[QGIS-Developer] Problem with plugin upload
Etienne Trimaille
etienne.trimaille at gmail.com
Mon Dec 7 05:06:21 PST 2020
Indeed, this check has been added last week about the `.git` *directory*.
The `.gitignore` mustn't have raised this error.
I will report this information.
Le lun. 7 déc. 2020 à 14:03, Joona Laine <joona at gispo.fi> a écrit :
> Hi!
> Thank you! I checked and I forgot to remove one of the .gitignore files
> there. I removed that and I managed to upload a new version just fine! This
> is strange since .gitignore files have not caused these kinds of problems
> before but I guess it is not too much of a work to export-ignore or remove
> those files before making a release.
> -Joona
> On Mon, 7 Dec 2020 at 14:49, Andrea Giudiceandrea <andreaerdna at libero.it>
> wrote:
>> Joona Laine wrote
>> > I removed those .gitignore files and tried again, but the problem
>> > persists.
>> > -Joona
>> Hi Joona,
>> are you sure you removed all the 5 .gitignore files from the zip file?
>> You can validate the zip file content using the code at
>> https://github.com/qgis/QGIS-Django/blob/master/qgis-app/plugins/validator.py
>> I tested your FMI2QGIS.0.1.1.zip and it generates:
>> For security reasons, zip file cannot contain '.git' directory
>> while removing all the 5 .gitignore files from the same zip file it
>> doesn't
>> generate any error.
>> Regards.
>> Andrea
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201207/0d0eef10/attachment.html>
