[QGIS-Developer] QGIS Development server - Service WMS is not registered
Jorge Gustavo Rocha
jgr at di.uminho.pt
Mon Apr 20 00:45:54 PDT 2020
Hi Uroš,
QGIS Server is complaining about the missing
output/lib/libqgispython.so. That library should be generated by your
compilation. Can you check the compilation output? Make sure that
library exist (and the other libraries). You should have:
ls output/lib/lib*.0
output/lib/libqgis_analysis.so.3.13.0 output/lib/libqgis_core.so.3.13.0
output/lib/libqgis_native.so.3.13.0 output/lib/libqgis_server.so.3.13.0
output/lib/libqgis_app.so.3.13.0 output/lib/libqgis_gui.so.3.13.0
output/lib/libqgispython.so.3.13.0
I don't know if that is the problem, but there is something missing in
your build step.
Regards,
Jorge Gustavo
On 20/04/20 08:06, Uros Preloznik wrote:
> Hi,
> I found couple of minor issues in QGIS Server 3.10 and wanted to make
> some test requests before posting issue, so it will be possible to
> replicate issue.
> So I build QGIS master and tried Development server, which I think is
> really cool to try and test things.
> For building I used this parameters
> cmake -DWITH_SERVER=true -DWITH_GEOREFERENCER=false -DWITH_GRASS7=false ..
> and then sudo make install
> I can start development server. Output from start:
> uros at Mint19:~/dev/cpp/QGIS/build_master$ ./output/bin/qgis_mapserver
> qt5ct: using qt5ct plugin
> QGIS Development Server listening on http://localhost:8000
> CTRL+C to exit
> 08:58:28 INFO Server[26649]: Qgis Server Settings:
> 08:58:28 INFO Server[26649]: - QGIS_OPTIONS_PATH / '' (Override the
> default path for user configuration): '' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_PARALLEL_RENDERING /
> '/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for
> WMS getMap request): 'false' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_MAX_THREADS /
> '/qgis/max_threads' (Number of threads to use when parallel rendering is
> activated): '-1' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_LOG_LEVEL / '' (Log level):
> '0' (read from ENVIRONMENT_VARIABLE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_LOG_FILE / '' (Log file):
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_LOG_STDERR / ''
> (Activate/Deactivate logging to stderr): '1' (read from
> 08:58:28 INFO Server[26649]: - QGIS_PROJECT_FILE / '' (QGIS project
> file): '' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - MAX_CACHE_LAYERS / '' (Specify the
> maximum number of cached layers): '100' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_CACHE_DIRECTORY /
> '/cache/directory' (Specify the cache directory):
> '/home/uros/.local/share/QGIS/QGIS3/profiles/default/cache' (read from
> DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_CACHE_SIZE / '/cache/size'
> (Specify the cache size): '52428800' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
> '/locale/showGroupSeparator' (Show group (thousands) separator): 'false'
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
> '/locale/userLocale' (Override system locale): 'en_US' (read from INI_FILE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_WMS_MAX_HEIGHT /
> '/qgis/max_wms_height' (Maximum height for a WMS request. The lower one
> of this and the project configuration is used.): '-1' (read from
> DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_WMS_MAX_WIDTH /
> '/qgis/max_wms_width' (Maximum width for a WMS request. The most
> conservative between this and the project one is used): '-1' (read from
> DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_API_RESOURCES_DIRECTORY /
> '/qgis/server_api_resources_directory' (Base directory where HTML
> templates and static assets (e.g. images, js and css files) are searched
> for):
> '/home/uros/dev/cpp/QGIS/build-master/output/share/qgis/resources/server/api'
> 08:58:28 INFO Server[26649]: - QGIS_SERVER_API_WFS3_MAX_LIMIT /
> '/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a
> features request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
> 08:58:28 INFO Server[26649]: Ini file used to initialize settings:
> /home/uros/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
> 08:58:28 INFO Server[26649]: cacheDirectory:
> /home/uros/.local/share/QGIS/QGIS3/profiles/default/cache/
> 08:58:28 INFO Server[26649]: maximumCacheSize: 52428800
> 08:58:28 INFO Server[26649]: Prefix PATH:
> 08:58:28 INFO Server[26649]: Plugin PATH:
> /home/uros/dev/cpp/QGIS/build-master/output/lib/qgis/plugins
> 08:58:28 INFO Server[26649]: PkgData PATH:
> 08:58:28 INFO Server[26649]: User DB PATH:
> /home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis.db
> 08:58:28 INFO Server[26649]: Auth DB PATH:
> /home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
> 08:58:28 INFO Server[26649]: SVG PATHS:
> /home/uros/dev/cpp/QGIS/build-master/output/share/qgis/svg/:/home/uros/.local/share/QGIS/QGIS3/profiles/default/svg/
> 08:58:28 WARNING No Authentication Methods[26649]: No QGIS auth method
> plugins found in:
> No authentication methods can be used. Check your QGIS installation
> 08:58:28 INFO Server[26649]: Server initialized
> 08:58:28 INFO
> /home/uros/dev/cpp/QGIS/src/server/qgsserverplugins.cpp[26649]: load
> library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython (3.13.0)
> 08:58:28 WARNING [26649]: Couldn't load Python support library: Cannot
> load library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython:
> (/home/uros/dev/cpp/QGIS/build-master/output/lib/libqgispython.so:
> cannot open shared object file: No such file or directory)
> 08:58:28 INFO Server[26649]: No server python plugins are available
> Problem is when I send some requests, like:
> http://localhost:8000/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
> Project is opened, but I get Service WMS is not registered. I know this
> is case sensitive, but it's actually whatever I give in SERVICE
> parameter is not registered.
> 08:59:34 INFO Server[26649]:
> MAP:/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
> 08:59:34 INFO Server[26649]: REQUEST:GetCapabilities
> 08:59:34 INFO Server[26649]: SERVICE:WMS
> 08:59:34 INFO Server[26649]: VERSION:1.3.0
> Logged warning: Loading a file that was saved with an older version of
> qgis (saved in 3.2.0-Bonn, loaded in 3.13.0-Master). Problems may occur.
> 08:59:35 WARNING [26649]: Service WMS is not registered
> 08:59:35 WARNING Server[26649]: <ServiceExceptionReport
> xmlns="http://www.opengis.net/ogc" version="1.3.0">
> <ServiceException code="Service configuration error">Service unknown or
> unsupported</ServiceException>
> </ServiceExceptionReport>
> Any ideas what's wrong, something with my build?
> I will try now with standard QGIS Server setup and see if it's working.
> best regards
> Uroš
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
