[QGIS-Developer] Problem with plugin upload
Joona Laine joona at gispo.fi
Mon Dec 7 02:37:59 PST 2020
Hi Jorge!
Thanks for the fast reply! Here
<https://github.com/GispoCoding/FMI2QGIS/releases/download/0.1.1/FMI2QGIS.0.1.1.zip>
is a link to the zip file I tried originally (version 0.1.1) and here
<https://github.com/GispoCoding/FMI2QGIS/releases/download/0.1.0/FMI2QGIS.0.1.0.zip>
is a link to the initial release zip file (version 0.1.0) that I uploaded
successfully on 1st December.
-Joona
<http://www.gispo.fi/>
On Mon, 7 Dec 2020 at 12:31, Jorge Gustavo Rocha <jgr at di.uminho.pt> wrote:
> Hi Joona,
> Can you share a link to your zip file? It would help to see the exact
> contents you are trying to upload.
> Regards,
> Jorge Gustavo
> Às 10:27 de 07/12/20, Joona Laine escreveu:
> > Hello Folks!
> > I noticed that there might be a problem with QGIS plugin repository
> > while uploading plugins. I tried to add a new version to a plugin
> > (FMI2QGIS <https://plugins.qgis.org/plugins/FMI2QGIS/>) first via
> > qgis-plugin-ci <https://github.com/opengisch/qgis-plugin-ci> and then
> > manually on web page, but both methods failed with error messages:
> > <Fault 1: "File upload must be a valid QGIS Python plugin compressed
> > archive. For security reasons, zip file cannot contain '.git' directory">
> > and
> >  "There were errors reding plugin package (please check also your
> > plugin's metadata). For security reasons, zip file cannot contain '.git'
> > directory".
> > I double checked the metadata.txt file and made sure that there were no
> > .git -directory in the zip file but still the problem persisted. I even
> > tried to upload the previous version again with a different version
> > number to see if the problem might lie in the plugin upload process
> > instead and I couldn't upload that one either.
> > Thanks!
> > Best regards,
> > Joona Laine, Gispo Ltd.
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201207/4d8a0f84/attachment.html>
More information about the QGIS-Developer mailing list
