[QGIS-Developer] Snap cache improvements grant report
Borys Jurgiel
lists at borysjurgiel.pl
Fri Jan 10 05:22:15 PST 2020
It seems those two regressions may be related to your work on the cache, arent they?
https://github.com/qgis/QGIS/issues/33285[1]
https://github.com/qgis/QGIS/issues/33449[2]
Regards,
Borys
Dnia piÄ…tek, 10 stycznia 2020 11:29:15 CET Julien Cabieces pisze:
> Hi PSC, devs,
> Here is my report for the Snap cache improvements grant proposal.
> We write a blog article to better explain what Snap cache improvement was
> about: https://oslandia.com/en/2020/01/10/en-qgis-snapping-improvements/
> This work leads to these PRs :
> - Manage circular dependencies: https://github.com/qgis/QGIS/pull/30947
> - Parallelize and relax snap index building:
> https://github.com/qgis/QGIS/pull/31648 - Fix QgsTaskManager
> waitForFinished : https://github.com/qgis/QGIS/pull/32838
> The first one is available in 3.10 release while the other ones are only in
> master. At first, I wanted to backport them in 3.10 but I change my mind.
> Indeed some of the modifications are quite critical (In QgsTaskManager for
> instance) and are difficult to fine test (because it's all threads and
> synchronisation).
> We're going to invest more time and keep working on this in the days to come
> in order to improve stability and maybe efficiency.
> As a consequence, parallel snap cache building and relaxed mode will
> land in 3.12 release.
> Thanks QGIS.org for funding this,
> Regards,
> Julien
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
[1] https://github.com/qgis/QGIS/issues/33285
[2] https://github.com/qgis/QGIS/issues/33449
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200110/3589e7e2/attachment.html>
