[QGIS-Developer] QgsRendererPropertiesDialog crashes python application with PyQgis
Marcelo Metello marcelometello44 at gmail.com
Wed Jan 15 12:53:24 PST 2020
I have an external windows standalone python application that uses pyqgis.
When I display a QgsRendererPropertiesDialog, python crashes
(sometimes) when the user clicks on any color button (screenshot:
http://psr.me/1903oq2). The problem is intermitent and seems to be in
displaying the color dialog. In previous QGis versions I could avoid
this problem by using:
        settings = QgsSettings()
        settings.setValue('qgis/native_color_dialogs', True)
QGis then used another color dialog that did not crash my application.
However, since I updated to QGis 3.8.3 (OSGEO4W) this option no longer
works.
I wrote a very small PyQt5 application (below, at the end) that reproduces
the problem: the color button sometimes crashes the application.
Any thoughts on how to fix this?
Operating system: Windows 10 Home
Python version: 3.7.0 (OSGEO4W)
QGis version: 3.8.3 (OSGEO4W)
Thanks,
Marcelo Metello
from qgis.core import QgsVectorLayer, QgsStyle
from qgis.gui import QgsRendererPropertiesDialog
from PyQt5 import QtCore, QtWidgets
def editStyle():
    layer = QgsVectorLayer('LineString?field=level:integer',
'contour_lines', 'memory')
    dialog = QtWidgets.QDialog()
    layout = QtWidgets.QVBoxLayout(dialog)
    # Add symbology panel
    symbPanel = QgsRendererPropertiesDialog(layer, QgsStyle.defaultStyle(),
True)
    layout.addWidget(symbPanel)
    # Add Ok Cancel button box
    buttonBox = QtWidgets.QDialogButtonBox(QtWidgets.QDialogButtonBox.Ok |
QtWidgets.QDialogButtonBox.Cancel, QtCore.Qt.Horizontal, dialog)
    buttonBox.button(QtWidgets.QDialogButtonBox.Ok).setText('Ok')
    buttonBox.button(QtWidgets.QDialogButtonBox.Cancel).setText('Cancel')
    buttonBox.accepted.connect(dialog.accept)
    buttonBox.rejected.connect(dialog.reject)
    layout.addWidget(buttonBox)
    dialog.setLayout(layout)
    dialog.adjustSize()
    if (dialog.exec_() == QtWidgets.QDialog.Accepted):
        symbPanel.apply()
# Create simple application with only one button
app = QtWidgets.QApplication([])
window = QtWidgets.QWidget()
layout = QtWidgets.QVBoxLayout()
editBtn = QtWidgets.QPushButton('Edit Style')
editBtn.clicked.connect(editStyle)
layout.addWidget(editBtn)
window.setLayout(layout)
window.show()
app.exec_()
app.exit()
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200115/7886bf6a/attachment.html>
More information about the QGIS-Developer mailing list
