[QGIS-Developer] QGIS unstable on debian testing
Richard Duivenvoorde rdmailings at duif.net
Sat Apr 11 23:37:01 PDT 2020
Hi uclaros,
I'm on master/bulseye too, and I do not encounter frequent crashes.
Is it possible that one of your plugins is creating havoc? Also because
it is with all you versions on the same machine (sharing your profile)
Maybe create a fresh profile with no plugins in it?
You are compiling against distro proj and gdal, yes?
If you encounter still crashes, you can compile 'with debug', and using
gdb maybe can debug the crash?
Regards,
On 4/11/20 1:02 AM, uclaros wrote:
> Hi,
> after some recent package updates in Debian bullseye (testing), QGIS builds
> have become unstable for me. While rendering on pan/zoom/vertex editing on a
> project with a couple of geopackage layers, QGIS may freeze completely (idle
> cpu) or crash with a dump like :
> 2020-04-09T00:00:27.315  [New LWP 122940]
> 2020-04-09T00:00:27.315  [New LWP 122941]
> 2020-04-09T00:00:27.315  [New LWP 122943]
> 2020-04-09T00:00:27.315  [New LWP 122944]
> 2020-04-09T00:00:27.315  [New LWP 122945]
> 2020-04-09T00:00:27.315  [New LWP 122946]
> 2020-04-09T00:00:27.315  [New LWP 122947]
> 2020-04-09T00:00:27.315  [New LWP 122948]
> 2020-04-09T00:00:27.315  [New LWP 122949]
> 2020-04-09T00:00:27.315  [New LWP 122950]
> 2020-04-09T00:00:27.315  [New LWP 122953]
> 2020-04-09T00:00:27.315  [New LWP 122957]
> 2020-04-09T00:00:27.315  [New LWP 122958]
> 2020-04-09T00:00:27.315  [New LWP 122959]
> 2020-04-09T00:00:51.886  [Thread debugging using libthread_db enabled]
> 2020-04-09T00:00:51.886  Using host libthread_db library
> "/lib/x86_64-linux-gnu/libthread_db.so.1".
> 2020-04-09T00:01:00.643  0x00007f62e03c4b4f in __GI___poll
> (fds=0x55bb3c41c110, nfds=7, timeout=16) at
> ../sysdeps/unix/sysv/linux/poll.c:29
> 2020-04-09T00:01:00.644  29     ../sysdeps/unix/sysv/linux/poll.c: No such
> file or directory.
> 2020-04-09T00:01:04.882  [Current thread is 1 (Thread 0x7f62d1bc6f80 (LWP
> 122933))]
> 2020-04-09T00:01:04.882  #0  0x00007f62e03c4b4f in __GI___poll
> 2020-04-09T00:01:04.882          resultvar = 18446744073709551100
> 2020-04-09T00:01:04.882          sc_cancel_oldtype = 0
> 2020-04-09T00:01:04.882  #1  0x00007f62d90f97fe in  () at
> /lib/x86_64-linux-gnu/libglib-2.0.so.0
> 2020-04-09T00:01:04.882  #2  0x00007f62d90f991f in g_main_context_iteration
> () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
> 2020-04-09T00:01:04.882  #3  0x00007f62e094e7c1 in
> QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
> () at /lib/x86_64-linux-gnu/libQt5Core.so.5
> 2020-04-09T00:01:04.882  #4  0x00007f62e08f76db in
> QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at
> 2020-04-09T00:01:04.882  #5  0x00007f62e08ff182 in QCoreApplication::exec()
> 2020-04-09T00:01:04.883  #6  0x000055bb3a6dd43c in main(int, char**)
> (argc=<optimized out>, argv=<optimized out>) at ../src/app/main.cpp:1608
> This happens to new builds, both master and older versions and the 3.10.3
> that gets installed from the debian repository.
> The recent update included proj 7.0.0 which is a major difference since the
> issues appeared.
> I was hoping to avoid building everything from source, but if I am to build
> an older proj version, what other packages should I look into rebuilding?
> Any other debian testing users having such issues?
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
