[QGIS-Developer] QGIS Development server - Service WMS is not	registered
    Uros Preloznik
    uros00 at gmail.com
    Mon Apr 20 00:06:58 PDT 2020
I found couple of minor issues in QGIS Server 3.10 and wanted to make some
test requests before posting issue, so it will be possible to replicate
issue.
So I build QGIS master and tried Development server, which I think is
really cool to try and test things.
For building I used this parameters
cmake -DWITH_SERVER=true -DWITH_GEOREFERENCER=false -DWITH_GRASS7=false ..
and then sudo make install
I can start development server. Output from start:
uros at Mint19:~/dev/cpp/QGIS/build_master$ ./output/bin/qgis_mapserver
qt5ct: using qt5ct plugin
QGIS Development Server listening on http://localhost:8000
CTRL+C to exit
08:58:28 INFO Server[26649]: Qgis Server Settings:
08:58:28 INFO Server[26649]:   - QGIS_OPTIONS_PATH / '' (Override the
default path for user configuration): '' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_PARALLEL_RENDERING /
'/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS
getMap request): 'false' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_MAX_THREADS /
'/qgis/max_threads' (Number of threads to use when parallel rendering is
activated): '-1' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_LOG_LEVEL / '' (Log level):
'0' (read from ENVIRONMENT_VARIABLE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_LOG_FILE / '' (Log file): ''
08:58:28 INFO Server[26649]:   - QGIS_SERVER_LOG_STDERR / ''
(Activate/Deactivate logging to stderr): '1' (read from
08:58:28 INFO Server[26649]:   - QGIS_PROJECT_FILE / '' (QGIS project
file): '' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - MAX_CACHE_LAYERS / '' (Specify the maximum
number of cached layers): '100' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_CACHE_DIRECTORY /
'/cache/directory' (Specify the cache directory):
'/home/uros/.local/share/QGIS/QGIS3/profiles/default/cache' (read from
DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_CACHE_SIZE / '/cache/size'
(Specify the cache size): '52428800' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
'/locale/showGroupSeparator' (Show group (thousands) separator): 'false'
08:58:28 INFO Server[26649]:   - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
'/locale/userLocale' (Override system locale): 'en_US' (read from INI_FILE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_WMS_MAX_HEIGHT /
'/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of
this and the project configuration is used.): '-1' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_WMS_MAX_WIDTH /
'/qgis/max_wms_width' (Maximum width for a WMS request. The most
conservative between this and the project one is used): '-1' (read from
DEFAULT_VALUE)
08:58:28 INFO Server[26649]:   - QGIS_SERVER_API_RESOURCES_DIRECTORY /
'/qgis/server_api_resources_directory' (Base directory where HTML templates
and static assets (e.g. images, js and css files) are searched for):
'/home/uros/dev/cpp/QGIS/build-master/output/share/qgis/resources/server/api'
08:58:28 INFO Server[26649]:   - QGIS_SERVER_API_WFS3_MAX_LIMIT /
'/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features
request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
08:58:28 INFO Server[26649]: Ini file used to initialize settings:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
08:58:28 INFO Server[26649]: cacheDirectory:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/cache/
08:58:28 INFO Server[26649]: maximumCacheSize: 52428800
08:58:28 INFO Server[26649]: Prefix  PATH:
08:58:28 INFO Server[26649]: Plugin  PATH:
/home/uros/dev/cpp/QGIS/build-master/output/lib/qgis/plugins
08:58:28 INFO Server[26649]: PkgData PATH:
08:58:28 INFO Server[26649]: User DB PATH:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis.db
08:58:28 INFO Server[26649]: Auth DB PATH:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
08:58:28 INFO Server[26649]: SVG PATHS:
/home/uros/dev/cpp/QGIS/build-master/output/share/qgis/svg/:/home/uros/.local/share/QGIS/QGIS3/profiles/default/svg/
08:58:28 WARNING No Authentication Methods[26649]: No QGIS auth method
plugins found in:
No authentication methods can be used. Check your QGIS installation
08:58:28 INFO Server[26649]: Server initialized
08:58:28 INFO
/home/uros/dev/cpp/QGIS/src/server/qgsserverplugins.cpp[26649]: load
library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython (3.13.0)
08:58:28 WARNING [26649]: Couldn't load Python support library: Cannot load
library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython:
(/home/uros/dev/cpp/QGIS/build-master/output/lib/libqgispython.so: cannot
open shared object file: No such file or directory)
08:58:28 INFO Server[26649]: No server python plugins are available
Problem is when I send some requests, like:
http://localhost:8000/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
Project is opened, but I get Service WMS is not registered. I know this is
case sensitive, but it's actually whatever I give in SERVICE parameter is
not registered.
08:59:34 INFO Server[26649]:
MAP:/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
08:59:34 INFO Server[26649]: REQUEST:GetCapabilities
08:59:34 INFO Server[26649]: SERVICE:WMS
08:59:34 INFO Server[26649]: VERSION:1.3.0
Logged warning: Loading a file that was saved with an older version of qgis
(saved in 3.2.0-Bonn, loaded in 3.13.0-Master). Problems may occur.
08:59:35 WARNING [26649]: Service WMS is not registered
08:59:35 WARNING Server[26649]: <ServiceExceptionReport xmlns="
http://www.opengis.net/ogc" version="1.3.0">
 <ServiceException code="Service configuration error">Service unknown or
unsupported</ServiceException>
</ServiceExceptionReport>
Any ideas what's wrong, something with my build?
I will try now with standard QGIS Server setup and see if it's working.
best regards
Uroš
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200420/f497c700/attachment.html>
