[QGIS-Developer] compiled current master crash on Debian testing
Richard Duivenvoorde rdmailings at duif.net
Tue Jun 2 04:46:13 PDT 2020
Hi Devs,
Fresh compiled QGIS this morning (actually twice..., and a reboot, to be
sure, and an empty profile),
on Debian Testing here
QGIS version
3.13.0-Master
QGIS code revision
6ddcd39800
Compiled against Qt
5.12.5
Running against Qt
5.12.5
Compiled against GDAL/OGR
3.0.4
Running against GDAL/OGR
3.0.4
Compiled against GEOS
3.8.1-CAPI-1.13.3
Running against GEOS
3.8.1-CAPI-1.13.3
Compiled against SQLite
3.31.1
Running against SQLite
3.31.1
PostgreSQL Client Version
12.3 (Debian 12.3-1)
SpatiaLite Version
4.3.0a
QWT Version
6.1.4
QScintilla2 Version
2.11.2
Compiled against PROJ
7.0.1
Running against PROJ
Rel. 7.0.1, May 1st, 2020
OS Version
Debian GNU/Linux bullseye/sid
This copy of QGIS writes debugging output.
Active python plugins
MetaSearch;
processing;
db_manager
Below some stacktraces.
QGIS start fine, but as soon as I try to open a layer (be it ogr or xyz)
QGIS crashes.
Any tips? I will try a super fresh configure compile too now.
Regards,
../src/core/providers/ogr/qgsogrprovider.cpp:4459 : (open) [0ms]
mLayerName: countries
../src/core/providers/ogr/qgsogrprovider.cpp:4460 : (open) [0ms]
mSubsetString:
../src/core/providers/ogr/qgsogrprovider.cpp:4541 : (open) [13ms] OGR
opened using Driver GPKG
QGIS died on signal 11[New LWP 233442]
[New LWP 233443]
[New LWP 233444]
[New LWP 233445]
[New LWP 233446]
[New LWP 233447]
[New LWP 233448]
[New LWP 233449]
[New LWP 233450]
[New LWP 233451]
[New LWP 233452]
[New LWP 233453]
[New LWP 233454]
[New LWP 233456]
[New LWP 233459]
[New LWP 233461]
[New LWP 233464]
[New LWP 233466]
[New LWP 233467]
[New LWP 233468]
[New LWP 233469]
[New LWP 233470]
[New LWP 233471]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007f6faeb89c0e in __GI___waitpid (pid=233472,
stat_loc=0x7ffd57660d14, options=0) at
../sysdeps/unix/sysv/linux/waitpid.c:30
30	../sysdeps/unix/sysv/linux/waitpid.c: No such file or directory.
[Current thread is 1 (Thread 0x7f6f9cdb4f40 (LWP 233434))]
#0  0x00007f6faeb89c0e in __GI___waitpid (pid=233472,
        resultvar = 18446744073709551104
        sc_cancel_oldtype = 0
#1  0x000055ffe4fdc2c0 in qgisCrash(int) (signal=11) at
../src/app/main.cpp:349
        status = 32765
        pidstr = "--pid=233434", '\000' <repeats 12 times>,
"\003\000\000\000\000\000\000"
        gdbpid = 233472
        exename =
"/home/richard/bin/qgis_/master/debug/bin/qgis\000\000\000+\000\323\000\000\000\000\000h\314\376\347\377U\000\000\006\000\000\000\377U\000\000\024\002\001\001\000\000\000\000h*\275\361\377U\000\000\032\000\000\000o\177\000\000y\005\027\000\000\000\000\000\271'\275\361\377U\000\000\001\000\000\000\377U\000\000H\000\323\000\375\177\000\000x/\275\361\377U\000\000\r\000\000\000\377U\000\000\004\000\000\000\000\000\000\000r\001\361\000o\177\000\000h\314\376\347\377U\000\000\005\000\000\000o\177\000\000q\001\362\000\377U\000\000\000\000\000\000\000\000\000\000\004\000\000\000\377U\000\000"...
        len = 45
#2  0x00007f6faeafa800 in <signal handler called> () at
/lib/x86_64-linux-gnu/libc.so.6
#3  0x00007f6fa9157fb0 in sqlite3_str_vappendf () at
/usr/lib/x86_64-linux-gnu/libsqlite3.so.0
#4  0x00007f6fa917b14f in sqlite3_vmprintf () at
#5  0x00007f6fa917c44f in sqlite3_mprintf () at
#6  0x00007f6fb0e7b359 in QgsSqliteUtils::uniqueFields(sqlite3*, QString
const&, QString&) (connection=0x55fff24022f8, tableName=...,
errorMessage=...) at ../src/core/qgssqliteutils.cpp:174
        uniqueFieldsResults = {q_hash = {{d = 0x7f6faf1c36e0
<QHashData::shared_null>, e = 0x7f6faf1c36e0 <QHashData::shared_null>}}}
        zErrMsg = 0x0
        rows = std::vector of length 0, capacity 1
        sql = {static null = {<No data fields>}, d = 0x55ffe7fcbdd0}
        cb = {<No data fields>}
        rc = 0
        uniqueFieldMatch =
{<std::vector<std::__cxx11::sub_match<__gnu_cxx::__normal_iterator<char
const*, std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> > > >,
std::allocator<std::__cxx11::sub_match<__gnu_cxx::__normal_iterator<char
std::allocator<char> > > > > >> = std::vector of length 0, capacity 0,
_M_begin = non-dereferenceable iterator for std::vector}
        sFieldIdentifierRe = {static icase = <optimized out>, static
nosubs = <optimized out>, static optimize = <optimized out>, static
collate = <optimized out>, static ECMAScript = (unknown: 16), static
basic = <optimized out>, static extended = <optimized out>, static awk =
<optimized out>, static grep = <optimized out>, static egrep =
<optimized out>, _M_flags = (unknown: 16), _M_loc = {static none = 0,
static ctype = 1, static numeric = 2, static collate = 4, static time =
8, static monetary = 16, static messages = 32, static all = 63, _M_impl
= 0x7f6faee67ce0, static _S_classic = <optimized out>, static _S_global
= <optimized out>, static _S_categories = <optimized out>, static
_S_once = <optimized out>, static _S_twinned_facets = <optimized out>},
_M_automaton = std::shared_ptr<const struct
std::__detail::_NFA<std::__cxx11::regex_traits<char> >> (use count 1,
weak count 0) = {get() = 0x55fff23ef120}}
#7  0x00007f6fb0a7ed00 in QgsOgrProvider::loadFields()
(this=0x55fff23daf80) at ../src/core/providers/ogr/qgsogrprovider.cpp:1116
        errMsg = {static null = {<No data fields>}, d = 0x7f6faf1c1680
<QArrayData::shared_null>}
        dsPtr = {<std::unique_ptr<sqlite3, QgsSqlite3Closer>> =
std::unique_ptr<struct sqlite3> = {get() = 0x55fff24022f8}, <No data
fields>}
        fdef = @0x55fff1c8c0c0: {hDefn = 0x55ffe7feab30, layer =
0x55fff1c8c080}
        fidColumn = {d = 0x55ffe7fec230}
        uniqueFieldNames = {q_hash = {{d = 0x7f6faf1c36e0
        createdFields = 32623
#8  0x00007f6fb0a7e77d in QgsOgrProvider::setEncoding(QString const&)
(this=0x55fff23daf80, e=...) at
../src/core/providers/ogr/qgsogrprovider.cpp:1023
        settings = {<QObject> = {<No data fields>}, static
staticMetaObject = {d = {superdata = 0x7f6faf392980
<QObject::staticMetaObject>, stringdata = 0x7f6fb145f340
<qt_meta_stringdata_QgsSettings>, data = 0x7f6fb145f380
<qt_meta_data_QgsSettings>, static_metacall = 0x7f6fb05fab42
<QgsSettings::qt_static_metacall(QObject*, QMetaObject::Call, int,
void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mUserSettings =
0x55fff2401620, mGlobalSettings = 0x55fff1c8c6d0, mUsingGlobalArray = false}
#9  0x00007f6fb0a9c257 in QgsOgrProvider::open(QgsOgrProvider::OpenMode)
(this=0x55fff23daf80, mode=QgsOgrProvider::OpenModeInitial) at
../src/core/providers/ogr/qgsogrprovider.cpp:4566
        origSubsetString = {static null = {<No data fields>}, d =
0x55fff1c74180}
        openReadOnly = false
        vsiPrefix = {static null = {<No data fields>}, d =
0x7f6faf1c1680 <QArrayData::shared_null>}
        __FUNCTION__ = "open"
        errCause = {static null = {<No data fields>}, d = 0x7f6faf1c1680
#10 0x00007f6fb0a7a2b7 in QgsOgrProvider::QgsOgrProvider(QString const&,
QgsDataProvider::ProviderOptions const&) (this=0x55fff23daf80, uri=...,
options=...) at ../src/core/providers/ogr/qgsogrprovider.cpp:515
        nMaxIntLen = 32765
        nMaxInt64Len = 1466311520
        nMaxDoubleLen = 0
        nDateLen = 22015
        supportsTime = 201
        supportsBinary = 16
        pszDataTypes = 0x7f6fb0e43cb6
<std::_Rb_tree_node<std::pair<QString const, QgsProviderMetadata*>
>::_M_valptr() const+28> "\311\303UH\211\345H\203\354
H\211}\350H\213E\350H\213P\030H\215E\370H\211\326H\211\307\350\065\351x\377H\213E\370\311ÐUH\211\345H\203\354\020H\211}\370H\213E\370H\211\307\350V\231v\377\220\311ÐUH\211\345H\211}\370\220]ÐUH\211\345H\203\354
H\211}\350H\211u\340H\203", <incomplete sequence \340>
        supportsDate = 231
        supportsBoolean = false
0x55fff24085c0, mGlobalSettings = 0x55fff24086f0, mUsingGlobalArray = false}
        nMaxDoublePrec = 544
        nativeTypes =
{<QListSpecialMethods<QgsVectorDataProvider::NativeType>> = {<No data
fields>}, {p = {static shared_null = {ref = {atomic = {_q_value =
{<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i = -1}, <No
data fields>}}}, alloc = 0, begin = 0, end = 0, array = {0x0}}, d =
0x5ed6379d}, d = 0x5ed6379d}}
        supportsDateTime = 219
        supportsStringList = false
#11 0x00007f6fb0a94ad5 in QgsOgrProviderMetadata::createProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x55ffe7ef34f0,
uri=..., options=...) at ../src/core/providers/ogr/qgsogrprovider.cpp:3451
#12 0x00007f6fb0e41e45 in QgsProviderRegistry::createProvider(QString
const&, QString const&, QgsDataProvider::ProviderOptions const&)
(this=0x55ffe7c9d3b0, providerKey=..., dataSource=..., options=...) at
../src/core/qgsproviderregistry.cpp:416
        metadata = 0x55ffe7ef34f0
#13 0x00007f6fb0f20d6e in QgsVectorLayer::setDataProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x55fff1c74640,
provider=..., options=...) at ../src/core/qgsvectorlayer.cpp:1717
        __FUNCTION__ = "setDataProvider"
#14 0x00007f6fb0f203a0 in QgsVectorLayer::setDataSource(QString const&,
QString const&, QString const&, QgsDataProvider::ProviderOptions const&,
bool) (this=0x55fff1c74640, dataSource=..., baseName=..., provider=...,
options=..., loadDefaultStyleFlag=true) at
../src/core/qgsvectorlayer.cpp:1620
        geomType = QgsWkbTypes::UnknownGeometry
#15 0x00007f6fb0f16b19 in QgsVectorLayer::QgsVectorLayer(QString const&,
QString const&, QString const&, QgsVectorLayer::LayerOptions const&)
