[QGIS-Developer] Server manual
Régis Haubourg regis.haubourg at gmail.com
Mon Apr 20 12:43:18 PDT 2020
Well,
Hard question depending a lot on your connection use cases. From the
benchmark E have been doing in production, NGINX seems to be better in most
situations.
I never tested caddy though.
Best
Régis
Le lun. 20 avr. 2020 à 20:49, Werner Macho <werner.macho at gmail.com> a
écrit :
> Hi Marco,
> Thanks for the hint with qgisserver-caddy I am going to take a look at
> it ASAP.
> And of course mod-fcgi in apache is available.
> The question is: which way is the fastest and uses the least
> ressources. So I wanted to try different webserver with different ways
> of starting qgisserver.
> There must be a reason why fastcgi and spawn-cgi and some others exist
> regards
> Werner
> On Mon, 2020-04-20 at 12:44 +0200, Marco Bernasocchi wrote:
> > Hi all
> > On 17.04.20 14:49, Paolo Cavallini wrote:
> > > Hi Werner,
> > > Il 17/04/20 14:45, werner.macho at gmail.com ha scritto:
> > > > Hi Paolo,
> > > > Thanks a lot, I overlooked that small part,
> > > so you confirm the current situation _is_confusing ;)
> > I agree it is :)
> > and honestly I think setting up a qgis server is not something many
> > people do. and the one who do, are probably ok with the language in
> > the user manual.
> > > > but as far as I see it
> > > > covers "only" nginx.
> > > do you need spawn-fcgi for apache?
> > no you don't. apache has it's own mod_fcgi
> > werner, my last deployment was done using caddy server, super neat
> > https://github.com/opengisch/qgisserver-caddy/
> > Cheers Marco
> > > cheers
> > Marco Bernasocchi
> > OPENGIS.ch CEO
> > QGIS.org Co-chair
> > marco at opengis.ch
> > +41 (0)79 467 24 70
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200420/665cf3c2/attachment.html>
More information about the QGIS-Developer mailing list
