[QGIS-Developer] GetFeatureInfo, difference between JSON/XML
Alessandro Pasotti
apasotti at gmail.com
Sun Apr 19 06:22:41 PDT 2020
On Sun, Apr 19, 2020 at 3:13 PM Tom Palan <thomas at palan.at> wrote:
> Hi,
> could somebody please explain why the fetching of a GetFeatureInfo
> request in application/json format instead of text/xml does need to
> query the layer again to get the feature values, again?
> I am talking about qgswmsrenderer.cpp, method convertFeatureInfoToJson,
> around line 2167. The conversion to json is the only one that needs to
> re-fetch the feature data instead of using the "result" (QDomDocument)
> directly.
> Is this because we need to get the correct field types for json
> conversion instead of returning just string values? Is this a real
> necessity?
> I noticed this because a postgis layer had problems with its id-column,
> and the json request failed while the xml request worked just fine. Of
> course the id-column will be fixed, but the re-fetching of every
> feature are also means that in the best case the db-query count goes up
> from 1 to 1+<feature-cnt>.
> Thanks for your input,
> Tom
AFAICS there is no good reason, the dom document is only used to get
the layers list, if you are on it I would recommend you to skip the
line
QDomDocument result = featureInfoDocument( layers, mapSettings,
outputImage.get(), version );
in case the format is json and pass in the list of layers to render
instead of the doc to QgsRenderer::convertFeatureInfoToJson.
To give you some more context, json export format was implemented
recently, after the server refactoring that happened in 3.0, perhaps
this is the reason why it was added as another "switch" in the format
list.
Alessandro Pasotti
w3: www.itopen.it