(this=0x55fff1c74640, vectorLayerPath=..., baseName=...,
providerKey=..., options=...) at ../src/core/qgsvectorlayer.cpp:180
        providerOptions = {transformContext = {d = {d = 0x55fff1c8cf20}}}
0x0, mGlobalSettings = 0x7f6faeb44d93 <malloc_consolidate+259>,
#16 0x00007f6fb2d4dfc8 in
QgsCoordinateBoundsPreviewMapWidget::QgsCoordinateBoundsPreviewMapWidget(QWidget*)
(this=0x55fff1c11af0, parent=0x55fff2482f70) at
../src/gui/qgscoordinateboundspreviewmapwidget.cpp:38
        rectColor = {cspec = QColor::Rgb, ct = {argb = {alpha = 15420,
red = 47545, green = 21588, blue = 53970, pad = 0}, ahsv = {alpha =
15420, hue = 47545, saturation = 21588, value = 53970, pad = 0}, acmyk =
{alpha = 15420, cyan = 47545, magenta = 21588, yellow = 53970, black =
0}, ahsl = {alpha = 15420, hue = 47545, saturation = 21588, lightness =
53970, pad = 0}, array = {15420, 47545, 21588, 53970, 0}}}
        srs = {static staticMetaObject = {d = {superdata = 0x0,
stringdata = 0x7f6fb14524c0
<qt_meta_stringdata_QgsCoordinateReferenceSystem>, data = 0x7f6fb14525e0
<qt_meta_data_QgsCoordinateReferenceSystem>, static_metacall =
0x7f6fb05e7ee2
<QgsCoordinateReferenceSystem::qt_static_metacall(QObject*,
QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x7f6fb1f45a90
<qt_meta_extradata_QgsCoordinateReferenceSystem>, extradata = 0x0}}, d =
{d = 0x55ffe7750960}, mValidationHint = {static null = {<No data
fields>}, d = 0x7f6faf1c1680 <QArrayData::shared_null>}, static
sCustomSrsValidation = 0x7f6fb3870be4
<customSrsValidation_(QgsCoordinateReferenceSystem&)>, static
sDisableSrIdCache = false, static sDisableOgcCache = false, static
sDisableProjCache = false, static sDisableWktCache = false, static
sDisableSrsIdCache = false, static sDisableStringCache = false}
        layerPath = {static null = {<No data fields>}, d = 0x55fff1c74530}
#17 0x00007f6fb2d55068 in
Ui_QgsCoordinateOperationWidgetBase::setupUi(QWidget*)
(this=0x55fff2482fa0, QgsCoordinateOperationWidgetBase=0x55fff2482f70)
at src/ui/ui_qgscoordinateoperationwidgetbase.h:91
        sizePolicy = {static staticMetaObject = {d = {superdata = 0x0,
stringdata = 0x7f6fafe7f2a0, data = 0x7f6fafe7f180, static_metacall =
0x0, relatedMetaObjects = 0x0, extradata = 0x0}}, {bits = {horStretch =
111, verStretch = 127, horPolicy = 0, verPolicy = 0, ctype = 0, hfw = 0,
wfh = 0, retainSizeWhenHidden = 0}, data = 32623}}
#18 0x00007f6fb2d4ea0d in
QgsCoordinateOperationWidget::QgsCoordinateOperationWidget(QWidget*)
(this=0x55fff2482f70, parent=0x7ffd57663200) at
../src/gui/qgscoordinateoperationwidget.cpp:40
        headers = {<QList<QString>> = {<QListSpecialMethods<QString>> =
{<No data fields>}, {p = {static shared_null = {ref = {atomic =
{_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i
= -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array =
{0x0}}, d = 0x0}, d = 0x0}}, <No data fields>}
#19 0x00007f6fb2d6bada in
Ui_QgsDatumTransformDialogBase::setupUi(QDialog*) (this=0x7ffd57663230,
QgsDatumTransformDialogBase=0x7ffd57663200) at
src/ui/ui_qgsdatumtransformdialogbase.h:151
0, verStretch = 0, horPolicy = 5, verPolicy = 5, ctype = 0, hfw = 0, wfh
= 0, retainSizeWhenHidden = 0}, data = 5570560}}
#20 0x00007f6fb2d68a9d in
QgsDatumTransformDialog::QgsDatumTransformDialog(QgsCoordinateReferenceSystem
const&, QgsCoordinateReferenceSystem const&, bool, bool, bool,
QPair<int, int>, QWidget*, QFlags<Qt::WindowType>, QString const&,
QgsMapCanvas*, bool) (this=0x7ffd57663200, sCrs=..., dCrs=...,
allowCrsChanges=false, showMakeDefault=true, forceChoice=false,
selectedDatumTransforms=..., parent=0x55ffe799ec90, f=...,
selectedProj=..., mapCanvas=0x55ffe7e7c880, allowFallback=true) at
../src/gui/qgsdatumtransformdialog.cpp:84
        sourceCrs = {static staticMetaObject = {d = {superdata = 0x0,
0x7f6fb05e7ee2
{d = 0x7ffd57663090}, mValidationHint = {static null = {<No data
fields>}, d = 0x7ffd57663090}, static sCustomSrsValidation =
0x7f6fb3870be4 <customSrsValidation_(QgsCoordinateReferenceSystem&)>,
static sDisableSrIdCache = false, static sDisableOgcCache = false,
static sDisableProjCache = false, static sDisableWktCache = false,
static sDisableSrsIdCache = false, static sDisableStringCache = false}
        destinationCrs = {static staticMetaObject = {d = {superdata =
0x0, stringdata = 0x7f6fb14524c0
0x7f6fb05e7ee2
{d = 0x7ffd57663060}, mValidationHint = {static null = {<No data
fields>}, d = 0x7f6fb0c0fc98
<QgsCoordinateTransformContextPrivate::OperationDetails::~OperationDetails()+24>},
static sCustomSrsValidation = 0x7f6fb3870be4
        deets = {sourceTransformId = 1466314816, destinationTransformId
= 32765, proj = {static null = {<No data fields>}, d = 0x55ffe4fe5ded
<QString::~QString()+27>}, isAvailable = 224, allowFallback = 48}
#21 0x00007f6fb2d6855f in
QgsDatumTransformDialog::run(QgsCoordinateReferenceSystem const&,
QgsCoordinateReferenceSystem const&, QWidget*, QgsMapCanvas*, QString
const&) (sourceCrs=..., destinationCrs=..., parent=0x55ffe799ec90,
mapCanvas=0x55ffe7e7c880, windowTitle=...) at
../src/gui/qgsdatumtransformdialog.cpp:47
        context = {d = {d = 0x55fff1ce96e0}}
        dlg = {<QDialog> = {<No data fields>},
<Ui::QgsDatumTransformDialogBase> = {<Ui_QgsDatumTransformDialogBase> =
{gridLayout = 0x55fff1c37160, mButtonBox = 0x55fff1c9bbd0, textEdit =
0x55ffe7fcb780, mCrsStackedWidget = 0x55fff1c354c0, page =
0x55fff1c35990, verticalLayout = 0x55fff240ba30, gridLayout_4 =
0x55fff1c33250, label = 0x55fff1c33460, mSourceProjectionSelectionWidget
= 0x55fff1c33600, label_2 = 0x55fff1be4ce0,
mDestinationProjectionSelectionWidget = 0x55fff1c37b20, page_2 =
0x55fff24937f0, verticalLayout_2 = 0x55fff249c8d0, gridLayout_5 =
0x55fff249c990, label_3 = 0x55fff249cb00, label_4 = 0x55fff249cf20,
mDestCrsLabel = 0x55fff249d330, mSourceCrsLabel = 0x55fff24a1640,
mCoordinateOperationsWidget = 0x7f6faf3a1b70}, <No data fields>}, static
staticMetaObject = {d = {superdata = 0x7f6faffeb8c0
<QDialog::staticMetaObject>, stringdata = 0x7f6fb30c6120
<qt_meta_stringdata_QgsDatumTransformDialog>, data = 0x7f6fb30c6260
<qt_meta_data_QgsDatumTransformDialog>, static_metacall = 0x7f6fb259c3e0
<QgsDatumTransformDialog::qt_static_metacall(QObject*,
QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x0, extradata =
0x0}}, mPreviousCursorOverride = std::unique_ptr<class
QgsTemporaryCursorRestoreOverride> = {get() = 0x55fff243ffb0}}
#22 0x00007f6fb38f9075 in
QgisApp::askUserForDatumTransform(QgsCoordinateReferenceSystem const&,
QgsCoordinateReferenceSystem const&, QgsMapLayer const*)
(this=0x55ffe799ec90, sourceCrs=..., destinationCrs=...,
layer=0x55fff1cd9030) at ../src/app/qgisapp.cpp:15229
        title = {static null = {<No data fields>}, d = 0x55fff1c8f3c0}
#23 0x00007f6fb38dc6d1 in QgisApp::projectCrsChanged()
(this=0x55ffe799ec90) at ../src/app/qgisapp.cpp:11106
        it = {i = 0x55ffe89c6550}
        __FUNCTION__ = "projectCrsChanged"
        alreadyAsked =
{<QListSpecialMethods<QgsCoordinateReferenceSystem>> = {<No data
0x55fff1c35c80}, d = 0x55fff1c35c80}}
        layers = {d = 0x55fff1cd97b0}
#24 0x00007f6fb397cfbb in
QtPrivate::FunctorCall<QtPrivate::IndexesList<>, QtPrivate::List<>,
void, void (QgisApp::*)()>::call(void (QgisApp::*)(), QgisApp*, void**)
(f=(void (QgisApp::*)(class QgisApp * const)) 0x7f6fb38dc3d4
<QgisApp::projectCrsChanged()>, o=0x55ffe799ec90, arg=0x7ffd57663700) at
/usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:152
#25 0x00007f6fb3976e71 in QtPrivate::FunctionPointer<void
(QgisApp::*)()>::call<QtPrivate::List<>, void>(void (QgisApp::*)(),
QgisApp*, void**) (f=(void (QgisApp::*)(class QgisApp * const))
0x7f6fb38dc3d4 <QgisApp::projectCrsChanged()>, o=0x55ffe799ec90,
/usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:185
#26 0x00007f6fb396aace in QtPrivate::QSlotObject<void (QgisApp::*)(),
QtPrivate::List<>, void>::impl(int, QtPrivate::QSlotObjectBase*,
QObject*, void**, bool*) (which=1, this_=0x55fff1f6ebd0,
r=0x55ffe799ec90, a=0x7ffd57663700, ret=0x0) at
/usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:414
#27 0x00007f6faf1104e8 in QMetaObject::activate(QObject*, int, int,
void**) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#28 0x00007f6fb05f9159 in QgsProject::crsChanged() (this=0x55ffe6d16190)
at src/core/qgis_core_autogen/EWIEGA46WW/moc_qgsproject.cpp:1070
#29 0x00007f6fb0dddaed in QgsProject::readProjectFile(QString const&,
QFlags<QgsProject::ReadFlag>) (this=0x55ffe6d16190, filename=...,
flags=...) at ../src/core/qgsproject.cpp:1609
        projectFile = <incomplete type>
0x55ffe7f52260, mGlobalSettings = 0x55ffe7f52280, mUsingGlobalArray = false}
        localeFileName = {static null = {<No data fields>}, d =
0x55ffefa9ed30}
        doc = std::unique_ptr<class QDomDocument> = {get() = 0x55fff19d04e0}
        line = 0
        column = 0
        errorMsg = {static null = {<No data fields>}, d = 0x7f6faf1c1680
        __FUNCTION__ = "readProjectFile"
        fileVersion = {mMajor = 3, mMinor = 13, mSub = 0, mName =
{static null = {<No data fields>}, d = 0x55ffe9c775b0}}
        thisVersion = {mMajor = 3, mMinor = 13, mSub = 0, mName =
{static null = {<No data fields>}, d = 0x55fff1ccac30}}
        fileName = {static null = {<No data fields>}, d = 0x55ffe7718c00}
        aStorage = std::unique_ptr<class QgsAuxiliaryStorage> = {get() =
0x0}
        oldTitle = {static null = {<No data fields>}, d = 0x7f6faf1c1680
        homePathNl = {impl = 0x55ffe7f93ba0}
