[QGIS-Developer] QGIS server logs
Paolo Cavallini
cavallini at faunalia.it
Wed Jul 8 05:35:56 PDT 2020
in my case, no docker, it's a real machine, with a xvfb
thanks Sylvain for comments
Il 08/07/20 13:10, Sylvain POULAIN ha scritto:
> @Regis,
> For xdg open and docker, just map your X11 running session inside docker
> container and export DISPLAY like this :
> -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=unix$DISPLAY
> It works with docker mundialis qgis 2. If not sufficient, you could map
> xdg-open to container :
> -v /usr/bin/xdg-open:/usr/bin/xdg-open:ro
> Why is it declared on the server version ?
> *Sylvain
> <http://giscan.com>
> Le mer. 8 juil. 2020 à 12:19, Paolo Cavallini <cavallini at faunalia.it
> <mailto:cavallini at faunalia.it>> a écrit :
> Hi again,
> on the same server I'm getting frequent:
> [Wed Jul 08 10:15:21.847370 2020] [fcgid:warn] [pid 23438] [client
> 127.0.0.1:37450 <http://127.0.0.1:37450>] mod_fcgid: error reading
> data, FastCGI server closed
> connection
> [Wed Jul 08 10:15:21.847989 2020] [core:error] [pid 23438] [client
> 127.0.0.1:37450 <http://127.0.0.1:37450>] End of script output
> before headers: qgis_mapserv.fcgi
> could this simply due to lack of resources (only 4Gb RAM) or there are
> other explanations?
> Cheers.
> Il 06/07/20 20:16, Régis Haubourg ha scritto:
> > Hi Paolo, I have those messages too when running QGIS desktop from a
> > docker. Xdg-runtime is used to open default app for files or urls
> on the
> > system. I think this has no impact on a server use case.
> > But I wish I could forward this xdg commands to my host so that I can
> > open help pages from QGIS in a docker :). If someone knows some magic
> > here please share !
> > Cheers
> > Régis
> > Le lun. 6 juil. 2020 à 18:29, Paolo Cavallini
> <cavallini at faunalia.it <mailto:cavallini at faunalia.it>
> > <mailto:cavallini at faunalia.it <mailto:cavallini at faunalia.it>>> a
> écrit :
> > Hi all,
> > I'm getting some messages from the log file I do'nt understand[0]
> > I couldn't find an explanation in the manual. Does anybody
> have some
> > hints?
> > Thanks in advance.
> > [0]
> > Application path not initialized
> > QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to
> > '/tmp/runtime-www-data'
> > QNetworkDiskCache::prepare() unable to open temporary file
> > Paolo Cavallini
> > www.faunalia.eu <http://www.faunalia.eu>
> <http://www.faunalia.eu> - QGIS.org
> > training, support, development on QGIS, PostGIS and more
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> <mailto:QGIS-Developer at lists.osgeo.org>>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe:
> Paolo Cavallini
> www.faunalia.eu <http://www.faunalia.eu> - QGIS.org
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini
www.faunalia.eu - QGIS.org
