[QGIS-Developer] QgsProcessingParameterMultipleLayers in Processing Modeler
matteo matteo.ghetta at gmail.com
Tue Jun 16 03:58:15 PDT 2020
Hi devs,
maybe a silly question but it seems to me that the
QgsProcessingParameterMultipleLayers is not correctly exposed in the
Processing Modeler Input, but maybe I'm missing something.
If you create a new model and try to add a "Multiple Input" input in a
model that you want to use with the "Merge Vector Layers" algorithm, the
way to feed the algorithm is by using the "Value" mode while I was
expecting to use the "Model Input".
The model is running just fine, but not sure if this is the expected
behavior.
Before to open a ticket I just wanted to have some feedback :)
Cheers
Matteo
More information about the QGIS-Developer mailing list
