[QGIS-Developer] Typed Variables?
Matthias Kuhn matthias at opengis.ch
Wed Jun 10 09:32:45 PDT 2020
Hi Andreas,
If required, the variable UI (and serialization to ini/project/...)
could made typable.
But for this use case, add a variable with 0 (or 1) and use
CASE WHEN @debug THEN
   'We are debugging'
ELSE
   'No debug'
END
That should just work
Matthias
On 6/10/20 5:26 PM, Andreas Neumann wrote:
> Hi,
> I have a question about the variables that can be defined on different
> scopes. They are most of the times (or always?) strings, if I manually
> define them - right? Some of the automatic variables might be of a
> different type (like date, layer, etc.)
> Can I also manually define a "typed" variable? E.g. a boolean true
> instead of 'true' as a string?
> That way I could directly use variables without having to add CASE
> WHEN END statements ...
> My use case would be to have a boolean "debugging" variable. If it is
> set to true, then certain parts of the form with internal IDs would be
> visible, if set to false, they would be hidden.
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200610/17bb2cf8/attachment.html>
More information about the QGIS-Developer mailing list
