[QGIS-Developer] Failing to install QGIS-dev/nightly with osgeo4w:
Richard Duivenvoorde
rdmailings at duif.net
Sun Apr 12 05:41:02 PDT 2020
I'm failing to install QGIS-nightly through osgeo4w64 on my Windooz VM
downloaded a fresh osgeo4w-setup-x86_64
Using norbit repo I started of by installing qgis-dev (and because that
failed earlier, I started of with a clean sheet, and also added
qgis-dev-pdb)
Installed all in c:\OSGeo4W64 dir
Using 'advanced' install I ticked the following from the Desktop group:
qgis-dev 3.13.0-26
qgis-dev-pdb 3.13.0-25
After this installation I open the osgeo4w terminal and with 'o-help' I
see there is a 'qgis-dev-bin' command.
Calling that shows: Oops.... Could not load qgis_app.dll
Check C:\..\bin\qgis-dev-bin.env for correct env paths
There IS a qgis_app.dll:
c:\OSGeo4W64\apps\qgis-dev\bin\qgis_app.dll
But NOT the env file, there is a tmpl file though:
c:\OSGeo4W64\bin\qgis-dev.bat.tmpl
Ah... copying that and saving to qgis-dev.bat, then run it works!
Ah, now also running 'qgis-dev-bin' works.
So, is there a step missing? If I just install qgis-dev?
Or should I call another script (first)?
I also tried to install Package 'qgis-full-dev', but that one shows
version number 2.99.0-2 ?
Anyway, I do have a working nightly now
(https://github.com/qgis/QGIS/commit/7a9c3c621a)
But thought to let others now.
Regards,
