[QGIS-Developer] QGIS Development server - Service WMS is not registered
Alessandro Pasotti apasotti at gmail.com
Mon Apr 20 00:43:38 PDT 2020
On Mon, Apr 20, 2020 at 9:07 AM Uros Preloznik <uros00 at gmail.com> wrote:
> Hi,
> I found couple of minor issues in QGIS Server 3.10 and wanted to make some test requests before posting issue, so it will be possible to replicate issue.
> So I build QGIS master and tried Development server, which I think is really cool to try and test things.
> For building I used this parameters
> cmake -DWITH_SERVER=true -DWITH_GEOREFERENCER=false -DWITH_GRASS7=false ..
> and then sudo make install
this is normally not required, you can install your build in your user
space with no sudo.
> I can start development server. Output from start:
> uros at Mint19:~/dev/cpp/QGIS/build_master$ ./output/bin/qgis_mapserver
I'm probably missing something but you are NOT launching the binary
you have installed (globally as root)  a few lines above.
> qt5ct: using qt5ct plugin
> QGIS Development Server listening on http://localhost:8000
> CTRL+C to exit
> 08:58:28 INFO Server[26649]: Qgis Server Settings:
> 08:58:28 INFO Server[26649]:   - QGIS_OPTIONS_PATH / '' (Override the default path for user configuration): '' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_PARALLEL_RENDERING / '/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS getMap request): 'false' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_MAX_THREADS / '/qgis/max_threads' (Number of threads to use when parallel rendering is activated): '-1' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_LOG_LEVEL / '' (Log level): '0' (read from ENVIRONMENT_VARIABLE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_LOG_FILE / '' (Log file): '' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_LOG_STDERR / '' (Activate/Deactivate logging to stderr): '1' (read from ENVIRONMENT_VARIABLE)
> 08:58:28 INFO Server[26649]:   - QGIS_PROJECT_FILE / '' (QGIS project file): '' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - MAX_CACHE_LAYERS / '' (Specify the maximum number of cached layers): '100' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_CACHE_DIRECTORY / '/cache/directory' (Specify the cache directory): '/home/uros/.local/share/QGIS/QGIS3/profiles/default/cache' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_CACHE_SIZE / '/cache/size' (Specify the cache size): '52428800' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_SHOW_GROUP_SEPARATOR / '/locale/showGroupSeparator' (Show group (thousands) separator): 'false' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE / '/locale/userLocale' (Override system locale): 'en_US' (read from INI_FILE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_WMS_MAX_HEIGHT / '/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of this and the project configuration is used.): '-1' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_WMS_MAX_WIDTH / '/qgis/max_wms_width' (Maximum width for a WMS request. The most conservative between this and the project one is used): '-1' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_API_RESOURCES_DIRECTORY / '/qgis/server_api_resources_directory' (Base directory where HTML templates and static assets (e.g. images, js and css files) are searched for): '/home/uros/dev/cpp/QGIS/build-master/output/share/qgis/resources/server/api' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]:   - QGIS_SERVER_API_WFS3_MAX_LIMIT / '/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: Ini file used to initialize settings: /home/uros/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
> 08:58:28 INFO Server[26649]: cacheDirectory: /home/uros/.local/share/QGIS/QGIS3/profiles/default/cache/
> 08:58:28 INFO Server[26649]: maximumCacheSize: 52428800
> 08:58:28 INFO Server[26649]: Prefix  PATH: /home/uros/dev/cpp/QGIS/build-master/output
> 08:58:28 INFO Server[26649]: Plugin  PATH: /home/uros/dev/cpp/QGIS/build-master/output/lib/qgis/plugins
> 08:58:28 INFO Server[26649]: PkgData PATH: /home/uros/dev/cpp/QGIS/build-master/output/share/qgis
> 08:58:28 INFO Server[26649]: User DB PATH: /home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis.db
> 08:58:28 INFO Server[26649]: Auth DB PATH: /home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
> 08:58:28 INFO Server[26649]: SVG PATHS: /home/uros/dev/cpp/QGIS/build-master/output/share/qgis/svg/:/home/uros/.local/share/QGIS/QGIS3/profiles/default/svg/
> 08:58:28 WARNING No Authentication Methods[26649]: No QGIS auth method plugins found in:
> No authentication methods can be used. Check your QGIS installation
> 08:58:28 INFO Server[26649]: Server initialized
> 08:58:28 INFO /home/uros/dev/cpp/QGIS/src/server/qgsserverplugins.cpp[26649]: load library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython (3.13.0)
> 08:58:28 WARNING [26649]: Couldn't load Python support library: Cannot load library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython: (/home/uros/dev/cpp/QGIS/build-master/output/lib/libqgispython.so: cannot open shared object file: No such file or directory)
> 08:58:28 INFO Server[26649]: No server python plugins are available
> Problem is when I send some requests, like:
> http://localhost:8000/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
> Project is opened, but I get Service WMS is not registered. I know this is case sensitive, but it's actually whatever I give in SERVICE parameter is not registered.
