[QGIS-Developer] QGIS Development server - Service WMS is not registered
Uros Preloznik
uros00 at gmail.com
Mon Apr 20 01:07:11 PDT 2020
Thanks for responding and sorry for the mess. I tried again without
install, just "make" so I'm only using output directory from build_master.
So this now works. I understand I need only build folder so installing was
just messing everything. Response from development server is now
uros at Mint19:~/dev/cpp/QGIS/build_master$ ./output/bin/qgis_mapserver
qt5ct: using qt5ct plugin
QGIS Development Server listening on http://localhost:8000
CTRL+C to exit
09:51:12 INFO Server[15333]: Qgis Server Settings:
09:51:12 INFO Server[15333]: - QGIS_OPTIONS_PATH / '' (Override the
default path for user configuration): '' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_PARALLEL_RENDERING /
'/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS
getMap request): 'false' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_MAX_THREADS /
'/qgis/max_threads' (Number of threads to use when parallel rendering is
activated): '-1' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_LOG_LEVEL / '' (Log level):
'0' (read from ENVIRONMENT_VARIABLE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_LOG_FILE / '' (Log file): ''
09:51:12 INFO Server[15333]: - QGIS_SERVER_LOG_STDERR / ''
(Activate/Deactivate logging to stderr): '1' (read from
09:51:12 INFO Server[15333]: - QGIS_PROJECT_FILE / '' (QGIS project
file): '' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - MAX_CACHE_LAYERS / '' (Specify the maximum
number of cached layers): '100' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_CACHE_DIRECTORY /
'/cache/directory' (Specify the cache directory):
'/home/uros/.local/share/QGIS/QGIS3/profiles/default/cache' (read from
DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_CACHE_SIZE / '/cache/size'
(Specify the cache size): '52428800' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
'/locale/showGroupSeparator' (Show group (thousands) separator): 'false'
09:51:12 INFO Server[15333]: - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
'/locale/userLocale' (Override system locale): 'en_US' (read from INI_FILE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_WMS_MAX_HEIGHT /
'/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of
this and the project configuration is used.): '-1' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_WMS_MAX_WIDTH /
'/qgis/max_wms_width' (Maximum width for a WMS request. The most
conservative between this and the project one is used): '-1' (read from
DEFAULT_VALUE)
09:51:12 INFO Server[15333]: - QGIS_SERVER_API_RESOURCES_DIRECTORY /
'/qgis/server_api_resources_directory' (Base directory where HTML templates
and static assets (e.g. images, js and css files) are searched for):
'/home/uros/dev/cpp/QGIS/build_master/output/data/resources/server/api'
09:51:12 INFO Server[15333]: - QGIS_SERVER_API_WFS3_MAX_LIMIT /
'/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features
request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
09:51:12 INFO Server[15333]: Ini file used to initialize settings:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
09:51:12 INFO Server[15333]: cacheDirectory:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/cache/
09:51:12 INFO Server[15333]: maximumCacheSize: 52428800
09:51:13 INFO Server[15333]: Prefix PATH:
09:51:13 INFO Server[15333]: Plugin PATH:
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/plugins
09:51:13 INFO Server[15333]: PkgData PATH:
09:51:13 INFO Server[15333]: User DB PATH:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis.db
09:51:13 INFO Server[15333]: Auth DB PATH:
/home/uros/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
09:51:13 INFO Server[15333]: SVG PATHS:
/home/uros/dev/cpp/QGIS/build_master/output/data/svg/:/home/uros/.local/share/QGIS/QGIS3/profiles/default/svg/
"Loading native module
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/server/libdummy.so"
09:51:13 INFO Server[15333]: Adding service SampleService 1.0
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/server/libwcs.so"
09:51:13 INFO Server[15333]: Adding service WCS 1.0.0
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/server/libwfs.so"
09:51:13 INFO Server[15333]: Adding service WFS 1.1.0
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/server/libwfs3.so"
09:51:14 WARNING [15333]: Adding API OGC WFS3 (Draft)
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/server/libwms.so"
09:51:14 INFO Server[15333]: Adding service WMS 1.3.0
/home/uros/dev/cpp/QGIS/build_master/output/lib/qgis/server/libwmts.so"
09:51:14 INFO Server[15333]: Adding service WMTS 1.0.0
09:51:14 INFO Server[15333]: Server initialized
09:51:14 INFO
/home/uros/dev/cpp/QGIS/src/server/qgsserverplugins.cpp[15333]: load
library /home/uros/dev/cpp/QGIS/build_master/output/lib/qgispython (3.13.0)
09:51:14 INFO
/home/uros/dev/cpp/QGIS/src/server/qgsserverplugins.cpp[15333]: Python
support library loaded successfully.
09:51:16 INFO Server[15333]: No server python plugins are available
V V pon., 20. apr. 2020 ob 09:46 je oseba Jorge Gustavo Rocha <
jgr at di.uminho.pt> napisala:
> Hi Uroš,
> QGIS Server is complaining about the missing
> output/lib/libqgispython.so. That library should be generated by your
> compilation. Can you check the compilation output? Make sure that
> library exist (and the other libraries). You should have:
> ls output/lib/lib*.0
> output/lib/libqgis_analysis.so.3.13.0 output/lib/libqgis_core.so.3.13.0
> output/lib/libqgis_native.so.3.13.0 output/lib/libqgis_server.so.3.13.0
> output/lib/libqgis_app.so.3.13.0 output/lib/libqgis_gui.so.3.13.0
> output/lib/libqgispython.so.3.13.0
> I don't know if that is the problem, but there is something missing in
> your build step.
