[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Alexandre Neto
senhor.neto at gmail.com
Fri Sep 20 17:04:40 PDT 2019
Hi Rosa,
You are right it's related. The commit was this one:
https://github.com/qgis/QGIS/pull/8997
Like otters already said, the Default Output vector extensions was no
longer working. The split vector layer hardcoded output extension changed
from shp to gpkg. Although I agree with the change, there might be cases
when users really need Shapefiles (or other file formats). Therefore I
decided to play with the algorithm file and submitted a PR to allow
selecting the output format from a small dropdown menu.
https://github.com/qgis/QGIS/pull/31910
Thanks all,
Alexandre Neto
On Fri, Sep 20, 2019 at 8:29 AM r.m.aguilardearchila at utwente.nl <
r.m.aguilardearchila at utwente.nl> wrote:
> Hi,
> Perhaps this is related to your question?
> https://github.com/qgis/QGIS-Documentation/issues/3409
> That was documented with
> https://github.com/qgis/QGIS-Documentation/pull/4144
> Best,
> Rosa
> *From:* QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> *On
> Behalf Of *Alexandre Neto
> *Sent:* 20 September 2019 09:13
> *To:* Alexander Bruy <alexander.bruy at gmail.com>
> *Cc:* qgis-dev <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [QGIS-Developer] Processing - Default Output raster&vector
> Hi Alex,
> Thanks for your fast answer.
> Is there a way to control what happens in multi output files? Like split
> vector layer, wher you can only select a output folder.
> Thanks,
> Alex
> A sexta, 20/09/2019, 06:05, Alexander Bruy <alexander.bruy at gmail.com>
> escreveu:
> Hi,
> these options are not used anymore and should be removed. Correct
> extension now
> determined automatically from the filename for file-based outputs.
> пт, 20 вер. 2019 о 00:02 Alexandre Neto <senhor.neto at gmail.com> пише:
> > Hi all,
> > I have realized that the processing option to determine the default
> output extension as moved to the advanced settings. What I find odd is that
> the value type is an integer and the default values is now 0. Changing it
> to 1, seems to make the default shapefiles.
> > If exists, where can I find the enumeration for default values? this
> needs to be documented
> > Thanks,
> > Alexandre Neto
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190921/1796a09c/attachment.html>