        backgroundColor = {cspec = QColor::Rgb, ct = {argb = {alpha =
65535, red = 65535, green = 65535, blue = 65535, pad = 0}, ahsv = {alpha
= 65535, hue = 65535, saturation = 65535, value = 65535, pad = 0}, acmyk
= {alpha = 65535, cyan = 65535, magenta = 65535, yellow = 65535, black =
0}, ahsl = {alpha = 65535, hue = 65535, saturation = 65535, lightness =
65535, pad = 0}, array = {65535, 65535, 65535, 65535, 0}}}
        selectionColor = {cspec = QColor::Rgb, ct = {argb = {alpha =
39321, red = 65535, green = 65535, blue = 0, pad = 0}, ahsv = {alpha =
39321, hue = 65535, saturation = 65535, value = 0, pad = 0}, acmyk =
{alpha = 39321, cyan = 65535, magenta = 65535, yellow = 0, black = 0},
ahsl = {alpha = 39321, hue = 65535, saturation = 65535, lightness = 0,
pad = 0}, array = {39321, 65535, 65535, 0, 0}}}
        context = {mPathResolver = {mBaseFileName = {static null = {<No
data fields>}, d = 0x55ffe7718c00}}, mMessages =
{<QListSpecialMethods<QgsReadWriteContext::ReadWriteMessage>> = {<No
data fields>}, {p = {static shared_null = {ref = {atomic = {_q_value =
0x7f6faf1c3760 <QListData::shared_null>}, d = 0x7f6faf1c3760
<QListData::shared_null>}}, mCategories = {<QList<QString>> =
{<QListSpecialMethods<QString>> = {<No data fields>}, {p = {static
shared_null = {ref = {atomic = {_q_value = {<std::__atomic_base<int>> =
{static _S_alignment = 4, _M_i = -1}, <No data fields>}}}, alloc = 0,
begin = 0, end = 0, array = {0x0}}, d = 0x7f6faf1c3760
<QListData::shared_null>}}, <No data fields>}, mProjectTranslator =
0x55ffe6d161b0, mCoordinateTransformContext = {d = {d = 0x55ffe7f92950}}}
        projectCrs = {static staticMetaObject = {d = {superdata = 0x0,
0x7f6fb05e7ee2
{d = 0x55ffe7374f90}, mValidationHint = {static null = {<No data
        datumErrors = {<QList<QString>> =
        variableNames = {<QList<QString>> =
        variableValues = {<QList<QString>> =
        nl = {impl = 0x55ffeced0e60}
        layerTreeElem = {<QDomNode> = {impl = 0x55ffe7fa65d0}, <No data
fields>}
        brokenNodes = {<QListSpecialMethods<QDomNode>> = {<No data
        clean = true
        layers = {d = 0x55fff23d4140}
        layerTreeCanvasElem = {<QDomNode> = {impl = 0x0}, <No data fields>}
        existingMaps = {d = 0x55ffe7fa2890}
        scales = {<QList<QString>> = {<QListSpecialMethods<QString>> =
{0x0}}, d = 0x7f6faf1c3760 <QListData::shared_null>}, d = 0x7f6faf1c3760
        res = {d = 0x7f6faf1c1680 <QArrayData::shared_null>}
        viewSettingsElement = {<QDomNode> = {impl = 0x55fff1cc5fd0}, <No
data fields>}
        timeSettingsElement = {<QDomNode> = {impl = 0x55fff1cc6740}, <No
data fields>}
        displaySettingsElement = {<QDomNode> = {impl = 0x55fff1cc41a0},
<No data fields>}
#30 0x00007f6fb0ded345 in QgsProject::unzip(QString const&,
flags=...) at ../src/core/qgsproject.cpp:3163
        archive = std::unique_ptr<class QgsProjectArchive> = {get() =
0x55fff19d04a0}
#31 0x00007f6fb0dd944c in QgsProject::read(QFlags<QgsProject::ReadFlag>)
(this=0x55ffe6d16190, flags=...) at ../src/core/qgsproject.cpp:1201
        storage = 0x0
        filename = {static null = {<No data fields>}, d = 0x55ffe7718c00}
        returnValue = false
#32 0x00007f6fb0dd8fed in QgsProject::read(QString const&,
flags=...) at ../src/core/qgsproject.cpp:1167
#33 0x00007f6fb38bbfe9 in QgisApp::addProject(QString const&)
(this=0x55ffe799ec90, projectFile=...) at ../src/app/qgisapp.cpp:6858
        refreshBlocker = {mReleased = false}
        returnCode = false
        dirtyBlocker = std::unique_ptr<class QgsProjectDirtyBlocker> =
{get() = 0x55fff17ce040}
        connectionScope = <incomplete type>
        badLayersHandled = false
        pfi = {d_ptr = {d = 0x55fff18488f0}}
        autoSetupOnFirstLayer = true
        usedCustomHandler = false
        customHandlerWantsThumbnail = false
        customHandlerIcon = {d = 0x0}
        __FUNCTION__ = "addProject"
#34 0x00007f6fb38c06c3 in QgisApp::openProject(QString const&)
(this=0x55ffe799ec90, fileName=...) at ../src/app/qgisapp.cpp:7330
#35 0x00007f6fb3abe67c in
QgsWelcomePage::recentProjectItemActivated(QModelIndex const&)
(this=0x55ffe7ae75f0, index=...) at ../src/app/qgswelcomepage.cpp:212
#36 0x00007f6fb3ac3309 in
QtPrivate::FunctorCall<QtPrivate::IndexesList<0>,
QtPrivate::List<QModelIndex const&>, void, void
(QgsWelcomePage::*)(QModelIndex const&)>::call(void
(QgsWelcomePage::*)(QModelIndex const&), QgsWelcomePage*, void**)
(f=(void (QgsWelcomePage::*)(class QgsWelcomePage * const, const class
QModelIndex &)) 0x7f6fb3abe612
<QgsWelcomePage::recentProjectItemActivated(QModelIndex const&)>,
o=0x55ffe7ae75f0, arg=0x7ffd57664a00) at
#37 0x00007f6fb3ac31b5 in QtPrivate::FunctionPointer<void
const&)>::call<QtPrivate::List<QModelIndex const&>, void>(void
#38 0x00007f6fb3ac2ff4 in QtPrivate::QSlotObject<void
(QgsWelcomePage::*)(QModelIndex const&), QtPrivate::List<QModelIndex
const&>, void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**,
bool*) (which=1, this_=0x55ffe791a9a0, r=0x55ffe7ae75f0,
a=0x7ffd57664a00, ret=0x0) at
#39 0x00007f6faf1104e8 in QMetaObject::activate(QObject*, int, int,
#40 0x00007f6fafd406b5 in QAbstractItemView::activated(QModelIndex
const&) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#41 0x00007f6fafd4ec1f in
QAbstractItemView::mouseDoubleClickEvent(QMouseEvent*) () at
#42 0x00007f6fafb24816 in QWidget::event(QEvent*) () at
#43 0x00007f6fafbd09ce in QFrame::event(QEvent*) () at
#44 0x00007f6fafd4e5fe in QAbstractItemView::viewportEvent(QEvent*) ()
#45 0x00007f6faf0e5763 in
QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*,
QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#46 0x00007f6fafae2c21 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#47 0x00007f6fafaec3e3 in QApplication::notify(QObject*, QEvent*) () at
#48 0x00007f6fb0b254c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffd57666410, receiver=0x55ffe7aa1d40, event=0x7ffd57665280) at
../src/core/qgsapplication.cpp:437
        done = true
        __FUNCTION__ = "notify"
#49 0x00007f6faf0e5a52 in QCoreApplication::notifyInternal2(QObject*,
#50 0x00007f6fafaeb4f3 in QApplicationPrivate::sendMouseEvent(QWidget*,
QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool,
bool) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#51 0x00007f6fafb40039 in  () at
#52 0x00007f6fafb42ec4 in  () at
#53 0x00007f6fafae2c32 in QApplicationPrivate::notify_helper(QObject*,
#54 0x00007f6fafaec190 in QApplication::notify(QObject*, QEvent*) () at
#55 0x00007f6fb0b254c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffd57666410, receiver=0x55fff19d4a10, event=0x7ffd57665840) at
        done = true
#56 0x00007f6faf0e5a52 in QCoreApplication::notifyInternal2(QObject*,
#57 0x00007f6faf4c6962 in
QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)
() at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#58 0x00007f6faf4c826b in
QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*)
#59 0x00007f6faf4a2ecb in
QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#60 0x00007f6f8b11bcda in  () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#61 0x00007f6fa744a60d in g_main_context_dispatch () at
/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#62 0x00007f6fa744a890 in  () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#63 0x00007f6fa744a91f in g_main_context_iteration () at
#64 0x00007f6faf13b7c1 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#65 0x00007f6faf0e46db in
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at
#66 0x00007f6faf0ec182 in QCoreApplication::exec() () at
#67 0x000055ffe4fe3aa9 in main(int, char**) (argc=1,
argv=0x7ffd57667718) at ../src/app/main.cpp:1618
        preApplicationLogMessages = {<QList<QString>> =
begin = 0, end = 0, array = {0x0}}, d = 0x55ffe6ef1a90}, d =
0x55ffe6ef1a90}}, <No data fields>}
        __FUNCTION__ = "main"
        mySnapshotFileName = {static null = {<No data fields>}, d =
        configLocalStorageLocation = {static null = {<No data fields>},
d = 0x55ffe6efaa70}
        profileName = {static null = {<No data fields>}, d = 0x55ffe6efbfd0}
        mySnapshotWidth = 800
        mySnapshotHeight = 600
        myHideSplash = false
        settingsMigrationForce = false
        mySkipVersionCheck = false
        hideBrowser = false
        myRestoreDefaultWindowState = false
        myRestorePlugins = true
        myCustomization = true
        dxfOutputFile = {static null = {<No data fields>}, d =
        dxfSymbologyMode = QgsDxfExport::SymbolLayerSymbology
        dxfScale = 50000
        dxfEncoding = {static null = {<No data fields>}, d =
0x55ffe4fee0a0 <main::{lambda()#2}::operator()() const::qstring_literal>}
        dxfMapTheme = {static null = {<No data fields>}, d =
        dxfExtent = {mXmin = 0, mYmin = 0, mXmax = 0, mYmax = 0}
        takeScreenShots = false
        screenShotsPath = {static null = {<No data fields>}, d =
        screenShotsCategories = 0
        myInitialExtent = {static null = {<No data fields>}, d =
0x55ffe4fee0e0 <main::{lambda()#3}::operator()() const::qstring_literal>}
        translationCode = {static null = {<No data fields>}, d =
0x55ffe6f282a0}
        authdbdirectory = {static null = {<No data fields>}, d =
        pythonfile = {static null = {<No data fields>}, d =
        customizationfile = {static null = {<No data fields>}, d =
0x55ffe7766f80}
        globalsettingsfile = {static null = {<No data fields>}, d =
0x55ffe6ef76f0}
