[QGIS-Developer] QGIS startup time, Loading of Processing
Andreas Neumann
a.neumann at carto.net
Wed Jun 10 14:09:59 PDT 2020
Here are the results from Windows 10 (run from inside Virtualbox):
On 2020-06-10 11:50, Nyall Dawson wrote:
> On Wed, 10 Jun 2020 at 19:37, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi Nyall,
>> You are right. GRASS and SAGA take the longest time in initialization. Perhaps we should disable those by default. I think both are for advanced users. These users should know how to enable the SAGA and GRASS providers, should they need them.
>> Here is the screenshot from my QGIS on Linux (without SAGA) (I'll send another one for Windows later):
> Thanks! I'm going to add some more granularity to the GRASS startup
> login shortly (but I'm 99% certain it will confirm that the issue is
> the text file reading...)
>> Seems like DataPlotly also takes substantial time to load.
> Yes - unfortunately that's the 3rd party plotly imports themselves
> which are slow. Possibly there's a way to defer these imports until
> needed till. Could you file an issue on the DataPlotly tracker about
> this?
> Nyall
>> Greetings,
>> Andreas
>> On 2020-06-10 11:27, Nyall Dawson wrote:
>> On Wed, 10 Jun 2020 at 19:22, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> Given that the initialization of the Processing plugin takes around 2/3 of the QGIS startup time, I wonder if we can discuss how to improve the situation?
>> Can there be a "delayed" or "on demand" loading of processing if the user needs it?
>> Quite a lot of users use QGIS for viewing or editing, without any need for analysis. I know that they could disable the processing plugin or use a different user profile where the plugin is disabled, but ...
>> Is there something that we could do as QGIS developers to speed up, delay or on-demand load the processing plugin?
>> Yes, I think there's lots we could do. But I'd love to see a
>> screenshot of the new startup time profiler for one of your affected
>> slow-to-start machines.
>> Typically the culprit is the GRASS and SAGA providers, where they load
>> algorithms from 100s of text files. File access like this on Windows
>> is very slow, so I think the easiest thing to try first would be if we
>> concatenate all the definitions into a single master text file...
>> Nyall
>> Thanks for the discussion,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200610/b6a9041f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200610/b6a9041f/attachment-0001.png>