> 08:59:34 INFO Server[26649]: MAP:/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
> 08:59:34 INFO Server[26649]: REQUEST:GetCapabilities
> 08:59:34 INFO Server[26649]: SERVICE:WMS
> 08:59:34 INFO Server[26649]: VERSION:1.3.0
> Logged warning: Loading a file that was saved with an older version of qgis (saved in 3.2.0-Bonn, loaded in 3.13.0-Master). Problems may occur.
> 08:59:35 WARNING [26649]: Service WMS is not registered
> 08:59:35 WARNING Server[26649]: <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" version="1.3.0">
>  <ServiceException code="Service configuration error">Service unknown or unsupported</ServiceException>
> </ServiceExceptionReport>
> Any ideas what's wrong, something with my build?
There is definitely something wrong with your build (probably the
paths), custom builds use custom paths and QGIS server needs to know
from where to load its services (WMS, WFS etc.) and APIs (OAPIF/WFS3).
The default path is /usr on Linux, but in your case I see that the
prefix path is correctly set to
/home/uros/dev/cpp/QGIS/build-master/output where you should find
lib/qgis/server/libwms.so & C.
But your configuration is totally broken: no auth plugins, no Python
and no modules (you should see them listed in the server logs but they
are not there), my output is for example:
"Loading native module
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgis/server/libdummy.so"
../src/server/services/DummyService/dummy.cpp:51 : (registerSelf)
[1ms] SampleModule::registerSelf called
../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms]
2020-04-20T09:42:12 Server[0] Adding service SampleService 1.0
09:42:12 INFO Server[30406]: Adding service SampleService 1.0
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgis/server/libwcs.so"
../src/server/services/wcs/qgswcs.cpp:118 : (registerSelf) [1ms]
WCSModule::registerSelf called
2020-04-20T09:42:12 Server[0] Adding service WCS 1.0.0
09:42:12 INFO Server[30406]: Adding service WCS 1.0.0
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgis/server/libwfs.so"
../src/server/services/wfs/qgswfs.cpp:142 : (registerSelf) [2ms]
WFSModule::registerSelf called
2020-04-20T09:42:12 Server[0] Adding service WFS 1.1.0
09:42:12 INFO Server[30406]: Adding service WFS 1.1.0
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgis/server/libwfs3.so"
../src/core/qgsmessagelog.cpp:29 : (logMessage) [1ms]
2020-04-20T09:42:12 [1] Adding API OGC WFS3 (Draft)
09:42:12 WARNING [30406]: Adding API OGC WFS3 (Draft)
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgis/server/libwms.so"
../src/server/services/wms/qgswms.cpp:178 : (registerSelf) [1ms]
WMSModule::registerSelf called
2020-04-20T09:42:12 Server[0] Adding service WMS 1.3.0
09:42:12 INFO Server[30406]: Adding service WMS 1.3.0
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgis/server/libwmts.so"
../src/server/services/wmts/qgswmts.cpp:116 : (registerSelf) [1ms]
WMTSModule::registerSelf called
2020-04-20T09:42:12 Server[0] Adding service WMTS 1.0.0
09:42:12 INFO Server[30406]: Adding service WMTS 1.0.0
2020-04-20T09:42:12 Server[0] Server initialized
09:42:12 INFO Server[30406]: Server initialized
2020-04-20T09:42:12 ../src/server/qgsserverplugins.cpp[0] load library
/home/xxxxx/dev/QGIS/build-local-qt5132-release_gdal3/output/lib/qgispython
(3.13.0)
09:42:12 INFO ../src/server/qgsserverplugins.cpp[30406]: load library
(3.13.0)
2020-04-20T09:42:12 ../src/server/qgsserverplugins.cpp[0] Python
support library loaded successfully.
09:42:12 INFO ../src/server/qgsserverplugins.cpp[30406]: Python
../src/server/qgsserverplugins.cpp:74 : (initPlugins) [0ms] Python
support library's instance() symbol resolved.
../src/server/qgsserverplugins.cpp:80 : (initPlugins) [308ms] Python
support ENABLED :-)
../src/core/qgsmessagelog.cpp:29 : (logMessage) [8ms]
2020-04-20T09:42:13 Server[0] No server python plugins are available
09:42:13 INFO Server[30406]: No server python plugins are available
You should check your paths.
What I do is:
- set CMAKE_PREFIX_PATH in cmake to the build directory
- never make install, just make
- prepare the environment by setting QGIS_PREFIX_PATH to the "output"
directory under your build directory (so: ${CMAKE_PREFIX_PATH}/output)
- run qgis binaries located in the ${QGIS_PREFIX_PATH}/bin directory
from the script that sets the correct environment
Hope this helps.
Alessandro Pasotti
w3:   www.itopen.it
More information about the QGIS-Developer mailing list