        openClProgramFolder = {static null = {<No data fields>}, d =
        args = {<QList<QString>> = {<QListSpecialMethods<QString>> =
{0x0}}, d = 0x55ffe6ef8ff0}, d = 0x55ffe6ef8ff0}}, <No data fields>}
        myUseGuiFlag = true
        rootProfileFolder = {static null = {<No data fields>}, d =
0x55ffe6ef90e0}
        manager = {<QObject> = {<No data fields>}, static
<QObject::staticMetaObject>, stringdata = 0x7f6fb1463500
<qt_meta_stringdata_QgsUserProfileManager>, data = 0x7f6fb1463580
<qt_meta_data_QgsUserProfileManager>, static_metacall = 0x7f6fb05fe97e
<QgsUserProfileManager::qt_static_metacall(QObject*, QMetaObject::Call,
int, void**)>, relatedMetaObjects = 0x0, extradata = 0x0}},
mWatchProfiles = false, mWatcher = std::unique_ptr<class
QFileSystemWatcher> = {get() = 0x0}, mRootProfilePath = {static null =
{<No data fields>}, d = 0x55ffe6ef90e0}, mUserProfile =
std::unique_ptr<class QgsUserProfile> = {get() = 0x0}, mSettings =
std::unique_ptr<class QSettings> = {get() = 0x55ffe6ef6920}}
        profile = 0x55ffe6ef8d80
        profileFolder = {static null = {<No data fields>}, d =
0x55ffe6ef16f0}
        myApp = {<QApplication> = {<No data fields>}, static
staticMetaObject = {d = {superdata = 0x7f6faffd6620
<QApplication::staticMetaObject>, stringdata = 0x7f6fb1450c00
<qt_meta_stringdata_QgsApplication>, data = 0x7f6fb1450e00
<qt_meta_data_QgsApplication>, static_metacall = 0x7f6fb05e5dfe
<QgsApplication::qt_static_metacall(QObject*, QMetaObject::Call, int,
void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, static
QGIS_ORGANIZATION_NAME = 0x7f6fb1528d3a "QGIS", static
QGIS_ORGANIZATION_DOMAIN = 0x7f6fb1528d3f "qgis.org", static
QGIS_APPLICATION_NAME = 0x7f6fb1528d48 "QGIS3", static
mFileOpenEventReceiver31300 = 0x55ffe799ec90, static mInitialized31300 =
true, static mRunningFromBuildDir31300 = false, static sMaxThreads31300
= 5, mIconCache = {d = 0x55ffe6ff2230}, mCursorCache = {d =
0x55ffe7bf6a20}, mQgisTranslator = 0x55ffe708b0d0, mQtTranslator =
0x55ffe7043ce0, mDataItemProviderRegistry = 0x55ffe7b73200, mAuthManager
= 0x55ffe790a7e0, mApplicationMembers = 0x55ffe7021410, static
sApplicationMembers = 0x0, static sAuthManager = 0x0}
0x55ffe704f7b0, mGlobalSettings = 0x55ffe71a6700, mUsingGlobalArray = false}
        libPaths = {<QList<QString>> = {<QListSpecialMethods<QString>> =
{0x0}}, d = 0x55ffe775a5e0}, d = 0x55ffe775a5e0}}, <No data fields>}
        relLibPath = {static null = {<No data fields>}, d = 0x55ffe77142d0}
        customizationsettings = 0x55ffe771ff30
        systemEnvVars = {d = 0x55ffe70491a0}
        useCustomVars = false
        desiredStyle = {static null = {<No data fields>}, d =
0x55ffe7374620}
        theme = {static null = {<No data fields>}, d = 0x55ffe760efd0}
        activeStyleName = {static null = {<No data fields>}, d =
0x55ffe7e017f0}
        mySplashPath = {static null = {<No data fields>}, d =
0x7f6fb1529ea0 <QgsApplication::splashPath()::{lambda()#1}::operator()()
        myPixmap = <incomplete type>
        w = 600
        h = 300
        mypSplash = 0x55ffe7b652c0
        qgis = 0x55ffe799ec90
        sigwatch = {<QObject> = {<No data fields>}, static
<QObject::staticMetaObject>, stringdata = 0x55ffe502f940
<qt_meta_stringdata_UnixSignalWatcher>, data = 0x55ffe502fa00
<qt_meta_data_UnixSignalWatcher>, static_metacall = 0x55ffe4fea9a4
<UnixSignalWatcher::qt_static_metacall(QObject*, QMetaObject::Call, int,
void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, d_ptr =
0x7f6f840058c0}
        retval = 17
[Inferior 1 (process 233434) detached]
gdb returned 0
../src/core/qgsruntimeprofiler.cpp:80 : (end) [0ms] PROFILE: Map
settings initialization - 0
../src/gui/qgsmapcanvas.cpp:528 : (refresh) [0ms] CANVAS refresh -
invalid settings -> nothing to do
../src/core/qgsscalecalculator.cpp:40 : (setMapUnits) [0ms] Map units
set to 6
../src/gui/qgsmapcanvas.cpp:425 : (setDestinationCrs) [0ms] refreshing
after destination CRS changed
../src/core/providers/ogr/qgsogrprovider.cpp:506 : (QgsOgrProvider)
[0ms] Data source uri is
[/home/richard/bin/qgis_/master/debug/share/qgis/resources/data/world_map.gpkg|layername=countries]
../src/core/providers/ogr/qgsogrprovider.cpp:278 : (AnalyzeURI) [0ms]
Data source uri is
../src/core/providers/ogr/qgsogrprovider.cpp:4457 : (open) [0ms]
mFilePath:
../src/core/providers/ogr/qgsogrprovider.cpp:4458 : (open) [0ms]
mLayerIndex: 0
mSubsetString:
../src/core/providers/ogr/qgsogrprovider.cpp:4541 : (open) [6ms] OGR
../src/core/providers/ogr/qgsogrconnpool.cpp:39 : (QgsOgrConnPool)
[12ms] Entering.
../src/core/providers/ogr/qgsogrconnpool.cpp:39 : (QgsOgrConnPool) [0ms]
Leaving.
QGIS died on signal 11[New LWP 4663]
[New LWP 4664]
[New LWP 4665]
[New LWP 4666]
[New LWP 4667]
[New LWP 4668]
[New LWP 4669]
[New LWP 4670]
[New LWP 4671]
[New LWP 4672]
[New LWP 4673]
[New LWP 4674]
[New LWP 4675]
[New LWP 4677]
[New LWP 4679]
[New LWP 4683]
[New LWP 4979]
[New LWP 5018]
[New LWP 5019]
[New LWP 5020]
[New LWP 5021]
[New LWP 5022]
[New LWP 5023]
[New LWP 5123]
[New LWP 5124]
[New LWP 5125]
[New LWP 5126]
[New LWP 5154]
[New LWP 5167]
[New LWP 5173]
[New LWP 5180]
0x00007f652cc4dc0e in __GI___waitpid (pid=5234, stat_loc=0x7ffdc18cc014,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
[Current thread is 1 (Thread 0x7f651ae78f40 (LWP 4655))]
#0  0x00007f652cc4dc0e in __GI___waitpid (pid=5234,
stat_loc=0x7ffdc18cc014, options=0) at
#1  0x000055fdc95e42c0 in qgisCrash(int) (signal=11) at
        status = 22013
        pidstr = "--pid=4655\000\062e\177\000\000\377\377\377\377",
'\000' <repeats 11 times>
        gdbpid = 5234
        exename =
"/home/richard/bin/qgis_/master/debug/bin/qgis\000\000\000\377\377\377\377\000\000\000\000\361\023A2e\177\000\000\210<\036.e\177\000\000xH\006\060e\177\000\000\300\302\214\301\375\177\000\000\260\036\270\330\375U\000\000\020\000\000\000\000\000\000\000\202\260\000/e\177\000\000\000\000\000\000\000\000\000\000\363ZA2e\177\000\000\005",
'\000' <repeats 15 times>,
"pÌ\301\375\177\000\000\310a\037.e\177\000\000\200\302\214\301\375\177\000\000\n\305A2e\177\000\000\060Ì\301\375\177\000\000*\000\000\000\000\000\000\000\327\302\214\301\375\177\000\000\327\302\214\301\375\177"...
        len = 45
#2  0x00007f652cbbe800 in <signal handler called> () at
#3  0x00007f652721bfb0 in sqlite3_str_vappendf () at
#4  0x00007f652723f14f in sqlite3_vmprintf () at
#5  0x00007f652724044f in sqlite3_mprintf () at
#6  0x00007f652ef3f359 in QgsSqliteUtils::uniqueFields(sqlite3*, QString
const&, QString&) (connection=0x55fdd8862088, tableName=...,
        uniqueFieldsResults = {q_hash = {{d = 0x7f652d2876e0
<QHashData::shared_null>, e = 0x7f652d2876e0 <QHashData::shared_null>}}}
        zErrMsg = 0x0
        sql = {static null = {<No data fields>}, d = 0x55fdd8b4b860}
        rc = 0
        uniqueFieldMatch =
= 0x7f652cf2bce0, static _S_classic = <optimized out>, static _S_global
weak count 0) = {get() = 0x55fdd8b81eb0}}
#7  0x00007f652eb42d00 in QgsOgrProvider::loadFields()
(this=0x55fdcb8f8dd0) at ../src/core/providers/ogr/qgsogrprovider.cpp:1116
        errMsg = {static null = {<No data fields>}, d = 0x7f652d285680
std::unique_ptr<struct sqlite3> = {get() = 0x55fdd8862088}, <No data
fields>}
        fdef = @0x55fdd8883d90: {hDefn = 0x55fdd8885560, layer =
0x55fdd8883d50}
        fidColumn = {d = 0x55fdd8889a90}
        uniqueFieldNames = {q_hash = {{d = 0x7f652d2876e0
        createdFields = 32613
#8  0x00007f652eb4277d in QgsOgrProvider::setEncoding(QString const&)
(this=0x55fdcb8f8dd0, e=...) at
staticMetaObject = {d = {superdata = 0x7f652d456980
<QObject::staticMetaObject>, stringdata = 0x7f652f523340
<qt_meta_stringdata_QgsSettings>, data = 0x7f652f523380
<qt_meta_data_QgsSettings>, static_metacall = 0x7f652e6beb42
0x55fdd8829da0, mGlobalSettings = 0x55fdd8885d30, mUsingGlobalArray = false}
#9  0x00007f652eb60257 in QgsOgrProvider::open(QgsOgrProvider::OpenMode)
(this=0x55fdcb8f8dd0, mode=QgsOgrProvider::OpenModeInitial) at
0x55fdd881f080}
0x7f652d285680 <QArrayData::shared_null>}
        errCause = {static null = {<No data fields>}, d = 0x7f652d285680
#10 0x00007f652eb3e2b7 in QgsOgrProvider::QgsOgrProvider(QString const&,
QgsDataProvider::ProviderOptions const&) (this=0x55fdcb8f8dd0, uri=...,
        nMaxIntLen = 32765
        nMaxInt64Len = -1047734656
        nMaxDoubleLen = 0
        nDateLen = 22013
        supportsTime = 22
        supportsBinary = 96
        pszDataTypes = 0x7f652ef07cb6
        supportsDate = 204
0x55fdd8820500, mGlobalSettings = 0x55fdd8820650, mUsingGlobalArray = false}
        nativeTypes =
0x5ed6394c}, d = 0x5ed6394c}}
        supportsDateTime = 50
#11 0x00007f652eb58ad5 in QgsOgrProviderMetadata::createProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x55fdcc1450f0,
#12 0x00007f652ef05e45 in QgsProviderRegistry::createProvider(QString
(this=0x55fdcc4e2f80, providerKey=..., dataSource=..., options=...) at
        metadata = 0x55fdcc1450f0
#13 0x00007f652efe4d6e in QgsVectorLayer::setDataProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x55fdd881f3a0,
#14 0x00007f652efe43a0 in QgsVectorLayer::setDataSource(QString const&,
bool) (this=0x55fdd881f3a0, dataSource=..., baseName=..., provider=...,
#15 0x00007f652efdab19 in QgsVectorLayer::QgsVectorLayer(QString const&,
(this=0x55fdd881f3a0, vectorLayerPath=..., baseName=...,
        providerOptions = {transformContext = {d = {d = 0x55fdd8755870}}}
0x0, mGlobalSettings = 0x55fdd8803a80, mUsingGlobalArray = 176}
