[QGIS-Developer] loading images in QGIS Viewer with RPC modelisation
GLANDUS Laurene laurene.glandus at thalesaleniaspace.com
Wed Apr 15 01:18:13 PDT 2020
Thanks for you answer.
which version of QGIS do you use and how do you know that it's displayed according to RPC ?
Best Regards
Laurène
-----Message d'origine-----
De : QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Julien Cabieces
Envoyé : mercredi 15 avril 2020 10:12
À : qgis-developer at lists.osgeo.org
Objet : Re: [QGIS-Developer] loading images in QGIS Viewer with RPC modelisation
Hello,
Last time I check, if the RPC file is in the same folder than your Pleiades image, QGIS will load it automatically when you open your Pleiades images. Your image will be displayed according to its RPC then.
I think that Gdal (used by QGIS to open the file) looks for a file starting with RPC_
Regards,
Julien
> Hello,
> I would like to load an Satellite image from the sensor Pleiades in Qgis. Linked with the image there is an RPC (rational polynomial coefficient) file which give geolocation information.
> I would like to load this image with the RPC information in the QGIS viewer.
> Has someone already try to develop something about loading an image in QGIS viewer with RPC geolocation of any satellite sensor?
> Best regards
> Laurène Glandus
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
