[QGIS-Developer] Removal of PostGISExecuteSQL.py in 3.14
Nils Nolde
nilsnolde at gmail.com
Mon Jul 13 12:12:21 PDT 2020
Thanks for the heads up Etienne! That’s great:)
> On 13. Jul 2020, at 18:02, Etienne Trimaille <etienne.trimaille at gmail.com> wrote:
>> Le lun. 13 juil. 2020 à 15:59, Nils Nolde <nilsnolde at gmail.com> a écrit :
>> Hi,
>> I just realized that the processing algo PostGISExecuteSQL.py was
>> removed for the 3.14 release.
> The algorithm has been ported to C++, so yes the python version has been removed.
> https://github.com/qgis/QGIS/blob/master/src/analysis/processing/qgsalgorithmexecutepostgisquery.cpp
> Even calling it from Python will work using the old previous Python processing provider because the compatibility is maintained.
>> Some time after processing.tools.postgis
>> module was removed (as the only module using it was PostGISExecuteSQL,
>> but still, it's a public API protected by backwards compatibility right?)
> Code in plugins (such as Processing or DB Manager) is not considered stable.
> You should use the public API, when it's starting with "from qgis." core, gui, analysis, processing etc
> You should use the new database API.
>> Was that a mistake?
>> Cheers
>> Nils
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200713/6fd771d6/attachment.html>