#16 0x00007f6530e124d8 in
(this=0x55fdd8803a80, parent=0x55fdcb823e70) at
stringdata = 0x7f652f5164c0
<qt_meta_stringdata_QgsCoordinateReferenceSystem>, data = 0x7f652f5165e0
0x7f652e6abee2
QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x7f6530009a90
{d = 0x55fdcbdaa0f0}, mValidationHint = {static null = {<No data
fields>}, d = 0x7f652d285680 <QArrayData::shared_null>}, static
sCustomSrsValidation = 0x7f6531934be4
        layerPath = {static null = {<No data fields>}, d = 0x55fdd881ef70}
#17 0x00007f6530fe82d3 in
Ui_QgsProjectionSelectorBase::setupUi(QWidget*) (this=0x55fdcb822ec0,
QgsProjectionSelectorBase=0x55fdcb822e90) at
src/ui/ui_qgsprojectionselectorbase.h:186
stringdata = 0x7f652df432a0, data = 0x7f652df43180, static_metacall =
0, verStretch = 0, horPolicy = 7, verPolicy = 5, ctype = 0, hfw = 0, wfh
= 0, retainSizeWhenHidden = 0}, data = 5701632}}
        icon = {d = 0x55fdcb8239e0}
        font = {static staticMetaObject = {d = {superdata = 0x0,
stringdata = 0x7f652d9966c0, data = 0x7f652d996400, static_metacall =
0x0, relatedMetaObjects = 0x0, extradata = 0x0}}, d = {d =
0x55fdd87d7930}, resolve_mask = 16}
        sizePolicy1 = {static staticMetaObject = {d = {superdata = 0x0,
0, verStretch = 0, horPolicy = 7, verPolicy = 3, ctype = 0, hfw = 0, wfh
= 0, retainSizeWhenHidden = 0}, data = 3604480}}
        font1 = {static staticMetaObject = {d = {superdata = 0x0,
0x55fdd87fbe20}, resolve_mask = 2}
#18 0x00007f6530fdf43d in
QgsProjectionSelectionTreeWidget::QgsProjectionSelectionTreeWidget(QWidget*)
(this=0x55fdcb822e90, parent=0x55fdcb7de5b0) at
../src/gui/qgsprojectionselectiontreewidget.cpp:34
        f = {static staticMetaObject = {d = {superdata = 0x0, stringdata
= 0x7f652d9966c0, data = 0x7f652d996400, static_metacall = 0x0,
relatedMetaObjects = 0x0, extradata = 0x0}}, d = {d = 0x18},
resolve_mask = 3409199272}
#19 0x00007f6530fdbc4e in
Ui_QgsGenericProjectionSelectorBase::setupUi(QDialog*)
(this=0x55fdcb7de5e0, QgsGenericProjectionSelectorBase=0x55fdcb7de5b0)
at src/ui/ui_qgsgenericprojectionselectorbase.h:59
        icon = {d = 0x0}
#20 0x00007f6530fdb26f in
QgsProjectionSelectionDialog::QgsProjectionSelectionDialog(QWidget*,
QFlags<Qt::WindowType>) (this=0x55fdcb7de5b0, parent=0x55fdcb877080,
fl=...) at ../src/gui/qgsprojectionselectiondialog.cpp:30
#21 0x00007f64db366a17 in
QgsWFSSourceSelect::QgsWFSSourceSelect(QWidget*, QFlags<Qt::WindowType>,
QgsProviderRegistry::WidgetMode) (this=0x55fdcb877080,
parent=0x55fdd6db8350, fl=...,
theWidgetMode=QgsProviderRegistry::Embedded) at
../src/providers/wfs/qgswfssourceselect.cpp:87
0x300000003, mGlobalSettings = 0x7f65312ab7a0, mUsingGlobalArray = 88}
#22 0x00007f64db363e75 in
QgsWfsSourceSelectProvider::createDataSourceWidget(QWidget*,
QFlags<Qt::WindowType>, QgsProviderRegistry::WidgetMode) const
(this=0x55fdcc8d5d40, parent=0x55fdd6db8350, fl=...,
widgetMode=QgsProviderRegistry::Embedded) at
../src/providers/wfs/qgswfsprovidergui.cpp:34
#23 0x00007f65310f1fc5 in
QgsDataSourceManagerDialog::QgsDataSourceManagerDialog(QgsBrowserGuiModel*,
QWidget*, QgsMapCanvas*, QFlags<Qt::WindowType>) (this=0x55fdd6db8350,
browserModel=0x55fdcceebab0, parent=0x55fdcc2846d0,
canvas=0x55fdcc2b5920, fl=...) at
../src/gui/qgsdatasourcemanagerdialog.cpp:71
        dlg = 0x55fdd6c5ecc0
        provider = @0x55fdcc8eccb8: 0x55fdcc8d5d40
        __for_range = @0x7ffdc18ce878:
{<QListSpecialMethods<QgsSourceSelectProvider*>> = {<No data fields>},
0x55fdcc8ecc50}, d = 0x55fdcc8ecc50}}
        __for_begin = {i = 0x55fdcc8eccb8}
        __for_end = {i = 0x55fdcc8eccf0}
        sourceSelectProviders =
#24 0x00007f6531947a3d in QgisApp::dataSourceManager(QString const&)
(this=0x55fdcc2846d0, pageName=...) at ../src/app/qgisapp.cpp:2322
#25 0x00007f653194a5fe in QgisApp::<lambda()>::operator()(void) const
(__closure=0x55fdcb591300) at ../src/app/qgisapp.cpp:2662
        this = 0x55fdcc2846d0
        menuAllEdits = 0x7f653194a5fe
<QgisApp::<lambda()>::operator()(void) const+54>
#26 0x00007f65319d94a6 in
void, QgisApp::createActions()::<lambda()> >::call(QgisApp::<lambda()>
&, void **) (f=..., arg=0x7ffdc18cedf0) at
/usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:146
#27 0x00007f65319d764f in
QtPrivate::Functor<QgisApp::createActions()::<lambda()>,
0>::call<QtPrivate::List<>, void>(QgisApp::<lambda()> &, void *, void
/usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:256
#28 0x00007f65319d3fad in
QtPrivate::QFunctorSlotObject<QgisApp::createActions()::<lambda()>, 0,
QtPrivate::List<>, void>::impl(int, QtPrivate::QSlotObjectBase *,
QObject *, void **, bool *) (which=1, this_=0x55fdcb5912f0,
r=0x55fdcc2846d0, a=0x7ffdc18cedf0, ret=0x0) at
/usr/include/x86_64-linux-gnu/qt5/QtCore/qobjectdefs_impl.h:439
#29 0x00007f652d1d44e8 in QMetaObject::activate(QObject*, int, int,
#30 0x00007f652dba0812 in QAction::triggered(bool) () at
#31 0x00007f652dba2e52 in QAction::activate(QAction::ActionEvent) () at
#32 0x00007f652dc9a80c in  () at
#33 0x00007f652dc9aa35 in
QAbstractButton::mouseReleaseEvent(QMouseEvent*) () at
#34 0x00007f652dd89f0a in QToolButton::mouseReleaseEvent(QMouseEvent*)
#35 0x00007f652dbe8776 in QWidget::event(QEvent*) () at
#36 0x00007f652dd89fb4 in QToolButton::event(QEvent*) () at
#37 0x00007f652dba6c32 in QApplicationPrivate::notify_helper(QObject*,
#38 0x00007f652dbb03e3 in QApplication::notify(QObject*, QEvent*) () at
#39 0x00007f652ebe94c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffdc18d05f0, receiver=0x55fdcc0d5880, event=0x7ffdc18cf460) at
        done = true
#40 0x00007f652d1a9a52 in QCoreApplication::notifyInternal2(QObject*,
#41 0x00007f652dbaf4f3 in QApplicationPrivate::sendMouseEvent(QWidget*,
#42 0x00007f652dc04039 in  () at
#43 0x00007f652dc06ec4 in  () at
#44 0x00007f652dba6c32 in QApplicationPrivate::notify_helper(QObject*,
#45 0x00007f652dbb0190 in QApplication::notify(QObject*, QEvent*) () at
#46 0x00007f652ebe94c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffdc18d05f0, receiver=0x55fdd5dd44a0, event=0x7ffdc18cf9b0) at
        done = true
#47 0x00007f652d1a9a52 in QCoreApplication::notifyInternal2(QObject*,
#48 0x00007f652d58aa13 in
#49 0x00007f652d58c26b in
#50 0x00007f652d566ecb in
#51 0x00007f65091dfcda in  () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#52 0x00007f652550e60d in g_main_context_dispatch () at
#53 0x00007f652550e890 in  () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#54 0x00007f652550e91f in g_main_context_iteration () at
#55 0x00007f652d1ff7c1 in
#56 0x00007f652d1a86db in
#57 0x00007f652d1b0182 in QCoreApplication::exec() () at
#58 0x000055fdc95ebaa9 in main(int, char**) (argc=1,
argv=0x7ffdc18d18f8) at ../src/app/main.cpp:1618
begin = 0, end = 0, array = {0x0}}, d = 0x55fdcb55fa90}, d =
0x55fdcb55fa90}}, <No data fields>}
d = 0x55fdcb568a60}
        profileName = {static null = {<No data fields>}, d = 0x55fdcb56a010}
        hideBrowser = false
        dxfScale = 50000
0x55fdc95f60a0 <main::{lambda()#2}::operator()() const::qstring_literal>}
0x55fdc95f60e0 <main::{lambda()#3}::operator()() const::qstring_literal>}
0x55fdcb596730}
0x55fdcbe61ac0}
0x55fdcb5656f0}
{0x0}}, d = 0x55fdcb567030}, d = 0x55fdcb567030}}, <No data fields>}
        myUseGuiFlag = true
0x55fdcb567120}
<QObject::staticMetaObject>, stringdata = 0x7f652f527500
<qt_meta_stringdata_QgsUserProfileManager>, data = 0x7f652f527580
<qt_meta_data_QgsUserProfileManager>, static_metacall = 0x7f652e6c297e
{<No data fields>}, d = 0x55fdcb567120}, mUserProfile =
std::unique_ptr<class QSettings> = {get() = 0x55fdcb564920}}
        profile = 0x55fdcb566d80
0x55fdcb55f6f0}
staticMetaObject = {d = {superdata = 0x7f652e09a620
<QApplication::staticMetaObject>, stringdata = 0x7f652f514c00
<qt_meta_stringdata_QgsApplication>, data = 0x7f652f514e00
<qt_meta_data_QgsApplication>, static_metacall = 0x7f652e6a9dfe
QGIS_ORGANIZATION_NAME = 0x7f652f5ecd3a "QGIS", static
QGIS_ORGANIZATION_DOMAIN = 0x7f652f5ecd3f "qgis.org", static
QGIS_APPLICATION_NAME = 0x7f652f5ecd48 "QGIS3", static
mFileOpenEventReceiver31300 = 0x55fdcc2846d0, static mInitialized31300 =
= 5, mIconCache = {d = 0x55fdcb6903d0}, mCursorCache = {d =
0x55fdcc142f00}, mQgisTranslator = 0x55fdcb6d8a20, mQtTranslator =
0x55fdcb764f90, mDataItemProviderRegistry = 0x7f64f000f120, mAuthManager
= 0x55fdcc084320, mApplicationMembers = 0x55fdcb679730, static
0x55fdcb6c16a0, mGlobalSettings = 0x55fdcb6abaa0, mUsingGlobalArray = false}
{0x0}}, d = 0x55fdcbdc8550}, d = 0x55fdcbdc8550}}, <No data fields>}
        relLibPath = {static null = {<No data fields>}, d = 0x55fdcb57d290}
        customizationsettings = 0x55fdcbdd3f30
        systemEnvVars = {d = 0x55fdcb6c0970}
0x55fdcbb03750}
        theme = {static null = {<No data fields>}, d = 0x55fdcb60bc30}
0x55fdcc3b3c30}
0x7f652f5edea0 <QgsApplication::splashPath()::{lambda()#1}::operator()()
        w = 600
        h = 300
        mypSplash = 0x55fdcbe83270
        qgis = 0x55fdcc2846d0
<QObject::staticMetaObject>, stringdata = 0x55fdc9637940
<qt_meta_stringdata_UnixSignalWatcher>, data = 0x55fdc9637a00
<qt_meta_data_UnixSignalWatcher>, static_metacall = 0x55fdc95f29a4
0x7f6500005660}
        retval = 17
[Inferior 1 (process 4655) detached]
gdb returned 0
Data source uri is
mFilePath:
mLayerIndex: 0
mSubsetString:
../src/core/providers/ogr/qgsogrprovider.cpp:4541 : (open) [2ms] OGR
../src/core/providers/ogr/qgsogrconnpool.cpp:39 : (QgsOgrConnPool) [6ms]
Entering.
Leaving.
