[QGIS-Developer] Adding a menu item in "View" menu
uclaros
uclaros at gmail.com
Thu Dec 17 13:16:48 PST 2020
you need to modify src/ui/qgisapp.ui with qt creator or qt designer.
Just note that the 'view' menu is a bit overcrowded and barely fits in one
column on older 1366x768 displays. We should consider grouping some actions
in sub-menus in 'view' and 'edit' menus.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
