[QGIS-Developer] GeoSeer ogc services data harvesting
Jonathan Moules
jonathan-lists at lightpear.com
Tue Jun 9 04:14:36 PDT 2020
Hi Andreas,
Sure, happy to share.
There's a little on the About page: https://www.geoseer.net/about.php
and then scattered around blog posts (the ones with the "GeoSeer" tag
are probably best for that: https://www.geoseer.net/blog/?t=GeoSeer ),
but put simply - We scrape a lot of different sources and metadata
catalogs and get the services from them. Then we request not only the
GetCapabilities that was declared, but also make educated guesses as to
what else might be on the box and request those too.
It's not perfect, but to the best of my knowledge it's by far the
largest such index in the world, and more importantly, it's *current*.
Everything in there responded with a valid GetCapabilities document with
at least one meaningful named dataset when it was last scraped within
the last few weeks.
Pertaining to your given services, GeoSeer has:
http://geoweb.so.ch/wms/sogis_natgef.wms? and a few others on that
sub-domain, as well as some on the subdomain:
http://www.sogis1.so.ch/cgi-bin/sogis/sogis_natgef.wms? - both are now
defunct I see which is why they're not in the database.
Thanks for the URL, I've added it for scraping.
> So I wonder how many other QGIS server installations may not be in
your database?
Alas that's a "unknown unknown"; there's no way to know (I can't think
of a way to find out anyway; suggestions welcome). However the vast
majority of the time when I come across a new service manually (i.e.
from following various mailing lists like this), it turns out it's
already in the index, so I think it's reasonably comprehensive at this
point.
While missing servers may change the absolute number of QGIS
Installations, they're very unlikely to change the proportions. For a
sample-size this large I'd expect the proportions to remain largely the
same, certainly for deployments.
Hope that's of interest and answers the question,
Cheers,
Jonathan
On 2020-06-09 10:45, Andreas Neumann wrote:
> Hi Jonathan,
> Can you share with us how you harvest your information on available
> public OGC services? You probably have that information published
> somewhere - so if you could point me towards this URL, it would help.
> I noticed that all of the services of our province (my employer) can't
> be found, as an example.
> Here is the start point:
> https://so.ch/verwaltung/bau-und-justizdepartement/amt-fuer-geoinformation/geoportal/geodienste/wms-web-map-service/
> and the GetCapabilities link:
> https://geo.so.ch/api/wms?SERVICE=WMS&REQUEST=GetCapabilities&VERSION=1.3.0
> your database? Of course I know you don't claim full coverage, but it
> would still be good to know how you harvest your data.
> Thanks for clarifying and greetings,
> Andreas