QGIS died on signal 11[New LWP 5734]
[New LWP 5735]
[New LWP 5736]
[New LWP 5737]
[New LWP 5739]
[New LWP 5740]
[New LWP 5741]
[New LWP 5742]
[New LWP 5744]
[New LWP 5745]
[New LWP 5746]
[New LWP 5747]
[New LWP 5748]
[New LWP 5750]
[New LWP 5751]
0x00007f7e94cfac0e in __GI___waitpid (pid=5758, stat_loc=0x7ffc61298e94,
[Current thread is 1 (Thread 0x7f7e82f25f40 (LWP 5726))]
#0  0x00007f7e94cfac0e in __GI___waitpid (pid=5758,
stat_loc=0x7ffc61298e94, options=0) at
#1  0x0000562f1bba72c0 in qgisCrash(int) (signal=11) at
        status = 22063
        pidstr = "--pid=5726\000\232~\177\000\000\377\377\377\377",
        gdbpid = 5758
        exename = "/home/richard/bin/qgis_/master/debug/bin/qgis",
'\000' <repeats 11 times>, "\363*L\232~\177\000\000\005", '\000'
<repeats 15 times>,
"`\221)a\374\177\000\000\310\061*\226~\177\000\000\360\220)a\374\177\000\000\n\225L\232~\177\000\000\240\221)a\374\177\000\000*\000\000\000\000\000\000\000G\221)a\374\177\000\000G\221)a\374\177\000\000\240\221)a\374\177\000\000\360w\355\224~\177\000\000\002\000\000\000\000\000\000\000\n\225L\232~\177\000\000\240\221)a\374\177\000\000*\000\000\000\000\000\000\000G\221)a\374\177\000\000"...
        len = 45
#2  0x00007f7e94c6b800 in <signal handler called> () at
#3  0x00007f7e8f2c8fb0 in sqlite3_str_vappendf () at
#4  0x00007f7e8f2ec14f in sqlite3_vmprintf () at
#5  0x00007f7e8f2ed44f in sqlite3_mprintf () at
#6  0x00007f7e96fec359 in QgsSqliteUtils::uniqueFields(sqlite3*, QString
const&, QString&) (connection=0x562f2032f0d8, tableName=...,
        uniqueFieldsResults = {q_hash = {{d = 0x7f7e953346e0
<QHashData::shared_null>, e = 0x7f7e953346e0 <QHashData::shared_null>}}}
        zErrMsg = 0x0
        sql = {static null = {<No data fields>}, d = 0x562f211e75b0}
        rc = 0
        uniqueFieldMatch =
= 0x7f7e94fd8ce0, static _S_classic = <optimized out>, static _S_global
weak count 0) = {get() = 0x562f2121db70}}
#7  0x00007f7e96befd00 in QgsOgrProvider::loadFields()
(this=0x562f1e6368c0) at ../src/core/providers/ogr/qgsogrprovider.cpp:1116
        errMsg = {static null = {<No data fields>}, d = 0x7f7e95332680
std::unique_ptr<struct sqlite3> = {get() = 0x562f2032f0d8}, <No data
fields>}
        fdef = @0x562f20f20980: {hDefn = 0x562f20f22170, layer =
0x562f20f20940}
        fidColumn = {d = 0x562f20f24990}
        uniqueFieldNames = {q_hash = {{d = 0x7f7e953346e0
        createdFields = 32638
#8  0x00007f7e96bef77d in QgsOgrProvider::setEncoding(QString const&)
(this=0x562f1e6368c0, e=...) at
staticMetaObject = {d = {superdata = 0x7f7e95503980
<QObject::staticMetaObject>, stringdata = 0x7f7e975d0340
<qt_meta_stringdata_QgsSettings>, data = 0x7f7e975d0380
<qt_meta_data_QgsSettings>, static_metacall = 0x7f7e9676bb42
0x562f20edf090, mGlobalSettings = 0x562f20f22940, mUsingGlobalArray = false}
#9  0x00007f7e96c0d257 in QgsOgrProvider::open(QgsOgrProvider::OpenMode)
(this=0x562f1e6368c0, mode=QgsOgrProvider::OpenModeInitial) at
0x562f20acbe40}
0x7f7e95332680 <QArrayData::shared_null>}
        errCause = {static null = {<No data fields>}, d = 0x7f7e95332680
#10 0x00007f7e96beb2b7 in QgsOgrProvider::QgsOgrProvider(QString const&,
QgsDataProvider::ProviderOptions const&) (this=0x562f1e6368c0, uri=...,
        nMaxIntLen = 32764
        nMaxInt64Len = 1630119152
        nMaxDoubleLen = 0
        nDateLen = 22063
        supportsTime = 167
        supportsBinary = 160
        pszDataTypes = 0x7f7e96fb4cb6
        supportsDate = 29
0x562f20628680, mGlobalSettings = 0x562f20bbe8d0, mUsingGlobalArray = false}
        nativeTypes =
0x5ed63a58}, d = 0x5ed63a58}}
        supportsDateTime = 214
#11 0x00007f7e96c05ad5 in QgsOgrProviderMetadata::createProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x562f1e067060,
#12 0x00007f7e96fb2e45 in QgsProviderRegistry::createProvider(QString
(this=0x562f1d981430, providerKey=..., dataSource=..., options=...) at
        metadata = 0x562f1e067060
#13 0x00007f7e97091d6e in QgsVectorLayer::setDataProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x562f20bbdb40,
#14 0x00007f7e970913a0 in QgsVectorLayer::setDataSource(QString const&,
bool) (this=0x562f20bbdb40, dataSource=..., baseName=..., provider=...,
#15 0x00007f7e97087b19 in QgsVectorLayer::QgsVectorLayer(QString const&,
(this=0x562f20bbdb40, vectorLayerPath=..., baseName=...,
        providerOptions = {transformContext = {d = {d = 0x562f206079f0}}}
0x0, mGlobalSettings = 0x7f7e94cb5dc7 <malloc_consolidate+311>,
#16 0x00007f7e98ebf4d8 in
(this=0x562f20ea63e0, parent=0x562f20e7df30) at
stringdata = 0x7f7e975c34c0
<qt_meta_stringdata_QgsCoordinateReferenceSystem>, data = 0x7f7e975c35e0
0x7f7e96758ee2
QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x7f7e980b6a90
{d = 0x562f1e0d91a0}, mValidationHint = {static null = {<No data
fields>}, d = 0x7f7e95332680 <QArrayData::shared_null>}, static
sCustomSrsValidation = 0x7f7e999e1be4
        layerPath = {static null = {<No data fields>}, d = 0x562f20acbf90}
#17 0x00007f7e990952d3 in
Ui_QgsProjectionSelectorBase::setupUi(QWidget*) (this=0x562f20e7d5a0,
QgsProjectionSelectorBase=0x562f20e7d570) at
stringdata = 0x7f7e95ff02a0, data = 0x7f7e95ff0180, static_metacall =
        icon = {d = 0x562f20e7e160}
stringdata = 0x7f7e95a436c0, data = 0x7f7e95a43400, static_metacall =
0x562f20e8c690}, resolve_mask = 16}
0x562f20e9e8e0}, resolve_mask = 2}
#18 0x00007f7e9908c43d in
(this=0x562f20e7d570, parent=0x562f20e76600) at
= 0x7f7e95a436c0, data = 0x7f7e95a43400, static_metacall = 0x0,
relatedMetaObjects = 0x0, extradata = 0x0}}, d = {d = 0x562f20e747c0},
resolve_mask = 488444072}
#19 0x00007f7e99088c4e in
(this=0x562f20e76630, QgsGenericProjectionSelectorBase=0x562f20e76600)
        icon = {d = 0x0}
#20 0x00007f7e9908826f in
QFlags<Qt::WindowType>) (this=0x562f20e76600, parent=0x562f20e5ad50,
#21 0x00007f7e4b39ba17 in
QgsProviderRegistry::WidgetMode) (this=0x562f20e5ad50,
parent=0x562f206065f0, fl=...,
0x300000003, mGlobalSettings = 0x7f7e993587a0, mUsingGlobalArray = 88}
#22 0x00007f7e4b398e75 in
(this=0x562f1e64c210, parent=0x562f206065f0, fl=...,
#23 0x00007f7e9919efc5 in
QWidget*, QgsMapCanvas*, QFlags<Qt::WindowType>) (this=0x562f206065f0,
browserModel=0x562f1ebdeaf0, parent=0x562f1da18510,
canvas=0x562f1db906e0, fl=...) at
        dlg = 0x562f20b00ec0
        provider = @0x562f1e6983b8: 0x562f1e64c210
        __for_range = @0x7ffc6129b6e8:
0x562f1e698350}, d = 0x562f1e698350}}
        __for_begin = {i = 0x562f1e6983b8}
        __for_end = {i = 0x562f1e6983f0}
#24 0x00007f7e999f4a3d in QgisApp::dataSourceManager(QString const&)
(this=0x562f1da18510, pageName=...) at ../src/app/qgisapp.cpp:2322
#25 0x00007f7e999f755f in QgisApp::<lambda()>::operator()(void) const
(__closure=0x562f1e6e6be0) at ../src/app/qgisapp.cpp:2651
        this = 0x562f1da18510
        menuAllEdits = 0x7f7e999f755f
<QgisApp::<lambda()>::operator()(void) const+47>
#26 0x00007f7e99a86471 in
&, void **) (f=..., arg=0x7ffc6129bc60) at
#27 0x00007f7e99a84625 in
#28 0x00007f7e99a80f27 in
QObject *, void **, bool *) (which=1, this_=0x562f1e6e6bd0,
r=0x562f1da18510, a=0x7ffc6129bc60, ret=0x0) at
#29 0x00007f7e952814e8 in QMetaObject::activate(QObject*, int, int,
#30 0x00007f7e95c4d812 in QAction::triggered(bool) () at
#31 0x00007f7e95c4fe52 in QAction::activate(QAction::ActionEvent) () at
#32 0x00007f7e95d4780c in  () at
#33 0x00007f7e95d47a35 in
#34 0x00007f7e95e36f0a in QToolButton::mouseReleaseEvent(QMouseEvent*)
#35 0x00007f7e95c95776 in QWidget::event(QEvent*) () at
#36 0x00007f7e95e36fb4 in QToolButton::event(QEvent*) () at
#37 0x00007f7e95c53c32 in QApplicationPrivate::notify_helper(QObject*,
#38 0x00007f7e95c5d3e3 in QApplication::notify(QObject*, QEvent*) () at
#39 0x00007f7e96c964c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffc6129d460, receiver=0x562f1d9a6a40, event=0x7ffc6129c2d0) at
        done = true
#40 0x00007f7e95256a52 in QCoreApplication::notifyInternal2(QObject*,
#41 0x00007f7e95c5c4f3 in QApplicationPrivate::sendMouseEvent(QWidget*,
#42 0x00007f7e95cb1039 in  () at
#43 0x00007f7e95cb3ec4 in  () at
#44 0x00007f7e95c53c32 in QApplicationPrivate::notify_helper(QObject*,
#45 0x00007f7e95c5d190 in QApplication::notify(QObject*, QEvent*) () at
#46 0x00007f7e96c964c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffc6129d460, receiver=0x562f207a3730, event=0x7ffc6129c820) at
        done = true
#47 0x00007f7e95256a52 in QCoreApplication::notifyInternal2(QObject*,
#48 0x00007f7e95637a13 in
#49 0x00007f7e9563926b in
#50 0x00007f7e95613ecb in
#51 0x00007f7e712cfcda in  () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#52 0x00007f7e8d5bb60d in g_main_context_dispatch () at
#53 0x00007f7e8d5bb890 in  () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#54 0x00007f7e8d5bb91f in g_main_context_iteration () at
#55 0x00007f7e952ac7c1 in
#56 0x00007f7e952556db in
#57 0x00007f7e9525d182 in QCoreApplication::exec() () at
#58 0x0000562f1bbaeaa9 in main(int, char**) (argc=3,
argv=0x7ffc6129e768) at ../src/app/main.cpp:1618
begin = 0, end = 0, array = {0x0}}, d = 0x562f1d3eca90}, d =
0x562f1d3eca90}}, <No data fields>}
d = 0x562f1d3f4250}
        profileName = {static null = {<No data fields>}, d = 0x562f1d3f9dc0}
        hideBrowser = false
        dxfScale = 50000
0x562f1bbb90a0 <main::{lambda()#2}::operator()() const::qstring_literal>}
0x562f1d3eca40}
0x562f1db19510}
0x562f1d3f26f0}
{0x0}}, d = 0x562f1d3f1e00}, d = 0x562f1d3f1e00}}, <No data fields>}
        myUseGuiFlag = true
0x562f1d3f48a0}
<QObject::staticMetaObject>, stringdata = 0x7f7e975d4500
<qt_meta_stringdata_QgsUserProfileManager>, data = 0x7f7e975d4580
<qt_meta_data_QgsUserProfileManager>, static_metacall = 0x7f7e9676f97e
{<No data fields>}, d = 0x562f1d3f48a0}, mUserProfile =
std::unique_ptr<class QSettings> = {get() = 0x562f1d3f1920}}
        profile = 0x562f1d3f6130
0x562f1d20f500}
staticMetaObject = {d = {superdata = 0x7f7e96147620
<QApplication::staticMetaObject>, stringdata = 0x7f7e975c1c00
<qt_meta_stringdata_QgsApplication>, data = 0x7f7e975c1e00
<qt_meta_data_QgsApplication>, static_metacall = 0x7f7e96756dfe
QGIS_ORGANIZATION_NAME = 0x7f7e97699d3a "QGIS", static
QGIS_ORGANIZATION_DOMAIN = 0x7f7e97699d3f "qgis.org", static
QGIS_APPLICATION_NAME = 0x7f7e97699d48 "QGIS3", static
mFileOpenEventReceiver31300 = 0x562f1da18510, static mInitialized31300 =
= -1, mIconCache = {d = 0x562f1d4ff5f0}, mCursorCache = {d =
0x562f1e5e9080}, mQgisTranslator = 0x562f1d51fb80, mQtTranslator =
0x562f1d588280, mDataItemProviderRegistry = 0x562f1d8b34c0, mAuthManager
= 0x562f1de80570, mApplicationMembers = 0x562f1d20e3a0, static
0x562f1d573930, mGlobalSettings = 0x562f1d7567d0, mUsingGlobalArray = false}
{0x0}}, d = 0x562f1e2d0510}, d = 0x562f1e2d0510}}, <No data fields>}
        relLibPath = {static null = {<No data fields>}, d = 0x562f1e2c9c60}
        customizationsettings = 0x562f1db194f0
        systemEnvVars = {d = 0x562f1daf6b10}
0x562f1bbb9ec0 <main::{lambda()#42}::operator()() const::qstring_literal>}
        theme = {static null = {<No data fields>}, d = 0x7f7e95332680
0x562f1e1fbd40}
0x7f7e9769aea0 <QgsApplication::splashPath()::{lambda()#1}::operator()()
        w = 600
        h = 300
        mypSplash = 0x562f1d960d20
        qgis = 0x562f1da18510
<QObject::staticMetaObject>, stringdata = 0x562f1bbfa940
<qt_meta_stringdata_UnixSignalWatcher>, data = 0x562f1bbfaa00
<qt_meta_data_UnixSignalWatcher>, static_metacall = 0x562f1bbb59a4
0x7f7e680057e0}
        retval = 17
[Inferior 1 (process 5726) detached]
gdb returned 0
/home/richard/bin/qgis: line 9:  5726 Aborted
/home/richard/bin/qgis_/master/debug/bin/qgis "$@"
mFilePath:
mLayerIndex: 0
mSubsetString:
Entering.
