[QGIS-Developer] GeoPackage - where are we -where do we go
Olivier Dalang
olivier.dalang at gmail.com
Tue Jun 2 06:58:38 PDT 2020
Hi !
About WAL related issues :
I just tried to reproduce the original issue that lead to using WAL on
local files (https://github.com/qgis/QGIS/issues/23283) but could not
reproduce it (recent master, Windows 10). Does the issue still exist
on other platforms ? (this can be tested by changing the
QgsSetting qgis/walForSqlite3 to false and following the steps in the
issue).
If not, maybe we could consider switching back to journal_mode=DELETE, as
it seems it could solve some of the issues with gpkgs. If yes, would
sharing just one sqlite connection handle for all accesses to a sqlite file
be a sensible approach to avoid the deadlock without using WAL ? I' n
Cheers !
Olivier
On Fri, 8 May 2020 at 11:30, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi list,
> I wondered about the state of GeoPackage. Personally, cince it has been
> introduced to qgis and evenmore since it has been selected as the default
> format, I have never grown to fully and completely.
> I do not want to trigger a evangelical discussion here. I'd like to see
> where we are and what we can reasonably do to have a default file format
> which can be recommended with no bad feelings.
> Here follow a couple of observations over the years, some of them
> properties of the specs I believe:
> * The fid requirement
> I sometimes want my features to be identified by uuids or others. They
> also tend to accumulate if derived datasets are created (through processing
> etc). If I need some pseudo stable primary key there is a rowid builtin
> into sqlite, we don't need a second one.
> Possible mitigation: alter the ogr implementation. possibly alter the
> standard (required?)
> * The modification on r/o open
> Has caused too much pain on git.
> Possible mitigation: a) switch to journal mode=delete (not an easy
> option because of https://issues.qgis.org/issues/15351) b) only switch to
> wal mode when layers are put into edit mode (I have strong doubts this is a
> safe thing to do)
> * The network share freeze
> Our default file should play nicely with (windows) network shares. It's
> clear to everyone that we can't expect concurrent writes. But it should
> "just work" for concurrent read by many.
> Possible mitigation: switch to journal mode=delete for network shares
> (we are looking into this)
> * The wal file appearing next to the file
> It is confusing to newcomers and looks almost like a sidecar file. I
> would care less if it was put into some system cache folder instead of just
> into my data folder. Or at least if it was a hidden file.
> Possible mitigation: switch to journal mode=delete (not an easy option
> * The couple of corrupted files I have received over the years which
> could only be repaired by a command line "dump contents as sql and execute
> into new file"
> I have not found a way to reproduce this. Some of them were produced by
> older qgis versions making it easy to violate foreign key constraints and
> hard to recover. This has been fixed.
> Possible mitigation: offer a "repair" option in qgis. Through processing
> or "on the fly" upon detection.
> * Default value magic replace values on insert (with no possibility to
> pre-evaluate them)
> E.g. a global sequence like on postgres would be nice. Can be worked
> around through default values in qgis though.
> Possible mitigation: a)add it as a feature to sqlite. b) use qgis
> default values. c) live with it.
> * The requirement for a single geometry column per table
> I just don't see a good reason to forbid that
> Possible mitigation: a) alter the standard. b) ignore the standard and
> patch the ogr implementation.
> I wonder how others feel about these topics.
> - Are there more pain points I forgot to list?
> - Do you see more approaches to mitigate these problems?
> - Is someone already working on these issues?
> It would be great to have a standard file format that we can fully trust.
> Let's make a reality check if GeoPackage can be this format.
> Best regards
> Matthias Kuhn
> +41 (0)76 435 67 63 <+41764356763>
> [image: OPENGIS.ch Logo] <http://www.opengis.ch>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200602/b6217245/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200602/b6217245/attachment-0001.png>
