[QGIS-Developer] Performance issues while loading a big QGIS project
Régis Haubourg
regis.haubourg at gmail.com
Tue Sep 24 10:22:18 PDT 2019
Thanks for your feedback.
Bye!
Le mar. 24 sept. 2019 à 18:09, <Bauer.Josef at swm.de> a écrit :
> Hello Nyall, hello Régis,
> thank you for your hints. The option “Trust project when data source has
> no metadata” improved the loading time a lot. The project still needs about
> 6 minutes to load, but at least it is already an improvement. However, I
> guess, that is normal for such a large project. The plug-in “Layers menu
> from project” also looks very interesting.
> Kind regards,
> Josef
> *Von:* Régis Haubourg <regis.haubourg at gmail.com>
> *Gesendet:* Dienstag, 24. September 2019 08:30
> *An:* Nyall Dawson <nyall.dawson at gmail.com>
> *Cc:* Bauer.Josef extern IT-DS-TS <Bauer.Josef at swm.de>; QGIS Developers
> List <qgis-developer at lists.osgeo.org>
> *Betreff:* Re: [QGIS-Developer] Performance issues while loading a big
> QGIS project
> Agreed, this should speed up the loading time of layers without metadata
> (probably postgresql views mainly in your case)
> If your need is to access some layers only, I recommend the
> menu_layers_from_project plugin. It will only parse the xml but not load
> the data until you choose to import some layers into a session.
> I also experienced that lowering the network timeout can speed up ogc
> webservice layers when the service is not responding.
> Regards
> Régis
> Le mar. 24 sept. 2019 à 00:49, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
> On Tue, 24 Sep 2019 at 00:41, <Bauer.Josef at swm.de> wrote:
> > Therefore, the question is, if QGIS provides a mechanism to postpone the
> initial loading of all layers from QGIS startup to the point in time when
> we actually need the layers? I.e., the layer structure is loaded but not
> the layer data.
> There's no such existing mechanism.
> Have you experiment with the setting under project properties -- data
> sources -- "Trust project when data source has no metadata"? I believe
> that was added to assist with cases like this.
> Nyall
> > Is there a build-in QGIS mechanism that allows loading only the needed
> layers from the .qgs file and write the appropriate styles to it or is it
> planned to implement such a mechanism in QGIS?
> > Kind regards,
> > Josef
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190924/7281d4e4/attachment.html>
