[QGIS-Developer] QGIS server logs
Sylvain POULAIN
sylvain.poulain at giscan.com
Wed Jul 8 04:10:23 PDT 2020
@Regis,
For xdg open and docker, just map your X11 running session inside docker
container and export DISPLAY like this :
-v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=unix$DISPLAY
It works with docker mundialis qgis 2. If not sufficient, you could map
xdg-open to container :
-v /usr/bin/xdg-open:/usr/bin/xdg-open:ro
Why is it declared on the server version ?
*Sylvain *
<http://giscan.com>
Le mer. 8 juil. 2020 à 12:19, Paolo Cavallini <cavallini at faunalia.it> a
écrit :
> Hi again,
> on the same server I'm getting frequent:
> [Wed Jul 08 10:15:21.847370 2020] [fcgid:warn] [pid 23438] [client
> 127.0.0.1:37450] mod_fcgid: error reading data, FastCGI server closed
> connection
> [Wed Jul 08 10:15:21.847989 2020] [core:error] [pid 23438] [client
> 127.0.0.1:37450] End of script output before headers: qgis_mapserv.fcgi
> could this simply due to lack of resources (only 4Gb RAM) or there are
> other explanations?
> Cheers.
> Il 06/07/20 20:16, Régis Haubourg ha scritto:
> > Hi Paolo, I have those messages too when running QGIS desktop from a
> > docker. Xdg-runtime is used to open default app for files or urls on the
> > system. I think this has no impact on a server use case.
> > But I wish I could forward this xdg commands to my host so that I can
> > open help pages from QGIS in a docker :). If someone knows some magic
> > here please share !
> > Cheers
> > Régis
> > Le lun. 6 juil. 2020 à 18:29, Paolo Cavallini <cavallini at faunalia.it
> > <mailto:cavallini at faunalia.it>> a écrit :
> > Hi all,
> > I'm getting some messages from the log file I do'nt understand[0]
> > I couldn't find an explanation in the manual. Does anybody have some
> > hints?
> > Thanks in advance.
> > [0]
> > Application path not initialized
> > QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to
> > '/tmp/runtime-www-data'
> > QNetworkDiskCache::prepare() unable to open temporary file
> > Paolo Cavallini
> > www.faunalia.eu <http://www.faunalia.eu> - QGIS.org
> > training, support, development on QGIS, PostGIS and more
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <mailto:
> QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Paolo Cavallini
> www.faunalia.eu - QGIS.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200708/cec3e26f/attachment.html>
