[QGIS-Developer] Snap cache improvements grant report
Julien Cabieces
julien.cabieces at oslandia.com
Fri Jan 10 06:31:30 PST 2020
Could be. Thank you for reporting, I'll take a look and answer you back
in those tickets.
Regards,
Julien
> Hi,
> It seems those two regressions may be related to your work on the cache, arent they?
> https://github.com/qgis/QGIS/issues/33285
> https://github.com/qgis/QGIS/issues/33449
> Regards,
> Borys
> Dnia piÄ…tek, 10 stycznia 2020 11:29:15 CET Julien Cabieces pisze:
>> Hi PSC, devs,
>> Here is my report for the Snap cache improvements grant proposal.
>> We write a blog article to better explain what Snap cache improvement was
>> about: https://oslandia.com/en/2020/01/10/en-qgis-snapping-improvements/
>> This work leads to these PRs :
>> - Manage circular dependencies: https://github.com/qgis/QGIS/pull/30947
>> - Parallelize and relax snap index building:
>> https://github.com/qgis/QGIS/pull/31648 - Fix QgsTaskManager
>> waitForFinished : https://github.com/qgis/QGIS/pull/32838
>> The first one is available in 3.10 release while the other ones are only in
>> master. At first, I wanted to backport them in 3.10 but I change my mind.
>> Indeed some of the modifications are quite critical (In QgsTaskManager for
>> instance) and are difficult to fine test (because it's all threads and
>> synchronisation).
>> We're going to invest more time and keep working on this in the days to come
>> in order to improve stability and maybe efficiency.
>> As a consequence, parallel snap cache building and relaxed mode will
>> land in 3.12 release.
>> Thanks QGIS.org for funding this,
>> Regards,
>> Julien
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
