[QGIS-Developer] stale bot :-(
Karsten Tebling tebling at masuch.de
Tue Dec 22 06:08:18 PST 2020
Hello,
could you tell me what is considered weed? In most cases I can't provide
sample data because I do not own the data or a coworker had the crash
and "only" saved the report details.
In the "QGIS unexpectedly ended"-dialog it reads "You can also send us a
helpful bug report using the Copy Report button and opening a ticket at
QGIS Issue Tracker." - the thing is, the "copy report"-button only
activates after some text is inserted into "Tell us something about when
you got the crash" and without knowing that, you just assume the "copy
report"-button is broken too and close the dialog. In addition some of
my workmates can't even read english, they just close the dialog
immediately. I also noticed that one of my reports was closed because I
only posted the stacktrace and a short sentence about what my coworker
was roughly doing as far as he could remember and I couldn't provide
sample data. So I guess posting the stack trace and a short explanation
is considered weed and not a "helpful bug report"?
Could you add more information to the "QGIS unexpectedly ended"-dialog,
so it is easier for you to pinpoint the issue without having the user to
create sample data, a sample project, a new user profile? That would be
my wish for christmas.
greetz
Karsten
Am 22.12.2020 um 09:37 schrieb Richard Duivenvoorde:
> I received some "this issue will be closed because of lack of feedback",
> but I think current 'stale bot implementation' is a little rude on the edges.
> (did I miss some discussion about this here?)
> I received some "this issue will be closed because of lack of feedback", only because I commented on them. But some are just plain valid:
> As an example:
> https://github.com/qgis/QGIS/issues/39107#issuecomment-749298135
> that is just a valid use-case (or maybe feature request?)
> This one:
> https://github.com/qgis/QGIS/issues/37984
> is just valid (I even installed Oracle to check this...)
> This one: also valid and still needed:
> https://github.com/qgis/QGIS/issues/37956
> Weeding the issues is not nice, so removing non-valid, old or non responding is fine, but now I think the bot is pulling the veggies instead of the weed :-)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
