[QGIS-Developer] pyqgis doc build broken?
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Jun 1 07:06:46 PDT 2020
Hi Harissou,
Thanks for the pointer.
The PyQGIS were still pointing to the old disco build image of QGIS.
I just upgraded to focal. This should be fixed for master in a couple of
hours.
For 3.10 and 3.12, it will follow on the next point release.
Cheers,
Denis
Le lun. 1 juin 2020 à 02:23, DelazJ <delazj at gmail.com> a écrit :
> Hi devs,
> Looks like the pyqgis doc did not build for quite some times.
> When you go to https://qgis.org/pyqgis/master, the last update time is
> today but there are some changes that I'd expect to see there and they are
> not:
> eg
> https://github.com/qgis/QGIS/pull/36566/files#diff-70971f0e258f54410aca383bd4af0942R272
> still in master code at
> https://github.com/qgis/QGIS/blob/master/python/core/auto_generated/geometry/qgspoint.sip.in#L272
> should not render like this
> https://qgis.org/pyqgis/master/core/QgsPoint.html?highlight=distancesquared3d#qgis.core.QgsPoint.distanceSquared3D
> Regards,
> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200601/75fef167/attachment.html>