Leaving.
QGIS died on signal 11[New LWP 5790]
[New LWP 5791]
[New LWP 5792]
[New LWP 5793]
[New LWP 5795]
[New LWP 5796]
[New LWP 5797]
[New LWP 5798]
[New LWP 5799]
[New LWP 5800]
[New LWP 5801]
[New LWP 5802]
[New LWP 5803]
[New LWP 5805]
[New LWP 5806]
0x00007f2967f2dc0e in __GI___waitpid (pid=5841, stat_loc=0x7ffdaecbf494,
[Current thread is 1 (Thread 0x7f2956158f40 (LWP 5782))]
#0  0x00007f2967f2dc0e in __GI___waitpid (pid=5841,
stat_loc=0x7ffdaecbf494, options=0) at
#1  0x0000559f25bcd2c0 in qgisCrash(int) (signal=11) at
        status = 21919
        pidstr = "--pid=5782\000m)\177\000\000\377\377\377\377", '\000'
<repeats 11 times>
        gdbpid = 5841
        exename =
"/home/richard/bin/qgis_/master/debug/bin/qgis\000\000\000\377\377\377\377\000\000\000\000\361\023om)\177\000\000\210<Li)\177\000\000xH4k)\177\000\000@\367ˮ\375\177\000\000
|\342*\237U\000\000\020\000\000\000\000\000\000\000\202\260.j)\177\000\000\000\000\000\000\000\000\000\000\363Zom)\177\000\000\005",
"\360\367ˮ\375\177\000\000\310aMi)\177\000\000\000\367ˮ\375\177\000\000\n\305om)\177\000\000\260\367ˮ\375\177\000\000*\000\000\000\000\000\000\000W\367ˮ\375\177\000\000W\367ˮ\375\177"...
        len = 45
#2  0x00007f2967e9e800 in <signal handler called> () at
#3  0x00007f29624fbfb0 in sqlite3_str_vappendf () at
#4  0x00007f296251f14f in sqlite3_vmprintf () at
#5  0x00007f296252044f in sqlite3_mprintf () at
#6  0x00007f296a21f359 in QgsSqliteUtils::uniqueFields(sqlite3*, QString
const&, QString&) (connection=0x559f27f95ef8, tableName=...,
        uniqueFieldsResults = {q_hash = {{d = 0x7f29685676e0
<QHashData::shared_null>, e = 0x7f29685676e0 <QHashData::shared_null>}}}
        zErrMsg = 0x0
        sql = {static null = {<No data fields>}, d = 0x559f2adf16c0}
        rc = 0
        uniqueFieldMatch =
= 0x7f296820bce0, static _S_classic = <optimized out>, static _S_global
weak count 0) = {get() = 0x559f2ae27c20}}
#7  0x00007f2969e22d00 in QgsOgrProvider::loadFields()
(this=0x559f27f39490) at ../src/core/providers/ogr/qgsogrprovider.cpp:1116
        errMsg = {static null = {<No data fields>}, d = 0x7f2968565680
std::unique_ptr<struct sqlite3> = {get() = 0x559f27f95ef8}, <No data
fields>}
        fdef = @0x559f2aa6d340: {hDefn = 0x559f2aa6b430, layer =
0x559f2aa6d300}
        fidColumn = {d = 0x559f2aa6c650}
        uniqueFieldNames = {q_hash = {{d = 0x7f29685676e0
        createdFields = 32553
#8  0x00007f2969e2277d in QgsOgrProvider::setEncoding(QString const&)
(this=0x559f27f39490, e=...) at
staticMetaObject = {d = {superdata = 0x7f2968736980
<QObject::staticMetaObject>, stringdata = 0x7f296a803340
<qt_meta_stringdata_QgsSettings>, data = 0x7f296a803380
<qt_meta_data_QgsSettings>, static_metacall = 0x7f296999eb42
0x559f2ad959e0, mGlobalSettings = 0x559f2aa6ca10, mUsingGlobalArray = false}
#9  0x00007f2969e40257 in QgsOgrProvider::open(QgsOgrProvider::OpenMode)
(this=0x559f27f39490, mode=QgsOgrProvider::OpenModeInitial) at
0x559f2a631d20}
0x7f2968565680 <QArrayData::shared_null>}
        errCause = {static null = {<No data fields>}, d = 0x7f2968565680
#10 0x00007f2969e1e2b7 in QgsOgrProvider::QgsOgrProvider(QString const&,
QgsDataProvider::ProviderOptions const&) (this=0x559f27f39490, uri=...,
        nMaxIntLen = 32765
        nMaxInt64Len = -1362359552
        nMaxDoubleLen = 0
        nDateLen = 21919
        supportsTime = 208
        supportsBinary = 208
        pszDataTypes = 0x7f296a1e7cb6
        supportsDate = 39
0x559f2a90e940, mGlobalSettings = 0x559f28d92df0, mUsingGlobalArray = false}
        nativeTypes =
0x5ed63abe}, d = 0x5ed63abe}}
        supportsDateTime = 43
#11 0x00007f2969e38ad5 in QgsOgrProviderMetadata::createProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x559f27c1ff30,
#12 0x00007f296a1e5e45 in QgsProviderRegistry::createProvider(QString
(this=0x559f2795d480, providerKey=..., dataSource=..., options=...) at
        metadata = 0x559f27c1ff30
#13 0x00007f296a2c4d6e in QgsVectorLayer::setDataProvider(QString
const&, QgsDataProvider::ProviderOptions const&) (this=0x559f27f81480,
#14 0x00007f296a2c43a0 in QgsVectorLayer::setDataSource(QString const&,
bool) (this=0x559f27f81480, dataSource=..., baseName=..., provider=...,
#15 0x00007f296a2bab19 in QgsVectorLayer::QgsVectorLayer(QString const&,
(this=0x559f27f81480, vectorLayerPath=..., baseName=...,
        providerOptions = {transformContext = {d = {d = 0x559f27f82940}}}
0x0, mGlobalSettings = 0x7f2967ee8dc7 <malloc_consolidate+311>,
mUsingGlobalArray = 160}
#16 0x00007f296c0f24d8 in
(this=0x559f2ad5f800, parent=0x559f27f45920) at
stringdata = 0x7f296a7f64c0
<qt_meta_stringdata_QgsCoordinateReferenceSystem>, data = 0x7f296a7f65e0
0x7f296998bee2
QMetaObject::Call, int, void**)>, relatedMetaObjects = 0x7f296b2e9a90
{d = 0x559f27add310}, mValidationHint = {static null = {<No data
fields>}, d = 0x7f2968565680 <QArrayData::shared_null>}, static
sCustomSrsValidation = 0x7f296cc14be4
        layerPath = {static null = {<No data fields>}, d = 0x559f27f45070}
#17 0x00007f296c0f9578 in
(this=0x559f27f45950, QgsCoordinateOperationWidgetBase=0x559f27f45920)
stringdata = 0x7f29692232a0, data = 0x7f2969223180, static_metacall =
41, verStretch = 127, horPolicy = 0, verPolicy = 0, ctype = 0, hfw = 0,
wfh = 0, retainSizeWhenHidden = 0}, data = 32553}}
#18 0x00007f296c0f2f1d in
(this=0x559f27f45920, parent=0x7ffdaecc19a0) at
#19 0x00007f296c10ffea in
Ui_QgsDatumTransformDialogBase::setupUi(QDialog*) (this=0x7ffdaecc19d0,
QgsDatumTransformDialogBase=0x7ffdaecc19a0) at
#20 0x00007f296c10cfad in
QgsMapCanvas*, bool) (this=0x7ffdaecc19a0, sCrs=..., dCrs=...,
selectedDatumTransforms=..., parent=0x559f27d9e420, f=...,
selectedProj=..., mapCanvas=0x559f27c87410, allowFallback=true) at
0x7f296998bee2
{d = 0x7ffdaecc1830}, mValidationHint = {static null = {<No data
fields>}, d = 0x7ffdaecc1830}, static sCustomSrsValidation =
0x7f296cc14be4 <customSrsValidation_(QgsCoordinateReferenceSystem&)>,
0x0, stringdata = 0x7f296a7f64c0
0x7f296998bee2
{d = 0x7ffdaecc1800}, mValidationHint = {static null = {<No data
fields>}, d = 0x7f2969fb3c98
static sCustomSrsValidation = 0x7f296cc14be4
        deets = {sourceTransformId = -1362356256, destinationTransformId
= 32765, proj = {static null = {<No data fields>}, d = 0x559f25bd6ded
<QString::~QString()+27>}, isAvailable = 128, allowFallback = 24}
#21 0x00007f296c10ca6f in
const&) (sourceCrs=..., destinationCrs=..., parent=0x559f27d9e420,
mapCanvas=0x559f27c87410, windowTitle=...) at
        context = {d = {d = 0x559f277753e0}}
{gridLayout = 0x559f2ad23fc0, mButtonBox = 0x559f2ad25fc0, textEdit =
0x559f2ad29c60, mCrsStackedWidget = 0x559f2ad34610, page =
0x559f2ad34ed0, verticalLayout = 0x559f2ad34a00, gridLayout_4 =
0x559f2ad351f0, label = 0x559f2ad35530, mSourceProjectionSelectionWidget
= 0x559f2ad35950, label_2 = 0x559f2ad3a9c0,
mDestinationProjectionSelectionWidget = 0x559f2ad37680, page_2 =
0x559f2ad52700, verticalLayout_2 = 0x559f2ad530c0, gridLayout_5 =
0x559f2ad53180, label_3 = 0x559f2ad532f0, label_4 = 0x559f2ad53710,
mDestCrsLabel = 0x559f2ad53b20, mSourceCrsLabel = 0x559f2ad54000,
mCoordinateOperationsWidget = 0x7f2968745d48}, <No data fields>}, static
staticMetaObject = {d = {superdata = 0x7f296938f8c0
<QDialog::staticMetaObject>, stringdata = 0x7f296c46a120
<qt_meta_stringdata_QgsDatumTransformDialog>, data = 0x7f296c46a260
<qt_meta_data_QgsDatumTransformDialog>, static_metacall = 0x7f296b9403f0
QgsTemporaryCursorRestoreOverride> = {get() = 0x559f2ad22cf0}}
#22 0x00007f296cc9d075 in
(this=0x559f27d9e420, sourceCrs=..., destinationCrs=...,
layer=0x559f2a2ab3b0) at ../src/app/qgisapp.cpp:15229
        title = {static null = {<No data fields>}, d = 0x559f2ad2d340}
#23 0x00007f296cc98177 in QgisApp::addRasterLayer(QgsRasterLayer*)
(this=0x559f27d9e420, rasterLayer=0x559f2a2ab3b0) at
../src/app/qgisapp.cpp:14606
        myList = {<QListSpecialMethods<QgsMapLayer*>> = {<No data
0x559f27f963f0}, d = 0x559f27f963f0}}
#24 0x00007f296cc98c32 in QgisApp::addRasterLayerPrivate(QString const&,
QString const&, QString const&, bool, bool) (this=0x559f27d9e420,
uri=..., name=..., providerKey=..., guiWarning=true, guiUpdate=true) at
../src/app/qgisapp.cpp:14686
        refreshBlocker = std::unique_ptr<class
QgisApp::QgsCanvasRefreshBlocker> = {get() = 0x559f27f7dc00}
        shortName = {static null = {<No data fields>}, d = 0x559f2a82e8c0}
        reRasterFile = {d = {d = 0x559f2b7b3e60}}
        matchRasterFile = {d = {d = 0x559f27f7dd50}}
