[QGIS-Developer] Problem with plugin upload
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Dec 7 03:04:07 PST 2020
I just experienced the same issue a few minutes ago and it went back
to normal.
I thought it was thanks to a requirements.txt file removal, but I guess it
was a server issue.
On Mon, 7 Dec 2020, 11:38 Joona Laine, <joona at gispo.fi> wrote:
> Hi Jorge!
> Thanks for the fast reply! Here
> <https://github.com/GispoCoding/FMI2QGIS/releases/download/0.1.1/FMI2QGIS.0.1.1.zip>
> is a link to the zip file I tried originally (version 0.1.1) and here
> <https://github.com/GispoCoding/FMI2QGIS/releases/download/0.1.0/FMI2QGIS.0.1.0.zip>
> is a link to the initial release zip file (version 0.1.0) that I uploaded
> successfully on 1st December.
> -Joona
> <http://www.gispo.fi/>
> On Mon, 7 Dec 2020 at 12:31, Jorge Gustavo Rocha <jgr at di.uminho.pt> wrote:
>> Hi Joona,
>> Can you share a link to your zip file? It would help to see the exact
>> contents you are trying to upload.
>> Regards,
>> Jorge Gustavo
>> Às 10:27 de 07/12/20, Joona Laine escreveu:
>> > Hello Folks!
>> > I noticed that there might be a problem with QGIS plugin repository
>> > while uploading plugins. I tried to add a new version to a plugin
>> > (FMI2QGIS <https://plugins.qgis.org/plugins/FMI2QGIS/>) first via
>> > qgis-plugin-ci <https://github.com/opengisch/qgis-plugin-ci> and then
>> > manually on web page, but both methods failed with error messages:
>> > <Fault 1: "File upload must be a valid QGIS Python plugin compressed
>> > archive. For security reasons, zip file cannot contain '.git'
>> directory">
>> > and
>> > "There were errors reding plugin package (please check also your
>> > plugin's metadata). For security reasons, zip file cannot contain '.git'
>> > directory".
>> > I double checked the metadata.txt file and made sure that there were no
>> > .git -directory in the zip file but still the problem persisted. I even
>> > tried to upload the previous version again with a different version
>> > number to see if the problem might lie in the plugin upload process
>> > instead and I couldn't upload that one either.
>> > Thanks!
>> > Best regards,
>> > Joona Laine, Gispo Ltd.
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Gabinete 3.29 (Piso 3)
>> Tel: +351 253604480
>> Fax: +351 253604471
>> Móvel: +351 910333888
>> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201207/682b247a/attachment-0001.html>
