[QGIS-Developer] Problem with plugin upload
Jorge Gustavo Rocha
jgr at di.uminho.pt
Mon Dec 7 02:30:53 PST 2020
Hi Joona,
Can you share a link to your zip file? It would help to see the exact
contents you are trying to upload.
Regards,
Jorge Gustavo
Às 10:27 de 07/12/20, Joona Laine escreveu:
> Hello Folks!
> I noticed that there might be a problem with QGIS plugin repository
> while uploading plugins. I tried to add a new version to a plugin
> (FMI2QGIS <https://plugins.qgis.org/plugins/FMI2QGIS/>) first via
> qgis-plugin-ci <https://github.com/opengisch/qgis-plugin-ci> and then
> manually on web page, but both methods failed with error messages:
> <Fault 1: "File upload must be a valid QGIS Python plugin compressed
> archive. For security reasons, zip file cannot contain '.git' directory">
> and
> "There were errors reding plugin package (please check also your
> plugin's metadata). For security reasons, zip file cannot contain '.git'
> directory".
> I double checked the metadata.txt file and made sure that there were no
> .git -directory in the zip file but still the problem persisted. I even
> tried to upload the previous version again with a different version
> number to see if the problem might lie in the plugin upload process
> instead and I couldn't upload that one either.
> Thanks!
> Best regards,
> Joona Laine, Gispo Ltd.
> <http://www.gispo.fi/>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
