[QGIS-Developer] get postgres connection from layer
Didier Peeters
dpeeter1 at ulb.ac.be
Wed Apr 29 14:19:10 PDT 2020
Hi Roberto,
I had the same problem and found the solution here : https://gis.stackexchange.com/questions/318635/getting-active-postgresql-connection-username-when-stored-through-authentication/343182#343182 <https://gis.stackexchange.com/questions/318635/getting-active-postgresql-connection-username-when-stored-through-authentication/343182#343182>
HTH,
Didier
> Le 29 avr. 2020 à 20:50, Poltini Roberto <Roberto.Poltini at gruppoiren.it> a écrit :
> Hi All,
> is it possible to have the postgres connection used by a vector layer using python with qgis 3 ?
> In qgis 2 I read the layer connection properties where I found login and password.
> A simple example to create a postgres connection used by a vector layer:
> import psycopg2
> conn = psycopg2.connect(layer.dataProvider().dataSourceUri())
> Now in layer.dataProvider().dataSourceUri() I find authConfigId property instead of login and password but I don’t know how to use it.
> This is because the new authorization system in qgis which permits to avoid to write login and password in the qgis project file.
> Thank you for help
> Roberto Poltini
> Per essere informati sulle novità del Gruppo Iren, vi invitiamo a registrarvi alla nostra mailing list, all’indirizzo "http://www.gruppoiren.it/" <http://www.gruppoiren.it/> .
> È possibile, inoltre, avanzare nuove idee e progetti per il territorio e seguire quelli già attivi nei Comitati Territoriali del Gruppo Iren, consultando "http://www.Irencollabora.it" <http://www.irencollabora.it/>
> You can also suggest new ideas and initiatives for the territory and view those already active in the Iren Group Territorial Committees "http://www.Irencollabora.it" <http://www.irencollabora.it/>
> Le informazioni contenute nella presente comunicazione e i relativi allegati possono essere riservate e sono, comunque, destinate esclusivamente alle persone o alla Società sopraindicati. La diffusione, distribuzione e/o copiatura del documento trasmesso da parte di qualsiasi soggetto diverso dal destinatario è proibita, sia ai sensi dell’art. 616 c.p. , che ai sensi del D.Lgs. n. 196/2003. Se avete ricevuto questo messaggio per errore, vi preghiamo di distruggerlo e di informare immediatamente il mittente.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200429/81167552/attachment.html>
