[QGIS-Developer] pyqgis doc build broken?
DelazJ delazj at gmail.com
Wed Jun 3 01:24:34 PDT 2020
Thanks, Denis.
Le lun. 1 juin 2020 à 16:06, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi Harissou,
> Thanks for the pointer.
> The PyQGIS were still pointing to the old disco build image of QGIS.
> I just upgraded to focal. This should be fixed for master in a couple of
> hours.
> For 3.10 and 3.12, it will follow on the next point release.
> Cheers,
> Denis
> Le lun. 1 juin 2020 à 02:23, DelazJ <delazj at gmail.com> a écrit :
>> Hi devs,
>> Looks like the pyqgis doc did not build for quite some times.
>> When you go to https://qgis.org/pyqgis/master, the last update time is
>> today but there are some changes that I'd expect to see there and they are
>> not:
>> eg
>> https://github.com/qgis/QGIS/pull/36566/files#diff-70971f0e258f54410aca383bd4af0942R272
>> still in master code at
>> https://github.com/qgis/QGIS/blob/master/python/core/auto_generated/geometry/qgspoint.sip.in#L272
>> should not render like this
>> https://qgis.org/pyqgis/master/core/QgsPoint.html?highlight=distancesquared3d#qgis.core.QgsPoint.distanceSquared3D
>> Regards,
>> Harrissou
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200603/e50e2cd7/attachment.html>
More information about the QGIS-Developer mailing list
