev <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Hi Alex,
Thanks for your fast answer.
Is there a way to control what happens in multi output files? Like split vector layer, wher you can only select a output folder.
Thanks,
Alex
A sexta, 20/09/2019, 06:05, Alexander Bruy <alexander.bruy at gmail.com<mailto:alexander.bruy at gmail.com>> escreveu:
these options are not used anymore and should be removed. Correct extension now
determined automatically from the filename for file-based outputs.
пт, 20 вер. 2019 о 00:02 Alexandre Neto <senhor.neto at gmail.com<mailto:senhor.neto at gmail.com>> пише:
> Hi all,
> I have realized that the processing option to determine the default output extension as moved to the advanced settings. What I find odd is that the value type is an integer and the default values is now 0. Changing it to 1, seems to make the default shapefiles.
> If exists, where can I find the enumeration for default values? this needs to be documented
> Thanks,
> Alexandre Neto
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190920/92bab0d1/attachment-0001.html>