> Regards,
> Jorge Gustavo
> On 20/04/20 08:06, Uros Preloznik wrote:
> > Hi,
> > I found couple of minor issues in QGIS Server 3.10 and wanted to make
> > some test requests before posting issue, so it will be possible to
> > replicate issue.
> > So I build QGIS master and tried Development server, which I think is
> > really cool to try and test things.
> > For building I used this parameters
> > cmake -DWITH_SERVER=true -DWITH_GEOREFERENCER=false -DWITH_GRASS7=false
> > and then sudo make install
> > I can start development server. Output from start:
> > CTRL+C to exit
> > 08:58:28 INFO Server[26649]: Qgis Server Settings:
> > 08:58:28 INFO Server[26649]: - QGIS_OPTIONS_PATH / '' (Override the
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_PARALLEL_RENDERING /
> > WMS getMap request): 'false' (read from DEFAULT_VALUE)
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_MAX_THREADS /
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_LOG_LEVEL / '' (Log level):
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_LOG_FILE / '' (Log file):
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_LOG_STDERR / ''
> > 08:58:28 INFO Server[26649]: - QGIS_PROJECT_FILE / '' (QGIS project
> > 08:58:28 INFO Server[26649]: - MAX_CACHE_LAYERS / '' (Specify the
> > maximum number of cached layers): '100' (read from DEFAULT_VALUE)
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_CACHE_DIRECTORY /
> > DEFAULT_VALUE)
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_CACHE_SIZE / '/cache/size'
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
> INI_FILE)
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_WMS_MAX_HEIGHT /
> > of this and the project configuration is used.): '-1' (read from
> > DEFAULT_VALUE)
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_WMS_MAX_WIDTH /
> > DEFAULT_VALUE)
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_API_RESOURCES_DIRECTORY /
> > templates and static assets (e.g. images, js and css files) are searched
> > for):
> '/home/uros/dev/cpp/QGIS/build-master/output/share/qgis/resources/server/api'
> > 08:58:28 INFO Server[26649]: - QGIS_SERVER_API_WFS3_MAX_LIMIT /
> > features request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
> > 08:58:28 INFO Server[26649]: Ini file used to initialize settings:
> > 08:58:28 INFO Server[26649]: cacheDirectory:
> > 08:58:28 INFO Server[26649]: maximumCacheSize: 52428800
> > 08:58:28 INFO Server[26649]: Prefix PATH:
> > 08:58:28 INFO Server[26649]: Plugin PATH:
> > /home/uros/dev/cpp/QGIS/build-master/output/lib/qgis/plugins
> > 08:58:28 INFO Server[26649]: PkgData PATH:
> > 08:58:28 INFO Server[26649]: User DB PATH:
> > 08:58:28 INFO Server[26649]: Auth DB PATH:
> > 08:58:28 INFO Server[26649]: SVG PATHS:
> /home/uros/dev/cpp/QGIS/build-master/output/share/qgis/svg/:/home/uros/.local/share/QGIS/QGIS3/profiles/default/svg/
> > 08:58:28 WARNING No Authentication Methods[26649]: No QGIS auth method
> > plugins found in:
> > No authentication methods can be used. Check your QGIS installation
> > 08:58:28 INFO Server[26649]: Server initialized
> > 08:58:28 INFO
> > /home/uros/dev/cpp/QGIS/src/server/qgsserverplugins.cpp[26649]: load
> > library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython
> (3.13.0)
> > 08:58:28 WARNING [26649]: Couldn't load Python support library: Cannot
> > load library /home/uros/dev/cpp/QGIS/build-master/output/lib/qgispython:
> > (/home/uros/dev/cpp/QGIS/build-master/output/lib/libqgispython.so:
> > cannot open shared object file: No such file or directory)
> > 08:58:28 INFO Server[26649]: No server python plugins are available
> > Problem is when I send some requests, like:
> http://localhost:8000/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
> > Project is opened, but I get Service WMS is not registered. I know this
> > is case sensitive, but it's actually whatever I give in SERVICE
> > parameter is not registered.
> > 08:59:34 INFO Server[26649]:
> MAP:/home/uros/dev/cpp/QGIS/tests/testdata/qgis_server_project/project.qgs
> > 08:59:34 INFO Server[26649]: REQUEST:GetCapabilities
> > 08:59:34 INFO Server[26649]: SERVICE:WMS
> > 08:59:34 INFO Server[26649]: VERSION:1.3.0
> > Logged warning: Loading a file that was saved with an older version of
> > qgis (saved in 3.2.0-Bonn, loaded in 3.13.0-Master). Problems may occur.
> > 08:59:35 WARNING [26649]: Service WMS is not registered
> > 08:59:35 WARNING Server[26649]: <ServiceExceptionReport
> > xmlns="http://www.opengis.net/ogc" version="1.3.0">
> > <ServiceException code="Service configuration error">Service unknown or
> > unsupported</ServiceException>
> > </ServiceExceptionReport>
> > Any ideas what's wrong, something with my build?
> > I will try now with standard QGIS Server setup and see if it's working.
> > best regards
> > Uroš
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200420/afda6ff5/attachment-0001.html>