0x559f27f7dbe0, mGlobalSettings = 0x559f2b7b4280, mUsingGlobalArray = false}
        baseName = {static null = {<No data fields>}, d = 0x559f2a82e8c0}
        __FUNCTION__ = "addRasterLayerPrivate"
        layer = 0x559f2a2ab3b0
        error = {mMessageList = {<QListSpecialMethods<QgsErrorMessage>>
= {<No data fields>}, {p = {static shared_null = {ref = {atomic =
{0x0}}, d = 0x7f2968567760 <QListData::shared_null>}, d = 0x7f2968567760
<QListData::shared_null>}}}
        title = {static null = {<No data fields>}, d = 0x7f2968565680
        ok = false
#25 0x00007f296cc992a2 in QgisApp::addRasterLayer(QString const&,
QString const&, QString const&) (this=0x559f27d9e420, uri=...,
baseName=..., providerKey=...) at ../src/app/qgisapp.cpp:14730
#26 0x00007f296cc25a40 in
QgisApp::handleDropUriList(QList<QgsMimeDataUtils::Uri> const&)
(this=0x559f27d9e420, lst=...) at ../src/app/qgisapp.cpp:2033
        u = @0x559f2baf0690: {layerType = {static null = {<No data
fields>}, d = 0x7f296a91d560 <QgsLayerItem::mimeUri()
const::{lambda()#2}::operator()() const::qstring_literal>}, providerKey
= {static null = {<No data fields>}, d = 0x7f29264b5e60
<QgsXyzLayerItem::QgsXyzLayerItem(QgsDataItem*, QString, QString,
QString const&)::{lambda()#1}::operator()() const::qstring_literal>},
name = {static null = {<No data fields>}, d = 0x559f2a82e8c0}, uri =
{static null = {<No data fields>}, d = 0x559f2a82c5b0}, supportedCrs =
{<QList<QString>> = {<QListSpecialMethods<QString>> = {<No data
<QListData::shared_null>}}, <No data fields>}, supportedFormats =
<QListData::shared_null>}}, <No data fields>}, layerId = {static null =
{<No data fields>}, d = 0x7f2968565680 <QArrayData::shared_null>}, pId =
<QArrayData::shared_null>}, wkbType = QgsWkbTypes::Unknown}
        uri = {static null = {<No data fields>}, d = 0x559f2a82c5b0}
        i = 0
        task = {mTask = 0x559f27f79f40}
        count = 0
#27 0x00007f296d02d770 in
QgsLayerItemGuiProvider::handleDoubleClick(QgsDataItem*,
QgsDataItemGuiContext) (this=0x559f28c68f60, item=0x559f29535fb0) at
../src/app/browser/qgsinbuiltdataitemproviders.cpp:524
        layerUriList = {<QListSpecialMethods<QgsMimeDataUtils::Uri>> =
{0x0}}, d = 0x559f2baf17a0}, d = 0x559f2baf17a0}}
        layerItem = 0x559f29535fb0
#28 0x00007f296c09ff08 in
QgsBrowserDockWidget::itemDoubleClicked(QModelIndex const&)
(this=0x559f28c658a0, index=...) at ../src/gui/qgsbrowserdockwidget.cpp:180
        provider = 0x559f28c68f70
        __for_range = @0x7ffdaecc21d0:
{<QListSpecialMethods<QgsDataItemGuiProvider*>> = {<No data fields>}, {p
0x559f287071a0}, d = 0x559f287071a0}}
        __for_begin = {i = 0x559f28707248}
        __for_end = {i = 0x559f28707258}
        item = 0x559f29535fb0
        context = {mMessageBar = 0x559f27e0d000}
        providers = {<QListSpecialMethods<QgsDataItemGuiProvider*>> =
{0x0}}, d = 0x559f287071a0}, d = 0x559f287071a0}}
#29 0x00007f296c0a67a0 in
(QgsBrowserDockWidget::*)(QModelIndex const&)>::call(void
(QgsBrowserDockWidget::*)(QModelIndex const&), QgsBrowserDockWidget*,
void**) (f=(void (QgsBrowserDockWidget::*)(class QgsBrowserDockWidget *
const, const class QModelIndex &)) 0x7f296c09fdf2
<QgsBrowserDockWidget::itemDoubleClicked(QModelIndex const&)>,
o=0x559f28c658a0, arg=0x7ffdaecc23e0) at
#30 0x00007f296c0a6416 in QtPrivate::FunctionPointer<void
#31 0x00007f296c0a5d46 in QtPrivate::QSlotObject<void
QtPrivate::List<QModelIndex const&>, void>::impl(int,
QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) (which=1,
this_=0x559f28c8a0d0, r=0x559f28c658a0, a=0x7ffdaecc23e0, ret=0x0) at
#32 0x00007f29684b44e8 in QMetaObject::activate(QObject*, int, int,
#33 0x00007f29690e4665 in QAbstractItemView::doubleClicked(QModelIndex
#34 0x00007f296915d183 in QTreeView::mouseDoubleClickEvent(QMouseEvent*)
#35 0x00007f2968ec8816 in QWidget::event(QEvent*) () at
#36 0x00007f2968f749ce in QFrame::event(QEvent*) () at
#37 0x00007f29690f25fe in QAbstractItemView::viewportEvent(QEvent*) ()
#38 0x00007f296915f2db in QTreeView::viewportEvent(QEvent*) () at
#39 0x00007f2968489763 in
#40 0x00007f2968e86c21 in QApplicationPrivate::notify_helper(QObject*,
#41 0x00007f2968e903e3 in QApplication::notify(QObject*, QEvent*) () at
#42 0x00007f2969ec94c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffdaecc3e30, receiver=0x559f28c7f690, event=0x7ffdaecc2ca0) at
        done = true
#43 0x00007f2968489a52 in QCoreApplication::notifyInternal2(QObject*,
#44 0x00007f2968e8f4f3 in QApplicationPrivate::sendMouseEvent(QWidget*,
#45 0x00007f2968ee4039 in  () at
#46 0x00007f2968ee6ec4 in  () at
#47 0x00007f2968e86c32 in QApplicationPrivate::notify_helper(QObject*,
#48 0x00007f2968e90190 in QApplication::notify(QObject*, QEvent*) () at
#49 0x00007f2969ec94c9 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7ffdaecc3e30, receiver=0x559f2a7ff2c0, event=0x7ffdaecc3260) at
        done = true
#50 0x00007f2968489a52 in QCoreApplication::notifyInternal2(QObject*,
#51 0x00007f296886a962 in
#52 0x00007f296886c26b in
#53 0x00007f2968846ecb in
#54 0x00007f2944502cda in  () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#55 0x00007f29607ee60d in g_main_context_dispatch () at
#56 0x00007f29607ee890 in  () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#57 0x00007f29607ee91f in g_main_context_iteration () at
#58 0x00007f29684df7c1 in
#59 0x00007f29684886db in
#60 0x00007f2968490182 in QCoreApplication::exec() () at
#61 0x0000559f25bd4aa9 in main(int, char**) (argc=3,
argv=0x7ffdaecc5138) at ../src/app/main.cpp:1618
begin = 0, end = 0, array = {0x0}}, d = 0x559f273c6a90}, d =
0x559f273c6a90}}, <No data fields>}
d = 0x559f273ce250}
        profileName = {static null = {<No data fields>}, d = 0x559f273c6a40}
        hideBrowser = false
        dxfScale = 50000
0x559f25bdf0a0 <main::{lambda()#2}::operator()() const::qstring_literal>}
0x559f273d1700}
0x559f27777610}
0x559f273cc6f0}
{0x0}}, d = 0x559f273cbe00}, d = 0x559f273cbe00}}, <No data fields>}
        myUseGuiFlag = true
0x559f273ce8a0}
<QObject::staticMetaObject>, stringdata = 0x7f296a807500
<qt_meta_stringdata_QgsUserProfileManager>, data = 0x7f296a807580
<qt_meta_data_QgsUserProfileManager>, static_metacall = 0x7f29699a297e
{<No data fields>}, d = 0x559f273ce8a0}, mUserProfile =
std::unique_ptr<class QSettings> = {get() = 0x559f273cb920}}
        profile = 0x559f273d2ef0
0x559f271e9500}
staticMetaObject = {d = {superdata = 0x7f296937a620
<QApplication::staticMetaObject>, stringdata = 0x7f296a7f4c00
<qt_meta_stringdata_QgsApplication>, data = 0x7f296a7f4e00
<qt_meta_data_QgsApplication>, static_metacall = 0x7f2969989dfe
QGIS_ORGANIZATION_NAME = 0x7f296a8ccd3a "QGIS", static
QGIS_ORGANIZATION_DOMAIN = 0x7f296a8ccd3f "qgis.org", static
QGIS_APPLICATION_NAME = 0x7f296a8ccd48 "QGIS3", static
mFileOpenEventReceiver31300 = 0x559f27d9e420, static mInitialized31300 =
= -1, mIconCache = {d = 0x559f275193b0}, mCursorCache = {d =
0x559f285bda30}, mQgisTranslator = 0x559f275343a0, mQtTranslator =
0x559f27565f30, mDataItemProviderRegistry = 0x559f27b9f5d0, mAuthManager
= 0x559f279ddd30, mApplicationMembers = 0x559f275df400, static
        settings = {<QObject> = {<No data fields>}, static
<QgsSettings::qt_static_metacall(QObject*, QMetaObject::Call, int,
void**)>, relatedMetaObjects = 0x0, extradata = 0x0}}, mUserSettings =
0x559f2746ed30, mGlobalSettings = 0x559f27515490, mUsingGlobalArray = false}
{_q_value = {<std::__atomic_base<int>> = {static _S_alignment = 4, _M_i
= -1}, <No data fields>}}}, alloc = 0, begin = 0, end = 0, array =
{0x0}}, d = 0x559f2754ae60}, d = 0x559f2754ae60}}, <No data fields>}
        relLibPath = {static null = {<No data fields>}, d = 0x559f2773b7f0}
        customizationsettings = 0x559f27771a10
        systemEnvVars = {d = 0x559f2748a730}
0x559f25bdfec0 <main::{lambda()#42}::operator()() const::qstring_literal>}
        theme = {static null = {<No data fields>}, d = 0x7f2968565680
0x559f27dc9130}
0x7f296a8cdea0 <QgsApplication::splashPath()::{lambda()#1}::operator()()
        w = 600
        h = 300
        mypSplash = 0x559f27a6fb40
        qgis = 0x559f27d9e420
<QObject::staticMetaObject>, stringdata = 0x559f25c20940
<qt_meta_stringdata_UnixSignalWatcher>, data = 0x559f25c20a00
<qt_meta_data_UnixSignalWatcher>, static_metacall = 0x559f25bdb9a4
0x559f27a2d6f0}
        retval = 17
[Inferior 1 (process 5782) detached]
gdb returned 0
More information about the QGIS-Developer mailing list
