[QGIS-Developer] QgsProcessingParameterMultipleLayers in Processing Modeler
Nyall Dawson nyall.dawson at gmail.com
Tue Jun 16 20:28:58 PDT 2020
On Tue, 16 Jun 2020 at 21:54, matteo <matteo.ghetta at gmail.com> wrote:
> Hi devs,
> maybe a silly question but it seems to me that the
> QgsProcessingParameterMultipleLayers is not correctly exposed in the
> Processing Modeler Input, but maybe I'm missing something.
> If you create a new model and try to add a "Multiple Input" input in a
> model that you want to use with the "Merge Vector Layers" algorithm, the
> way to feed the algorithm is by using the "Value" mode while I was
> expecting to use the "Model Input".
> The model is running just fine, but not sure if this is the expected
> behavior.
> Before to open a ticket I just wanted to have some feedback :)
Thanks -- fixed in https://github.com/qgis/QGIS/pull/37261
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
