[QGIS-Developer] Performance issues while loading a big QGIS project
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Sep 24 23:54:59 PDT 2019
That's a bloody huge project...
I can't fathom you need all these layers at once.
You could try to split the project in a "base" project with a minimum
set of layers and split the rest in of the layers/groups into a number
of qlr files.
And use the "QLR Browser" plugin to load/unload the different qlr files
as you need them.
I personally think this method is better than using other plugins with
similar functionality and certainly is better than loading 1080 layers
at once.
The QLR browser plugin is used in a number of Danish municipalities
which typically uses a very large number of layers in their daily use of
QGIS.
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 23-09-2019 kl. 16:34 skrev Bauer.Josef at swm.de:
> Dear QGIS developers,
> we are facing some crucial performance issues while loading a big QGIS
> project.
> The project ...
> ... has 1080 layers
> ... has 167 layer groups
> ... is heavily styled (in fact, most of the information in the .qgs
> file are stylings)
> ... has a size of 53 MB (the .gqs file)
> ... loads the data from a PostGIS database
> The main problem we are facing is, that the loading time of the .qgs
> file is between 10 and 15 Minutes (depending on the network traffic).
> We don't need all the layers which are defined in the .qgs file
> immediately. In most cases, we just need a bunch of those layers at once.
> Therefore, the question is, if QGIS provides a mechanism to postpone
> the initial loading of all layers from QGIS startup to the point in
> time when we actually need the layers? I.e., the layer structure is
> loaded but not the layer data.
> Is there a build-in QGIS mechanism that allows loading only the needed
> layers from the .qgs file and write the appropriate styles to it or is
> it planned to implement such a mechanism in QGIS?
> Kind regards,
> Josef
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190925/8e9d2fb3/attachment.html>
