[QGIS-Developer] Failing to install QGIS-dev/nightly with osgeo4w:
Jürgen E. Fischer jef at norbit.de
Tue Apr 14 06:30:29 PDT 2020
Hi Richard,
On Sun, 12. Apr 2020 at 14:41:02 +0200, Richard Duivenvoorde wrote:
> After this installation I open the osgeo4w terminal and with 'o-help' I
> see there is a 'qgis-dev-bin' command.
No issues while installing?  %OSGEO4W_ROOT%\etc\postinstall\qgis-dev.bat should
have been run (and now be named qgis-dev.bat.done).
> There IS a qgis_app.dll:
> c:\OSGeo4W64\apps\qgis-dev\bin\qgis_app.dll
> But NOT the env file, there is a tmpl file though:
That should have been created by running "bin\qgis-dev.bat --postinstall" from
the postinstall batch job.
> c:\OSGeo4W64\bin\qgis-dev.bat.tmpl
> Ah... copying that and saving to qgis-dev.bat, then run it works!
And that should have been used to create qgis-dev.bat - also from postinstall.
> I also tried to install Package 'qgis-full-dev', but that one shows
> version number 2.99.0-2 ?
That package is empty, but has dependencies - eg. qgis-dev.  The version number
doesn't matter.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200414/e2639682/attachment.sig>
More information about the QGIS-Developer mailing list
