[QGIS-Developer] Problem with plugin upload
Joona Laine
joona at gispo.fi
Mon Dec 7 05:03:34 PST 2020
Hi!
Thank you! I checked and I forgot to remove one of the .gitignore files
there. I removed that and I managed to upload a new version just fine! This
is strange since .gitignore files have not caused these kinds of problems
before but I guess it is not too much of a work to export-ignore or remove
those files before making a release.
-Joona
On Mon, 7 Dec 2020 at 14:49, Andrea Giudiceandrea <andreaerdna at libero.it>
wrote:
> Joona Laine wrote
> > I removed those .gitignore files and tried again, but the problem
> > persists.
> > -Joona
> Hi Joona,
> are you sure you removed all the 5 .gitignore files from the zip file?
> You can validate the zip file content using the code at
> https://github.com/qgis/QGIS-Django/blob/master/qgis-app/plugins/validator.py
> I tested your FMI2QGIS.0.1.1.zip and it generates:
> For security reasons, zip file cannot contain '.git' directory
> while removing all the 5 .gitignore files from the same zip file it doesn't
> generate any error.
> Regards.
> Andrea
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201207/88c54876/attachment.html>
